BMW M3 Forum (E90 E92)
      03-19-2009, 11:25 PM   #1
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
Arrow DIY: BMW Performance Steering Wheel
Hey guys,
Here is DIY on how to install BMW Performance Steering Wheel. It is not very difficult you just need to take your time and pay attention to what you are doing.
Tools:
1. Not very big Flathead Screwdriver
2. 16mm or 5/8 socket with wrench and extensions
3. T25 torx socket ( i think it is T25 but I might be wrong)
4. Very small flathead screwdriver
5. 10mm socket
If you are local ( Bay Area ) I can install it for you
This DIY is for you just to look/read and get an idea on how it can be done. I am not encouraging you to do this installation. I will not be responsible for anything that might happen to you, your vehicle, or anybody who might be helping you, or anything else.
Before you start taking everything apart you need to read PDF Instructions in the Post#3 at the bottom and get familiar with it. Make sure you understand what goes where. After you did that, I would recommend to label supplied BMW harness with A1,A2,A3,A4,A5,A6, and A7 tags. It will be easier to figure out what goes where.
1. Disconnect your Battery and make sure your (-) Negative terminal will not be touching battery
2. Remove lower plastic panels on both sides (passenger/driver). I just have picture of the passenger side
Driver side
3. Read PDF instruction and unplug Blue connector
4. Release the side tabs and pop off the Black/Grey connector that is inside the Blue one.
5. Read PDF installation and remove Blue/Red wire from Pin1 and Red from Pin2. Insert A3 into Pin1 and A4 into Pin2. Now install wires that you removed from Pin1 and Pin2 into Connector E
Pulling out wires from Pin1 and Pin2
Connector E
Wires from Pin1 and Pin2 inserted into Connector E
Wires A3 and A4 inserted into big Black connector into Pin1 and Pin2 and Connector E connecter to A5
6. Now you can install Control Module B and connect A6 to the module
      03-19-2009, 11:25 PM   #2
doba_s
doba_s's Avatar
7. Attach module B to the harness using zip-tie like i did or somewhere else ... it is not the best spot because it make a bit hard to install plastic cover at the end.
8. Install the Black connector into Blue connector and then reinstall Blue connector. I used zip-tie to get all those wires together ...
9. Now you need to remove your Airbag. Make sure you have no power going to your car or it can be very bad and dangerous !
Use medium size flathead screwdriver and insert it into very little openings (one on each side)
Insert screwdriver like this
Not like that
Push on it with the moderate force and pull that side of the airbag gently
Then do the other side
Now you can open Green and Black clips/locks with a flathead screwdriver. Take it easy and don't break them
10. Disconnect the connector from the Coil spring cartridge (Grey/Yellow and Black)
11. Now you can remove your old steering wheel by using 16mm or 5/8 socket
12. Now we need to remove upper/lower steering column trim. Pull the upper part first. Pull it up and do one side at a time. You can use a medium size flathead screwdriver and push it up from the inside, but be very careful and don't punch yourself ... it hurts like a B... trust me
Tape the upper part to the dash
13. Remove the lower part by pressing on the tabs (one on each side)
14. Now remove Coil spring cartridge with T15 torx. Unplug Black small connector on the RT side.
Make sure not to pull the whole assembly out of the column. Very Important. Unclip all the clips and remove just the Coil spring cartridge and nothing else. These are the clips that are holding it on the side, so make sure to unclip them
15. Install the new Coil spring cartridge that came with you new PSW. Don NOT connect the Black connector just yet.
16. Now you need to remove the center console to rout the harness to the steering column. I did it this way but you might decide to do it differently.
17. This is how I routed A7
18. Read PDF instruction and remove wires from the Black connector ( the one I told you not to connect to your new Coil spring cartridge) and insert them into A7 white connector. They are numbered 1-6 and you need to insert them the same way ... #1 from Black connector goes to #1 in A7 White connector and so on ...
Now you CAN connect A7 White connector into you new Coil spring cartridge
19. Zip-tie the wires together and put back steering wheel column trim.
20. Transfer everything from your old wheel to your new PSW and install everything back. Read the PDF file. Connect black connector from the new Coil spring cartridge to the Green connector on you new PSW. The rest is the same. In PDF file it says to connect Black connector to Black but it is actually Green and not Black. Just FIY.
It should look like this
Vedubin01942.50
      03-19-2009, 11:26 PM   #3
doba_s
doba_s's Avatar
21. Since OBDII port doesn't have two needed wire to connect A1 and A2 I decided to use cigaret lighter as the power source. I have something else taped into this power source so don't pay attention to the Red and Black wires. You need to tap A2 Braun wire in to thick Braun wire and A1 Green/Braun into thick Red/Black wire on your cigaret lighter connector.
