BMW M3 Forum (E90 E92)
EXXEL Distributions
      03-21-2009, 04:00 PM   #1
lucid
lucid's Avatar
Drives: E30 M3; Expedition
TE37 Track Setup Mounted
I mounted the TE37s I purchased last month to check for fit. The specs are:
18x9.5 ET28: 265/35 BFG
18x10.5 ET30: 285/30 BFG
Suspension is stock for the time being. (I don't want coilovers on this car--at least not yet.)
I might run spacers in the back, but haven't decided what size...
Here are some pics, including the stock 19" wheels with PSCs on for comparison.
Name:  TE37 side 2.JPG
Size:  310.7 KBName:  Stock F.JPG
Size:  298.3 KBName:  TE37 R.JPG
      03-21-2009, 04:56 PM   #2
r_seng
End Game
r_seng's Avatar
Drives: Devil's Chariot
Looking great lucid! You can never go wrong with TEs!
Can you get a detailed shot of that stick on the spoke? I've never seen it before.
      03-21-2009, 05:04 PM   #3
lucid
lucid's Avatar
The sticker says "TC Kline Racing". I bought the wheels used from TC Kline. I think he had the wheels custom made as a large order with Rays.
      03-21-2009, 05:33 PM   #4
dawgdog
Drives: 2015 M3, 2016 GT3
Love the wheels and your car looks great! Where did you purchase them?
2015 f80 M3, 2016 GT3
      03-21-2009, 05:37 PM   #5
lucid
lucid's Avatar
http://tcklineracing.com/wheels1.htm
      03-21-2009, 05:52 PM   #6
makots
makots's Avatar
Singapore
49
Drives: '08 e92 M3 AW 6MT
sick man lucid! TE37! haha.
2008 AW/BLK M3 6MT / Eisenmann Race / H&R / HID Angels / 3D Front & Rear Lip / UUC SSK / TE37 / Turner Pulleys / 4.10FD & 2 Clutch Salisbury Diff / Escort 9500ci
      03-21-2009, 05:54 PM   #7
endofanera7
endofanera7's Avatar
Drives: 08 JB E92 M3
Sweat!!! TE37s are just so aggressive! def great for track!
      03-21-2009, 10:15 PM   #8
M3V8Driver
M3V8Driver's Avatar
Drives: E92 M3 - DCT
Looks good. I was wondering two things: Did you measure the front and rear track? I would like to sompare it to the stock track measurements. Second, does the rear feel loose? It looks like you could use spacers in the back, as you suggested. The track actually "looks" narrower than the front.
      03-21-2009, 10:15 PM   #9
Ryan@IND
BimmerPost Supporting Vendor
Ryan@IND's Avatar
Drives: ACR
Lucid.... They look great. Hopefully you will get to see tons of track time with those, real soon.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      03-21-2009, 10:25 PM   #10
lucid
lucid's Avatar
April is the month!
I'm still considering your quote on the Advans for street wheels btw...That or the RAC project, if it happens...
      03-21-2009, 10:39 PM   #11
lucid
lucid's Avatar
I didn't measure the track width. Track width, as measured by the distance between the center of the tires on the same axle, should not change much with the front setup since the offset is only 1 mm off from stock. The rears are about 7 mm off though, so that would translate to a track reduction of 14 mm. I don't think that is significant enough to make the rear feel loose, but I haven't driven the car hard with this setup yet. The stock track is 60.5" front and rear.
      03-23-2009, 04:19 PM   #12
monsta
monsta's Avatar
Drives: E92 M3
looks great Lucid! I called TC a lil while back but they didn't have anything else available @ your price
'08 E92 M3 6MT | IB | FR | RAC RG63's | VRS Ti Exhaust | Fabspeed HFC & Xpipe
'09 X5 35d SG/SB
'11 X3 28i AW/CN/FW (wife's car
      03-23-2009, 10:05 PM   #13
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
nice - what do they wiegh? youwill love the tire if you havent tried it already.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
      03-23-2009, 10:31 PM   #14
badfish
badfish's Avatar
100
Drives: E92 AW M3
2008 M3  [0.00]
Nice track setup. Strange but to me they look smaller than the stock 18s for some reason.
      03-24-2009, 11:38 AM   #15
lucid
lucid's Avatar
Rear wheels weigh 44.5lbs, fronts 43lbs.
I know you use the same tires on the track. What hot pressures were you running last year?
      03-24-2009, 11:46 AM   #16
lucid
lucid's Avatar
You are correct. The tires have a smaller diameter. Stock 18" PS2 are 25.7" F/26.3" R. These are 25" F&R. You are limited by the sizes BFGs come in.
      03-24-2009, 03:13 PM   #17
sayemthree
sayemthree's Avatar
597
37 to 43 hot per BFG tech info.
      03-24-2009, 03:25 PM   #18
sayemthree
sayemthree's Avatar
597
required reading - care and feeding of the R1 tire:
http://www.tirerack.com/images/tires...ce_R1_care.pdf
      03-24-2009, 04:10 PM   #19
monsta
monsta's Avatar
Drives: E92 M3
great read thanks for posting since I'm about to pull the trigger on a set for some stock 18's I just picked up for track use...
I'm thinking about running basically same set up lucid 9.5F 10.5R what do you think? & where can I get a set for the best price?
'09 X5 35d SG/SB
      03-24-2009, 06:20 PM   #20
lucid
lucid's Avatar
Not sure what you mean Monsta. Do you want an identical set of TE37s? If so, TCKline might have new ones in stock, but you are looking at $750 a piece; it seems like they sold the used ones they wanted to get rid of. Otherwise, it might be hard to find these in stock in 18".
If you are looking for alternatives, I would seriously consider Advan RS, but I don't know that you'll have 18" sets in stock.
      03-24-2009, 06:42 PM   #21
monsta
monsta's Avatar
Drives: E92 M3
Sorry maybe I wasn't clear enough...I just got a set of OEM 18's for track use in the meantime, I'm just starting to get into trackdays (w/ car) don't want to jump head first into a $3k+ set of wheels just yet, but did order some RS19's from Rennspec & will upgrade brakefluid....I did speak to TCKline couple weeks ago regarding the TE37's they told me to give a call back in a couple weeks they might have some available...
my question was regarding the BFG R1's....what size should I go F&R and where is the best place to buy from....
hopefully I'm clearer now...
'09 X5 35d SG/SB
      03-24-2009, 08:37 PM   #22
lucid
lucid's Avatar
Sizing might be an issue. You might need to go 245/40 and 275/35, but that might be too wide for the 9.5" rear wheels although tirerack give a range of 9" to 11" for that tire. See sizes here:
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
I bought mine from tirerack. They had the best prices I could find, and great service.
Did the stock rims come with PS2s? If so, considering you are a beginner, you might just want to stick to those for the time being.
m3post
