BMW M3 Forum (E90 E92)
Mporium BMW
      05-05-2009, 08:18 PM   #1
CRS_M3
Drives: BMW E92 M3 - AW/CF Roof
Camber Settings for Track
I just purchased a new set of Pilot Sport Cup+ for the stock 19 Inch wheels. I intend to track the car and not too sure if I need to set some negative camber in the car for these tires. After adjusting Camber, will it affect Toe? Do I need to do a wheel alignment?
Can I just set negative camber on the car without camber plates? Can this be done easily (DIY) or mechanic? If I need camber plates for front and rear, any recommendations?
Thanx for the help!
      05-21-2009, 11:45 AM   #2
Green///Hell
Green///Hell's Avatar
Drives: 991 GT3, F15 X5, 1199S
there is not much room on the stock setup and to get the PCUPS to work properly you will need to run negative camber.
I think if you're staying with the stock suspension you can use the Dinan top perches to max it out a little bit more. I think you need negative 2-2.2 for those tires
The rear I'm not sure anything is available yet but companies are going to being producing some camber arms You will need to align everything
      05-21-2009, 05:02 PM   #3
lucid
lucid's Avatar
Drives: E30 M3; Expedition
You can get ~-1.4 out of the stock fronts with the pins pulled.
      06-03-2009, 12:59 AM   #4
m3larson
Drives: 2014 M6 Gran C 1997 M3 Track C
The dealer said they have to remove my front bumper to line up the lasers for an alignment on my lowered M3. If I take it to another shop is there specs somewhere I can have them set the camber to?
The Verdict: Every other manufacturer should give up on building their own cars and just make M3s instead. -Car and Driver June 2008
      06-03-2009, 01:11 AM   #5
swamp2
swamp2's Avatar
Drives: E92 M3
Are you running on the track and on the street with you pins pulled? Does pulling the pins require and alignment?
      06-04-2009, 10:22 AM   #6
attila
attila's Avatar
83
Drives: 2015 Mclaren 650s, 2015 GTS4,
I could get -1.2 on the front both side without the pins removed. My BMW service refused to remove the pins since " it is not recommended by BMW". I feel some change, mainly because i was running neutral and positive on one side!! as a factory setup. Would like to find an independent shop to pull the pins out and max - camber.
I am not convinced by the Dinan camber plates. An extra -0.5 degree for $500??!!!
      06-04-2009, 11:53 PM   #7
attbimmer
attbimmer's Avatar
13
Drives: '08 E90 M3, '88 E30 M3
Removing the pins is fairly simple. You just need to remove the plastic covers that hold the micro filter and then remove the strut braces. I did it a few weeks ago.
Regarding the Dinan camber plates they are only $250, not $500 (unless that was with labor), and they add -0.7 degrees. They are not adjustable (and will slightly raise the cars front ride height, but are a fairly common way to cheaply add negative camber.
      06-05-2009, 03:18 AM   #8
lucid
lucid's Avatar
My understanding is that pulling the pins simply provides more "potential" movement. In order to realize that potential, you need to unbolt and slide the mounts, so alignment seems necessary after that is done as that is not exactly a precise operation, but someone should confirm this.
      06-05-2009, 08:23 AM   #9
attila
attila's Avatar
83
My mistake, I thought Dinan is selling not a pair but a single plate for $250!
I would not pull the pins and adjust the camber without realignment.
      06-05-2009, 12:27 PM   #10
FrenchBoy
FrenchBoy's Avatar
France
233
Drives: '16 F80 M3
I am planning to have my favorite shop tweak my car alignment by maximizing the camber I can get from the stock setup and going zero toe in the front.
The alignment pin in the shock tower support plate needs to be removed to get maximum camber. Just to be clear, this should be doable from within the engine bay by loosening the 3 suspension bolts on each side and pulling the pin out. No need to pull the suspension assembly out. Is this correct?
On a seperate note, I am also planning to have the shop fit my Schroth 4-point harness in the M3. I have the E46 quick fit kit (from my old E46) but Schroth does not make a E90 quick fit kit yet. The plan is to use the E46 kit and use one of the front seats attachment bolts. Hope it works!
Current: 2016 F80 M3 6-Speed | SO | AB XT1 | ZCP | M Performance Suspension | GC Camber Plates
Previous: 2009 E90 M3
      06-05-2009, 01:55 PM   #11
attila
attila's Avatar
83
Yes, that's correct!!
      06-05-2009, 04:05 PM   #12
lucid
lucid's Avatar
Yes, you should not have to pull the suspension out. You should be able to make the adjustment after loosening the 3 bolts.
      06-05-2009, 04:54 PM   #13
FrenchBoy
FrenchBoy's Avatar
France
233
Drives: '16 F80 M3
Thanks guys!
      06-05-2009, 06:33 PM   #14
jml
jml's Avatar
128
Drives: X5M, GT3RS, GT4
It's not turning out to be as big of a problem as I thought. If you run higher pressures (40psi back in the paddock), rotate, and flip once, you get reasonable life out of a set of NT01s (4 DE days). The camber curve is much improved on the E90 over the E46. Rear can easily do -2 degrees, which also seems to be fine.
      06-06-2009, 04:03 AM   #15
lucid
lucid's Avatar
I have -1.75 in the rear, and that proved to be too negative. Both rear tires were hotter on the insides than the rest of the tire (outside and mid sections were even). That's with about 41-42 psi hot on BFGs. I will have that dialed back. I have -1.95 up front with the camber plates, and that worked well with even temps across both front tires.
      06-06-2009, 09:48 AM   #16
jml
jml's Avatar
128
Cool. I'm just happy the front does not need -3.5 like the E46. I could probably back off the rear a little, but it seems to be wearing fine. The rear does get a little squirrelly putting power down mid exit to exit...
      06-20-2009, 07:40 AM   #17
dawgdog
Drives: 2015 M3, 2016 GT3
I just had springs installed and when they set the camber settings during allignment I ended up with -1.2 in front and, if I recall correctly, -1.7 in the rear.
2015 f80 M3, 2016 GT3
      06-20-2009, 09:13 AM   #18
FrenchBoy
FrenchBoy's Avatar
France
233
Drives: '16 F80 M3
You should bring you car to Redmond Town Center this morning ;-)
http://www.m3post.com/forums/showthread.php?t=274045
Looking forward to checking out your car.
      06-20-2009, 09:28 AM   #19
von_zoom
von_zoom's Avatar
30
Drives: 2010 Z06
Lucid, are you running this on the street? If I recall correctly, you are not running a square set up on the track. By not being square, does this have any effect?
I have -1.75 in the rear, .... I will have that dialed back. I have -1.95 up front with the camber plates, and that worked well with even temps across both front tires.
Thanks, vz
Previous Track Toy
      06-20-2009, 09:48 AM   #20
attila
attila's Avatar
83
I asked it in a different thread but more of topic here:
Does anyone running Dinan camber plates with the stock springs?? Is that lift up the front?
Is it worth getting the Dinan springs?? I mean, for the track.
      06-22-2009, 11:13 AM   #21
lucid
lucid's Avatar
Yes, this is my DD. And, yes, I have a 265/295 setup. -1.9 camber up front reduced understeer nicely, and the car does rotate more easily. I'm pretty happy with it.
-1.75 rear was too much. I was heating up the inside edges of both tires, and lost some grip, but that might have been a pressure issue. I had that dialed back to -1.4.
      06-22-2009, 11:14 AM   #22
m3larson
How bad is the wear on your street tires?
m3post
