BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
Mporium BMW
      02-25-2009, 01:07 PM   #1
bim14
BIMMM3R
bim14's Avatar
77
Drives: '14 M5 6MT AW/SO
H&R springs for e92
Hey guys, I was thinking about getting the H&R springs for my e92, as well as some 15mm spacers all around. I just had a few questions about the Springs tho, because I had H&R race on my previous 08 Audi S5, and I had problems with the front 2 springs which caused something with the suspension to break. I really want to lower the car, as well as make sure I don't have problems. H&R springs look good, and are also a good price. If you guys can possibly tell me what the downside is, and what to be careful of with this setup, that would be really helpful. Thanks!
      02-25-2009, 03:55 PM   #2
SV Concepts
SV Concepts's Avatar
Drives: Vorsteiner E60 M5
Location: 1460 White Oaks Rd. Suite F. Campbell, CA 95008
Springs alone are an affordable upgrade that "get the job done" if you want to tighten things up a bit and lower the car visually.
The downside is that they will wear your OEM shocks down faster compared to a paired spring+shock or coilover setup. This is probably what you experienced after extended use.
Ultimately, it's your choice. Some people do springs only and hope for the best as they don't plan to keep the car forever. Others get springs, then get shocks later when they fail. Still others want performance AND looks, and they get coil-overs, springs+shocks (like the Eibach pro kit or H&R cupkit), or just get coils.
It's your choice entirely, depending on your budget, preferences, and what you are trying to accomplish by putting on aftermarket springs!
Hope this helps
      02-25-2009, 04:25 PM   #3
bim14
BIMMM3R
bim14's Avatar
77
I see. I understand the springs are more for short term use, and that's what i'm looking for but the H&R's I had on my S5 wore down my shocks after like 1 month. Is that usual? I just want to make sure, so I don't have to consider paying upwards of 2k to fix the problem or have to get a new car, like I did with the S5
      02-25-2009, 04:31 PM   #4
SlammedR8
SlammedR8's Avatar
Drives: 2019 X5 40i/2020 R8 V10 Spyder
No problems here, Im on H&R for almost a year now!
btw, where are you getting your spacers from? i need some front spacers
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather
2020 Range Rover HSE - Black/Black
2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black
      02-25-2009, 04:47 PM   #5
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
^^ tirerack
      02-25-2009, 10:28 PM   #6
moog55
moog55's Avatar
Drives: E92 M3
H&R springs and H&R spacers for me. had them on for a couple weeks and can't believe i waited this long to do it. should have done this months ago.
      03-02-2009, 09:33 AM   #7
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
do you really have to worry about your shocks and struts failing with a spring upgrade? how likely is this to occur? what is the time frame we are talking?
m3post
