04-28-2009, 02:02 PM | #2 |
Rep 770
Not when I have 18's with the r-comps mounted. TMPS malfunction warning goes on, but who cares. Not worth the extra expense since I check the tire pressures in between almost every run session anyway.
Although with rain during my last 2 track days, I've been using the stock 19" PS2s with TPMS as my "rain tires" and they work well enough to get some traction.
2021 A6 Allroad, 2020 SQ7, 2019 M5 Comp, 2011 GT3
past: A4, S4, X5 4.8is, SLK55, E60 M5, RS4, ML63, E92 M3, Q5, Touareg TDI, Escalade, SQ5, RS7, Velar FE, Q7 |
02-03-2010, 12:45 PM | #4 |
Rep 629
I did not use TPMS in 2009, about 10 track days, and not planning to use it this year either.
I have dedicated track wheels/tires. Change them at the track. |
02-03-2010, 08:55 PM | #5 |
Rep 697
I asked the same question a while back. I got them and am glad I did!
http://www.m3post.com/forums/showthr...highlight=tpms |
02-03-2010, 11:39 PM | #6 | |
Rep 664
02-04-2010, 11:22 AM | #7 |
BimmerPost Supporting Vendor
8065
Rep 18,788
For the track, you may want to look into the TPMS emulation module from Macht Schnell, this will allow you to turn on/off TPMS monitoring at will.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
02-05-2010, 12:43 AM | #8 | |
Rep 4,737
I would definitely use TPMS on the track. You want to know when your tires are out when going at 100 mph+. GL. |
02-05-2010, 01:45 AM | #9 |
Rep 1,664
works fine on the stock setup, zero issues multiple days....
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
02-05-2010, 11:54 AM | #11 |
Rep 1,664
TPMS, I would probably add it to my track setup also when the time comes.
02-05-2010, 12:01 PM | #12 |
Rep 697
The only minor thing that I have seen with my TPMS on track wheels is that the light sometimes goes off 1st thing in the morning when I bring the cold pressure down to 26lbs. They system probably has a cutoff point around 26 where it thinks that you don't have sufficient pressure.
The light goes off after a couple of laps when the tires warm up and never comes back on for the remainder of the day. I think the only reason not to get TMPS is the cost, but for $200 I can't see why one would cut this corner. |
02-05-2010, 12:24 PM | #13 |
Rep 664
I have a spare OEM 18 set, so I'll probably switch those TPMS to the new rims. Probably best 'cos I'll want to DD with the track setup for a few days to break in the tires.
