Damn it, halo rings' tip started to melt..what's wrong!!!
06-22-2006, 11:39 AM | #1 |
Rep 1,166
Why is this happening? They melted on both the outer rings causing dimmer than the inner rings. the pics dont show well but in person they are noticeable though.
It was fine before i changed to PMB. Can anyone having PMB check your halo ring tip if they suffer the same? Can i open up the headlight and change the outer rings?
325i Arctics M-Sport, Gray Leather with Alu Trim, ///M DCT Paddleshift, ///M Gear Knob, BBS LM-R 19", Michelin PS2, KW V2, H&R Anti Roll Bars, BMW Performance Air Intake System, 3D Front Lip, ACS Roof Spoiler, OEM Boot Spoiler, Osram 6000K, Brex White Ring, PIAA 6200K HID Fog, PIAA License Plate LED, BMS Powerbox
06-22-2006, 11:42 AM | #2 |
Rep 597
What exactly is happening? Is it that you're rings are just dimmer? Or is something actually wrong? When you install the PMB your rings will become dimmer (at least with the Hyperwhite), so if thats happening its normal.
Graphite E90 325i / Navigation / Premium / Xenon / LUX White Rings / 15% Tint / Blackline Tail Lights
06-22-2006, 11:44 AM | #3 |
Rep 1,166
nope, the tips are started to melt.
06-22-2006, 11:45 AM | #4 |
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
Was that before or after Brex?? I can't imagine how PMB would do that though, I mean PMB doesn't effect heat, its just a lens similar to OEM. The melting is definitely a heat issue.
Will check soon, when I go to install my Lux angel eyes kit.
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
06-22-2006, 11:45 AM | #5 |
Rep 1,166
i think the heat is not properly filtered and passed to the tips causing them to melt?
or perhaps the PMB glass came contact with the tips causing them to melt?
06-22-2006, 11:47 AM | #6 |
Rep 17,767
I believe PMB only serves to filter out the yellowness (filters different parts of the light output spectrum) to arrive at the desired color. The lighting is still the same i.e. via OEM small halogen bulb in the housing...so again that wouldn't be the source of out-of-spec heat/temperature in the housing.
06-22-2006, 11:50 AM | #7 |
Rep 1,166
aiyoo......this is getting me nuts!!!!:mad: :mad:
i dont think there'll be replacement halo rings as i cant see the part no on the OEM part website.
06-22-2006, 11:50 AM | #8 | |
Rep 17,767
06-22-2006, 11:55 AM | #9 |
Rep 16,628
woah!!! i have never seen this. i think the glass got in contact with the halos. i dont think that is possible either. pmb sit on a housing that have some space away from the halos...
06-22-2006, 12:02 PM | #10 |
Rep 1,166
it's the same route to install the the entire unit back into the housing.