22. Now you can put everything back together. Connect your battery after you are done with everything, start your car and you should get this
Read the Manual that came with your new PSW to set it the way you like !
I hope this will help
PDF FILE HERE
cloumeM165.50
      03-19-2009, 11:28 PM   #4
urbo73
Drives: 2021 BMW M340i xDrive
What?? I have to remove my clutch pedal?
      03-19-2009, 11:57 PM   #5
doba_s
doba_s's Avatar
no you don't ... I have M-DCT
      03-20-2009, 01:47 AM   #6
FStop7
I like cars
FStop7's Avatar
Vatican City State
329
Drives: M6
You should really use a torque wrench to tighten the bolt the secures the wheel to the column.
      03-20-2009, 01:51 AM   #7
leletyM3
HPF Stg2 640rwhp
11
Drives: HPF M3
Great DIY!!!
      03-20-2009, 01:56 AM   #8
doba_s
doba_s's Avatar
yes you can ... mine is too big and I couldn't use it ... I'll recheck it in a week or so, but there is no way it will get loose ... plus don't remember reading in PDF file anything about using torque wrench to tighten it.
      03-20-2009, 02:24 AM   #9
FStop7
I like cars
FStop7's Avatar
Vatican City State
329
Drives: M6
I've done wheel swaps on a 335i and an E46 M3, in both cases I'm pretty sure it was recommended to torque to 75lb-ft.
The perf wheel looks good, btw. I just wish it had M stitching.
      03-20-2009, 02:37 AM   #10
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Awesome DIY - thanks for taking the time to post.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      03-20-2009, 04:30 AM   #11
Genro757
///M-Flight VP
Genro757's Avatar
Drives: '13 Frozen Red Edition E92 M3
2013 E92 M3  [0.00]
I got my steering wheel installed this weekend...good DIY...but not too technically/mechanically incline so I got BMW here in Bamberg, Germany (Autohaus Sperber) to do the install and programming for me...next project Alcantara my headliner, A pillar and B pillars
      03-20-2009, 09:46 AM   #12
MentholGuy
MentholGuy's Avatar
Drives: 11 E90 M3
Awesome DIY Aleks!!!!
I wish I could join installation, and this makes me can't wait mine get installed!!
How long did it take? I might try to install mine today once I get back to SF tonight..
Good Job!!
      03-20-2009, 10:06 AM   #13
doba_s
doba_s's Avatar
Good Job!!
it took me about 2-3h ... i was trying not to f...k it up haha ...
      03-20-2009, 10:07 AM   #14
doba_s
doba_s's Avatar
this DIY is for you to get an idea ... you don't need to program anything after you install it ... so I am not sure what your BMW center did ...
SaNGRia984.50
      03-20-2009, 10:08 AM   #15
doba_s
doba_s's Avatar
thanks Tom ... I called you yesterday and left you a message ... but disregard it ... everything works good !
      03-20-2009, 10:44 AM   #16
Alex///M
E90 - the Ultimate family hauler
Alex///M's Avatar
Drives: 2008 E90 ///M3
Awesome job and post on this project!
Every time I see a Performance Steering Whell my reaction is first then .
So you're saying that after you installed the wheel all the functions worked? You did not have to take it in to the dealer for programming or coding to your car?
2008 AW E90 M3 - current
2002 TIAG E46 M3 - gone
1991 DiamondSchwartz E30 M3 - gone but not forgotten
      03-20-2009, 10:56 AM   #17
doba_s
doba_s's Avatar
nope ... read PDF file and it says there that you don't need to reprogram it.
      03-20-2009, 11:51 AM   #18
David1
David1's Avatar
Drives: 09 E92 09 X5
I take it the new wheel can only go on one way, a groove in the splines?
      03-20-2009, 12:08 PM   #19
doba_s
doba_s's Avatar
you are right ...
      03-20-2009, 12:32 PM   #20
rav7ks
rav7ks's Avatar
38
Drives: e92 M3
08 M3  [0.00]
I really like the thickness of the OEM steering wheel.
Is the performance steering wheel similar in thickness ?
If it is I'm buying one today lol.
      03-20-2009, 12:37 PM   #21
Big Windy
Big Windy's Avatar
Drives: None
awesome DIY. there is no way i could do that myself...
      03-20-2009, 12:51 PM   #22
Genro757
///M-Flight VP
Genro757's Avatar
2013 E92 M3  [0.00]
Thickness is just the same...and the alcantara feels great...
m3post
