E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Interesting cellphone cradle problem
      07-22-2005, 10:47 AM   #1
agarbati
agarbati's Avatar
39
Drives: E90, Saph Blk 330i
So I got the cell phone adapter and base plate for my Motorola V710. I was in the middle of a conversation and the phone died. I checked and it was because of low batt. I thought the phone cradle was supposed to charge the phone if the phone was docked.
Anyone?
      07-22-2005, 10:49 AM   #2
ravinxd
ravinxd's Avatar
Drives: '11 E92 with M-sport pkg
The cradle only charges when the car is running. If you have a low battery to begin with, using bluetooth might use more juice than the charger can deliver back to the battery.
      07-22-2005, 11:08 AM   #3
agarbati
agarbati's Avatar
39
So if I have a low batt, the bluetooth draws more current than the cradle charger puts in?
Also, the car was running during the conversation.
      07-22-2005, 11:10 AM   #4
Broken1
Addict
Broken1's Avatar
203
Drives: 2024 X5 40i M-Sport
It might not have been connected properly, or the phone wasn't properly inserted into the cradle.
Try putting your phone in, and moving it...or placing it so that the phone idicates to you that it is charging...or take it back
      07-22-2005, 11:13 AM   #5
agarbati
agarbati's Avatar
39
Yep, no matter how I insert the cellphone it never indicates it is charging. Think I'll have to go back.
      07-22-2005, 11:21 AM   #6
spydrz
spydrz's Avatar
Drives: '15 M4, '15 i3
06 330i  [7.00]
2002 X5 3.0i  [0.00]
2001 525i  [0.00]
The wire connection is right under the parking-brake boot...you simply unsnap (carefully) the leather boot from the console and the connections are in there. Mine charges, but I have no antenna reception...
2002 X5 3.0i/man.*
2006 330i/man./Arktis/Grau*
2001 525i/step./Schiefergrün/Sandbeige*
2013 X1 xDrive35i Alpinweiß/Schwarz/M Sport/Dinan Stage 2
*retired
      07-22-2005, 11:48 AM   #7
robertb
Drives: 2012 335i
My cradle charges fine, but the instant I plug the phone completely into the cradle I lose all my signal strength. I guess I'll be going back to the dealer too.
      07-22-2005, 11:51 AM   #8
spydrz
spydrz's Avatar
06 330i  [7.00]
2002 X5 3.0i  [0.00]
2001 525i  [0.00]
I'm going to swing by there today...my guess is there's a connection loose in the trunk.
2002 X5 3.0i/man.*
*retired
      07-22-2005, 12:34 PM   #9
E90Fleet
South Africa
1312
For the signal guys , ask your dealer to check the antenna wire is actually connected to the fin
Onthe 5 Series when it came out they forgot to put on the instructions that the antenna cable wasnt connected from the factory and guys had no signal.
Connecting the wire fixed it
      07-22-2005, 12:35 PM   #10
E90Fleet
South Africa
1312
agarbati it sounds like your cradle isnt pluged in correctly
      07-22-2005, 01:03 PM   #11
spydrz
spydrz's Avatar
06 330i  [7.00]
2002 X5 3.0i  [0.00]
2001 525i  [0.00]
Will do!
Is there any way I can check this myself? They just had the car for a week and only 1/2 the things were fixed. Does the cover pop off?
2002 X5 3.0i/man.*
*retired
      07-22-2005, 01:10 PM   #12
E90Fleet
South Africa
1312
Originally Posted by spydrz
Will do!
Ill try and see if I can find out where to check , just a little busy right now
      07-22-2005, 01:20 PM   #13
spydrz
spydrz's Avatar
06 330i  [7.00]
2002 X5 3.0i  [0.00]
2001 525i  [0.00]
Thanks, I appreciate it!
2002 X5 3.0i/man.*
*retired
      07-22-2005, 01:41 PM   #14
E90Fleet
South Africa
1312
Ok,apparently its not easy
There are 4 connections
1)wire to fin
2)wire to telephone control unit
3)wire from telephone control unit
4)wire into cradle dock
They reccomend you dont touch anything if you dont know what you are doing
The easiest one is the wire from the docking cradle somewhere behind the hand brake (emergency brake) leather cover
There should be 2 connectors from the cradle and both must be pluged in ( smaller one is antenna )
It does seem that its best left to a trained tech to check it
      07-22-2005, 01:58 PM   #15
spydrz
spydrz's Avatar
06 330i  [7.00]
2002 X5 3.0i  [0.00]
2001 525i  [0.00]
1)wire to fin
OK, I know the one in behind the handbrake is connected, because I connected it myself...the TCU is under the trunk carpeting, and all plugs seem to be attached securely...and I removed the small cover by the CHMSL in the rear of the roof and saw that plug connected to what appears to be a base unit for the fin. So I guess it's going to be up to the dealer techs to look into it.
2002 X5 3.0i/man.*
*retired
      07-22-2005, 02:04 PM   #16
E90Fleet
South Africa
1312
So did you install it ? ( since you pluged in the cable yourself )
maybe it needs coding
      07-22-2005, 02:06 PM   #17
spydrz
spydrz's Avatar
06 330i  [7.00]
2002 X5 3.0i  [0.00]
2001 525i  [0.00]
I did install the eject box/snap-in myself. Do you think it would require coding to receive an antenna signal?
2002 X5 3.0i/man.*
*retired
      07-22-2005, 02:18 PM   #18
E90Fleet
South Africa
1312
Just thinking of possibilities, maybe the TCU needs to be switched on or something
I havent seen any installation instructions for these yet, so dont know exactly what has to be done.
Ill try and get soe, but it could take a few days at least
      07-22-2005, 02:50 PM   #19
spydrz
spydrz's Avatar
06 330i  [7.00]
2002 X5 3.0i  [0.00]
2001 525i  [0.00]
Thanks so much! I installed a complete BT retrofit kit on my X5, so I figured this would be easy--since my car has BT standard. Now I only get a signal when my car is right under a phone tower
2002 X5 3.0i/man.*
*retired
      09-01-2005, 06:52 PM   #20
arturo rivera
Drives: 330i(e90)
phone cradle
when I plug the phone to the cradle after 5 minutes or so ....it loses signal.....any ideas?
e90post