why are they touched? what's done cannot be undone, anyway can someone tells me if halos are replaceable? is this the part number? http://www.realoem.com/bmw/showparts...18&hg=63&fg=05 No. Description Supplement Qty From Up To Part Number Price Notes 01 BULB XENON LIGHT WITH IGNITION ELEMENT D1S 2 63217160807 ENDED 01 BULB XENON LIGHT WITH IGNITION ELEMENT 2 63217162862 $217.62 +core 02 LONGLIFE BULB 12V 55W H7 2 63217160781 $14.06 FOR VEHICLES WITH ADAPTIVE HEAD LIGHT S524A=YES 03 ELECTRONICS BOX ALC UNCODED 2 63126934836 $109.93 03 ELECTRONICS BOX ALC UNCODED 2 63126941634 $114.95 04 HEAD LIGHT VERTICAL AIM CONTROL 2 63116938563 +core 05 BULB SOCKET, TURN INDICATOR ZKW 2 63117159570 06 BULB SILVER 12V 21W 2 63217160897 $16.74 07 COVERING CAP, XENON HEADLIGHT, LEFT 1 63117159568 07 COVERING CAP, XENON HEADLIGHT, RIGHT 1 63117159569 08 CONTROL UNIT XENON LIGHT 2 63126948180 $389.48 09 LIGHTING UNIT, LIGHT RINGS 2 63117161444 10 STICK-ON LABEL XENON-LIGHT 2 71237165545 $1.56 11 CLIP NUT M6 2 41357060601 $0.56 12 TORX-BOLT WITH WASHER ISA M6X18 4 41618172499 $1.67 13 ADJUSTING ELEMENT, HEADLIGHT ZKW X 2 63117162083 $7.48 14 ADJUSTING ELEMENT, HEADLIGHT ZKW Y 2 63117171086 $7.48 15 CONNECTION CABLE, XENON ZKW 2 63117175037 $25.39 16 REPAIR CLIP, ZKW, INTERIOR LEFT 1 63117175205 $4.69 16 REPAIR CLIP, ZKW, INTERIOR RIGHT 1 63117175206 $4.69 16 REPAIR CLIP, ZKW, EXTERIOR LEFT 1 63117175207 $4.69 16 REPAIR CLIP, ZKW, EXTERIOR RIGHT 1 63117175208 $4.69
06-22-2006, 12:08 PM | #11 |
Rep 1,166
can someone help to find out if halos are replaceable?
its 1:14am, i'm tired need to zzzzzZZZZ thanks
06-22-2006, 12:10 PM | #12 |
BIG PAPI
10
Rep 189
The only think i can think of could be the glass came loose and the light was going directly to the halo would that be a possibility ? because when i installed mine the glass wasnt the same size as the original so I had to push it in and bent the metal a little so it could fit right but dont take my word i am just guessing here i have never seen this and i am about to check mine right now since i have the same PMB,s !!!
325i sport/ premium/ cold weather package/ IDrive/ Xenon/ H&R springs/ breyton spoiler/ breyton front lip/ silver CF trims/ black line tail lights/5% tints/ and much more to come |
06-22-2006, 12:12 PM | #13 | |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
That's after, he installed the pmbs and was taking it out for the Brex install when he saw that.
Bimmer325, how long have you had the PMB's installed? Danny Quote:
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
06-22-2006, 12:16 PM | #14 | |
Rep 1,166
06-22-2006, 12:18 PM | #15 | |
Rep 1,166
06-22-2006, 12:58 PM | #16 |
Rep 597
Maybe its just something wrong with the rings, and wasn't from the PMB? I doubt that the PMB could damage the rings because its held by that bracket. The only thing you'd have 2 make sure is that the PMB was sitting tightly in the bracket. Was the enclosure lose when you went to install your Brex? There might be the possibility that the enclosure that covers the halogen bulb + the PMB was lose and heat could of got in through there and caused the damage that way.
06-22-2006, 01:09 PM | #17 |
BIG PAPI
10
Rep 189
I am just the only thing it couldve melt it is the bulb right ? but why
06-22-2006, 01:54 PM | #18 |
Rep 715
did you happen to touch the lense or the bulbs during the install??? The oils from your fingers are not good for high temperature bulbs or lenses...
E46 325xi Oxford Green/Sand Leatherette/Myrtle Wood Auto ZCW - Retired
E90 330xi Mystic Blue/Black Leather/Aluminum 6sp Manual ZSP/ZPP/ZCW/CA - Retired F22 M235i Mineral Gray/Red Leather/Aluminum 6sp Manual ZPP/ZTP |
06-22-2006, 02:30 PM | #19 |
Rep 6,563
Hey bimmer325, take out all the mod you did with your light and bring the car into the dealer and tell them you think something is wrong with your halo and the intensity is not as bright. Hopefully, they will replace it for you with out you running around screaming bloody marry and pulling your hair out . Try that my friend.
Edit: I betcha he went to sleep already... |
06-22-2006, 02:34 PM | #20 | |
MAUI BUILT
485
Rep 7,781
Danny
