BMW M3 Forum (E90 E92)
Mporium BMW
      05-08-2009, 11:38 PM   #1
tbucella
tbucella's Avatar
Drives: 23 M240iX; 09 M3 Sedan
Question Shift Light for 6MT?
Has anyone installed a shift light on a six speed E9x M3? (Let's not discuss why BMW chose to omit this.) I would really like to install one.
      05-09-2009, 06:21 AM   #2
Genro757
///M-Flight VP
Genro757's Avatar
Drives: '13 Frozen Red Edition E92 M3
2013 E92 M3  [0.00]
I have shift lights on my BMW Performance Steering wheel...
2013 "Frozen Red Edition" E92 M3, M-DCT with all the 'fixin's, Akrapovic Evolution w/CF Tips, BPM Stage 2 Tune, BPM DCT Software
      05-09-2009, 09:00 AM   #3
SOARISTO
SOARISTO's Avatar
Japan
29
Drives: New M3 Coupe M-DCT
Cool
Hello, M3 Fighter Pilots!!
My M3 friend (6MT) has succeeded to install Shift Indicator, using the information of my site.
In Japan, some products are sold as follows.
This is DIGITAL type, like BMW Performance Steering LED.
This is ANALOG type.
These Shift Indicator is made by Pivot, and model list is here.
The Tacho Signal (Engine Spark Pulse Signal) can get form OBD-II Port.
Pin 9 is "Tacho Signal" and pin 4 or pin 5 is "Earth" (Signal Ground).
Some information about "Tacho Signal" (OBD-II Port) see here.
(Sorry, This site is written in Japanese.)
      05-09-2009, 11:09 PM   #4
tbucella
tbucella's Avatar
Smile
Thanks for the information, I will look for this connector. I'm an Electrical Engineer so I will check out the signal with an oscilloscope.
This is very helpful!
      05-10-2009, 06:39 PM   #5
lucid
lucid's Avatar
Drives: E30 M3; Expedition
If someone can post a detailed DIY on this, that would be highly appreciated!
      05-16-2009, 07:40 AM   #6
syncros
Drives: 2008 M3 Coupe
Very interesting.
      05-16-2009, 09:11 AM   #7
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
I think if someone really wants shift lights, the Performance SW is the way to go! Plus you get the other functionallity that comes with it.
      05-18-2009, 08:53 AM   #8
tbucella
tbucella's Avatar
I was just about to by a light when I read the above. When you get performance SW what is used as the light? What software would you recommend?
      05-18-2009, 09:13 AM   #9
SlammedR8
SlammedR8's Avatar
Drives: 2019 X5 40i/2020 R8 V10 Spyder
Really? Some of you guys think this is necessary in a 6MT? I don't see why you would need it, and especially not the ones posted above. They belong in Hondas/Toyotas.
If you really want one, then throw the money down for a Performance SW
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather
2020 Range Rover HSE - Black/Black
2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black
      05-18-2009, 10:09 AM   #10
lucid
lucid's Avatar
To avoid catching the limiter on the track...I'd rather not spend $1k on a new steering wheel I don't need if I can find an alternative solution for much less.
      05-18-2009, 10:35 AM   #11
mPlasticDesign
684
The shift lights are on the steering wheel(see picture) Just check out this thread, PencilGeek did a nice write up.
http://www.m3post.com/forums/showthread.php?t=163635
      05-19-2009, 08:08 AM   #12
tbucella
tbucella's Avatar
I agree. I misread the previous posts with performance SW as "performance software", hence my question about which SW. With all deference to those who have installed the performance wheel, I don't like the look of it, I prefer the standard wheel. In addition, the installation looks like a full days work for a pro, more if you are an amateur tinkerer. And... it does cost a $1000 bucks.
I have found two shift lights that look like winners and have made some paper tube models to try and figure out where to mount them. Right now I am leaning toward an A-pillar mount. But there are options within the tech screen recess, on top of the dash between the humps and also within the instrument cluster on the right side. I am also considering a single super bright LED mounted so it's completely out of sight when unlit. The solutions cost between $100-$150 and should be able to be installed in a couple of hours. It'll probably still take me some time to get around to it, but I'll post my install once I have it done.
Here are the shift lights I have been looking at:
http://www.raptorperformance.com/pro...hift_light.htm
http://www.speedhut.com/product_deta...NUMBER-737.htm
Or this one with an external lamp for a more stealthy install:
http://www.raptorperformance.com/pro...RPM_Switch.htm
      05-19-2009, 09:05 AM   #13
lucid
lucid's Avatar
Thanks for the info/links.
I would like to have the light right above the dash so that I don't have to look down or to the side. But if it is bright enough, it might not matter all that much as it would get your attention.
Please let us know how you end up setting this up. If you post a DIY for the wiring, that would be great; I'll add it to the DIY index.
      02-11-2012, 06:11 PM   #14
Factoy Pilot
Factory Pilot
Factoy Pilot's Avatar
Netherlands
Drives: E92 Jerez Blk ZCP 6MT
2011 528i  [0.00]
2013 M328i  [0.00]
2011 M3  [6.00]
Shift lights, REALLY? Why buy a MT? IMO I'd spend the $$$ on another mod.
      11-29-2012, 07:13 PM   #15
janeym3
Drives: Blue M3
M Performance Steering Wheel
This thread may have already answered your steering question, but I'm jazzed that this ties in perfectly with something I was listening to yesterday
http://stitcher.com/s?ABoAAKnyu=refid&twsn
Embedded in the steering wheel is a display embedded that features Gforces, with shift lights, an accelerometer, & a 1/4 mile mode, with red, yellow & green start. The audio specifically about the wheel is in the final 5 minutes of the clip linked above.
      11-29-2012, 08:16 PM   #16
BPMSport
BimmerPost Supporting Vendor
BPMSport's Avatar
Drives: Harrop M3 / F10 M5 / F82 M4
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
I tried for a week getting the DCT shift lights to work in a 6MT and I'm sorry to say that it seems impossible using the factory modules... I believe the DCT control unit is what sends the command to the cluster to make the lights go on, so without the DCT control unit in there there is nothing telling them to turn on ;(
I was really disappointed by this, but am going to look into adding a module which will make the shift lights work in manual cars.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      11-29-2012, 08:36 PM   #17
S65NAPWR
Drives: M3
Good man, make it happen. I'll buy the first one.
      11-29-2012, 09:24 PM   #18
ruff1017
ruff1017's Avatar
27
Drives: 09 M3 6speed
That will be great! I will get one also.Keep it up!
      11-30-2012, 01:29 AM   #19
kaiv
IG: limited.slip
Drives: E46 M3 in a 325i Touring body!
100% agree.
And if you need a light to tell you when to shift at an hpde that's kinda sad :X
      11-30-2012, 02:02 AM   #20
whats77inaname
Drives: when at all possible
      11-30-2012, 02:06 AM   #21
Z K
Z K's Avatar
1887
Drives: E90 M3, G20 M340i
Originally Posted by whats77inaname View Post
That is pretty dumb.. The temp gauge looks like it is indicating boost? What if you actually want to use the temp gauge? That is probably the most valuable gauge when you are on track.
      11-30-2012, 11:32 AM   #22
whats77inaname
Actually, it's programmable, and it's AFR.
Tags
shift light
m3post
