E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > can i run 245/40-18 all around on XI
      03-22-2009, 02:14 PM   #1
gumpy
Drives: 2011 BMW 135i DCT
I am buying some 18x9 inch wheels and want to run 245/40-18 at all 4 corners of my 335xi. I have H&R coilovers with the car lowered. Anyone know if this wide of a tire will work?
Thanks,
Gumpy.
      03-22-2009, 04:20 PM   #2
MaxL
Drives: E90 M3, Cayenne T, 991 GT3
I have this setup with stock suspension and it works great - improvement over stock in both performance and comfort. The bigger wheels fill the arches much better as well. Not sure if your lowered suspension can cause any rubbing...
      03-25-2009, 07:49 PM   #3
gumpy
Thanks for the info. Gives me a little peace of mind until my new wheels and tires get here!
The H&R's are awesome and I don't think it will rub. It did not rub with stock tires with 3 people in the car over some rough roads.
Looking forward to see how she handles with a significantly larger contact patch!
Take care.
Gumpy.
      03-25-2009, 07:59 PM   #4
adr1974
Drives: 2021 X5 xDrive 40i
Hey MaxL -- you don't have any pictures of your setup, do you? Would like to see how the bigger tires fill the xi wheel gap on stock suspension.
Thanks,
Adam
      03-25-2009, 08:01 PM   #5
JaysBlueE92
Mr. Monaco
JaysBlueE92's Avatar
Drives: Slow..
2007 E92  [5.00]
In the wheel and tire forum i got the ok on running a 245 / 19 up front..so should be ok
      03-25-2009, 08:04 PM   #6
VMRWheels
BimmerPost Supporting Vendor
VMRWheels's Avatar
2038
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
What are the offsets of the 18x9's? We can narrow it down the fitment clearance some more if you can post them.
-Charles@VMRWheels
www.vmrwheels.com
      03-25-2009, 09:25 PM   #7
THR4OSU
Drives: 2006 330XI
18X9
I am running 245/35 19's at all 4 corners and I also have H&R coilovers. You will have no problems.
Thanks,
Gumpy.
      03-26-2009, 06:41 PM   #8
who's ur daddy?
Drives: Canada's first and only 323xi
I'm curious to know what kind of rim width and offset you guys are using for the 245's. Please post.
      03-26-2009, 06:47 PM   #9
gumpy
THR4OSU,
Thanks for the reply. It's good to know that it will work fine on my car.
Gumpy.
      03-29-2009, 03:48 PM   #10
DESI4life10
DESI4life10's Avatar
Drives: Coding: Desi4life10@gmail.com
I do not mean to hijack your thread. I just thought this might be a better place to post my question rather than creating a new topic.
I have a 328xi with no spot package. I am in the market for some new wheels and came apon a seller on e90.
He is selling a set of OEM style 162 rims that have the runflat bridgestone potenza tires.
Now his tire setup is:
225/40R18-Front
255/35R18- Rear
Am I safe to put this staggered setup wheels on my xi? I used the tire calculator and I got a difference of 0.236% (speedometer reading will be .2% too fast)
Also, do I risk the wheels rubbing with my fender using this setup?
Thanks
      03-29-2009, 08:46 PM   #11
who's ur daddy?
225/40R18-Front
255/35R18- Rear
Thanks
A million threads on this. This is the OEM staggered set up for sport packaged xi's. So, yes, you can run this set up and there will be no rubbing.
      03-29-2009, 08:47 PM   #12
who's ur daddy?
bump for more width and offset info on you square guys... :P
      03-29-2009, 08:52 PM   #13
DESI4life10
Thanks for letting me know. I just wanted to double check.
      03-29-2009, 08:59 PM   #14
TofuTurkey
Gobble gobbledygook
TofuTurkey's Avatar
Drives: 08 335xi Coupe
I'm square
I'm running 245/35/19, ET30. Not lowered. Front doesn't rub, not sure what the range of ET is for it to stay that way.
Btw, how do you like the coilovers? Does it make any squeaky sounds when you go over bumps?
      03-30-2009, 07:12 AM   #15
gumpy
H&R coilovers are awesome. No noise whatsoever. Here is a link to a post of mine describing the coilovers.
http://www.e90post.com/forums/showthread.php?t=243279
Gumpy.
      03-30-2009, 09:52 AM   #16
DESI4life10
Got another question regarding the setup I was talking about above.
I am planning on buying the set used. This set was used on an RWD car. I guess with the RWD, the rear tires will wear down faster than the fronts.
Now for AWD, we have to be careful with the diameter. Putting the tire size info in the tire calculator gave me a 0.2% difference which is clear for the AWD.
But what happens when we buy a used set? does the "rolling" diameter change significantly to the point where I can not put these wheels on my car?
Thanks
      03-30-2009, 11:32 AM   #17
who's ur daddy?
Thanks
Tire wear will depend on how aggressively the person drives.
You are worrying to much man!
      03-30-2009, 12:56 PM   #18
DESI4life10
Yea I know I worry a little too much. I just don't want to get screwed over by BMW if something happens to the car due to the tires.
      03-30-2009, 01:30 PM   #19
Ph0zenstone
Ph0zenstone's Avatar
325
Drives: 2018 530e X-Drive
see my thread here: http://www.e90post.com/forums/showthread.php?t=246356
i'm running staggered no problem and the difference is within 1% i believe
      04-06-2009, 12:42 AM   #20
mgl
________________________
Drives: aw e92
i have a set of 245/40zr18 michelin ps2's available for sale if anyone is interested.
http://www.e90post.com/forums/showthread.php?t=248676
e90post
