E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > 19's and best % combination 225 fronts?
      04-05-2009, 08:29 AM   #1
flyguy
flyguy's Avatar
Drives: E92 335xi, Alpine White
Unless I am making a mistake isn't the best % combination for xi with 19's a 225-35R 19 on the front with 265-30R 19 closer (better) than using a 235 on the front? Seems that way on Tire Rack specs. Am I wrong? Was going to get 235 for front but now I am questioning that?
      04-05-2009, 10:13 AM   #2
jgalaxy
Gearing
jgalaxy's Avatar
Drives: E46 M3, F22 M240
The OEM staggered setup on 18s is 255/35/18 and 225/40/18 and 19s are 255/30/19 and 225/35/19. That is reference that can be put thru any tire size calculator (The Tire Rack forum here has one).
I have 265/30/19 and 235/35/19 (10.5" and 8.5" M1 replicas) - Tons of understeer. Looks nice though.
The key is to maintain the run diameters as close to OEM as possible and to keep any % difference between front and rear run ratios as close to zero percent as possible.
This is a good tire size calculator
http://www.1010tires.com/tiresizecalculator.asp
If at first you don't succeed ...
      04-05-2009, 06:25 PM   #3
Ph0zenstone
Ph0zenstone's Avatar
324
Drives: 2018 530e X-Drive
i have 225/35/19 up front and 255/30/19 which is the oem tire size. you're best bet is to stay as close to that as possible to net you the least % variance.
      04-05-2009, 06:36 PM   #4
JaysBlueE92
Mr. Monaco
JaysBlueE92's Avatar
Drives: Slow..
2007 E92  [5.00]
I actually think 235/35 up front and 265/30 rear is the recommended setup...
      04-06-2009, 05:46 AM   #5
Ph0zenstone
324
i thnk thats the recommended setup per Tirerack but thats not the oem size. I think its still under 1% for both of them but the 225/35 and 255/30 is closer to 0%.
e90post
