03-01-2009, 06:13 PM | #3 |
Rep 4,726
Bottom left at the end in a sneaky ass spot. Just uploaded so the middle one is still processing and HQ usually takes an hour to become available.
03-01-2009, 06:25 PM | #4 |
Rep 689
wow! were you running meth? Can you get one with the tack and speedo in the camera? Congrats ocha!
2007 M Coupe w/NAV/Premium/Extended Leather, Clearbra, DICE, 4.10 BMW Motorsport Polished LSD, Active Autowerke Gen IV Headers, Supersprint Race Exhaust and X-Pipe, ESS Tuned DME, KWV3 Coilovers, Volk RE30, OEM Strut Tower Brace, Short Antenna, JL AMP, JL 10W7, Valentine V1.
03-01-2009, 06:32 PM | #5 | |
Rep 4,726
Meth was running but I'm still not seeing any obvious timing changes even at levels that are definitely more the could ever be necessary. I'll be dynoing next week and if it's where it should be I'll start some customization. The stock section one is also on the car in these videos in preparation for the "out of the box" dyno. I hope to take some more videos as well, these were just some tests to get the perspective.
03-01-2009, 06:37 PM | #6 |
Rep 689
Cool. You are running headers plus stock section 1... got it. How about x-pipe and cans- are they stock too?
03-01-2009, 06:41 PM | #7 |
Rep 4,726
Cans are stock, X pipe is not, Section 1 will go back on after the dyno (and I correct a few problems with it -_- )
03-01-2009, 06:50 PM | #8 |
Rep 689
What xpipe are you using? Good luck getting the boost problem solved.
03-01-2009, 07:02 PM | #9 | |
Rep 4,726
Heres some other pictures I took the other day as well: ESS supplied clamps vs replacements: What the replacements do: Going clamp crazy to hermetically seal the charge pipes : Coolant sensor location, not visible when the car is together: Blower oil supply and oil pressure tap location: Quick shot of the coilovers ebcause I never took pictures beffore :/ :
03-02-2009, 06:25 PM | #11 |
Rep 4,726
I made a video of the speedo today just for you burt.
And now I will be a complete tease as I am setting it to upload and leaving. 0-60 was between 4-4.5 seconds 0-100 was easily below 10, I'm going by about 65 indicated and 105 indicated to correct for the speedo, and I took the 100 readings RIGHT before the shift (which was @ 100-105 indicated depending on the run). Video is not the most accurate way to take readings though. Crap uploaded before I got out the door.
03-03-2009, 07:31 PM | #15 |
Rep 1,090
worm clamps are never very good for high pressure situtations, if yours fail again you should check out.
http://www.aapsa.com.au/awshop/index...27501639422173 Or go to a local diesel/truck parts shop as they have similar clamps like in the link and usually they cost a tenth of what worm clamps cost from auto shops and are far superior. I miss the sound of my old s/c celica.
135i N54 manual
MR-S with a 2zz swap and mods Sold EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold |
03-03-2009, 07:39 PM | #16 | |
Rep 4,726
03-03-2009, 09:15 PM | #17 |
Rep 1,090
Ah ok yeah thought u double clamped them because they wouldnt hold.
here at auto shops they charge like 10bucks for shitty worm clamp so for me its cheaper to use the better ones. Cant wait for the dyno day :P
135i N54 manual
03-03-2009, 09:25 PM | #18 | |
Rep 4,726
Dyno is tomorrow at 9 am, 430 wheel or bust.
03-03-2009, 09:44 PM | #19 |
Rep 1,709
Nice video ...I can't wait for the dyno results
Live as if you will die tomorrow, but learn as if you will live forever." M.G
03-04-2009, 07:38 AM | #21 |
Rep 689
Ocha- good luck man! Hey, I hope you will dyno with and without meth. I am curious what meth adds. On my old car, it added big torque and hp.
