      11-24-2008, 07:32 PM   #1
robertdelrusso
Drives:
Cool When do you actually use 6th gear?
I ve noticed that unless i'm doing 80 + mph I not only lose power using 6th gear but the gas mileage drops. Wondering if anyone knows when BMW suggests 6th gear. Almost a waste of time so far. rare occasions that I can actually drive anywhere faster than 80.
.........curious
      11-24-2008, 07:37 PM   #2
bman6074
Drives: 14 M235i and 07 Lotus Exige S
mmmmm interesting, i use it on back roads (40+ speeds) and have noticed i get better gas mileage. Def loss of power but im not looking for power, as much as gas savings.
      11-24-2008, 07:50 PM   #3
robertdelrusso
Drives:
just to be clear
Less power and using more gas in 6th gear below 80 mph
      11-24-2008, 08:00 PM   #4
Artmasterx
Artmasterx's Avatar
46
Drives: 2007 BMW 335i
2006 Volvo V70R  [10.00]
2007 BMW 335i  [10.00]
I typically use 6th when cruising on the highway (which I don't do all that often). You definitely lose power, and I can't comment on gas mileage. I would assume that you would get better mpg unless you going up hills or something that would be better suited for using lower gears. But our 128i sees mostly city driving.
Maybe I will do a little test when we drive to NC around Christmas. That should give some extended highway time. I figure to use the electronic mpg and do about 30 min in 5th and 30 min in 6th and see which is better... hopefully with similar flatness of the terrain...
Current: 2007 335i sedan
Alpine White | Sports | Premium | Cold | Comfort Access
FORMERLY: 128i coupe
Alpine White | Sports Package | Black Leather
      11-24-2008, 08:00 PM   #5
bman6074
Yea I understood what you stated. I seem to find the opposite when it comes to the more gas use.
Being on back roads i dont see more than 50 maybe 55 MPH.
      11-24-2008, 08:07 PM   #6
Rachel
Dangerous Curves
Rachel's Avatar
Drives: better than the boys ;)
2011 Ducati 848EVO  [0.00]
2008 135i  [0.00]
I drive on the highway 80 miles a day 5 days a week and always use 6th.. my current gas mileage is 24.2.... Not all that bad? oh, I also have a JB3...
      11-24-2008, 08:49 PM   #7
Dr_Jones
Drives:
Anytime you are thinking about going to 5th...just go to sixth (unless you are in third and thinking about skip shifting to 5th)
torque...it does a body good
Just like Indiana...I love my whip
      11-24-2008, 10:26 PM   #8
Artmasterx
Artmasterx's Avatar
46
You may have missed the fact that he is a 128i owner. So 6th gear is rather weak compared to the 135i. 5th gear is still reasonably peppy on the 128i at highway speeds.
      11-24-2008, 10:27 PM   #9
arrutled
arrutled's Avatar
103
Drives: Olsa
I never use 5th, to each his own though!
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks!
      11-25-2008, 05:50 AM   #10
penny
penny's Avatar
Drives: '08 135i (sold)
^^ I'm with Arrutled. Usually skip 5th myself.
'08 135i.
      11-25-2008, 08:30 AM   #11
and 1
winter mode
and 1's Avatar
Italy
62
Drives: 08 135i, 88 M3
1988 BMW M3  [0.00]
2008 135i  [7.50]
5th gear...so last season
88 M3: BMWCCA J Sport
08 135: because streetcar
      11-25-2008, 08:37 AM   #12
pit1
Drives: F87 M2
I too often skip 5th and jump into 6th as soon as I hit the highway. Still enough power to overtake, only gear down for quick maneuvers...say, around a rock-throwing semi.
      11-25-2008, 09:43 AM   #13
robertdelrusso
Drives:
What is a JB 3?
Cheers
Bob
      11-25-2008, 12:06 PM   #14
arrutled
arrutled's Avatar
103
Drives: Olsa
JuiceBox 3, it is a tune, make car go fast
      11-25-2008, 12:22 PM   #15
amybang
... and Orca too!
amybang's Avatar
Drives: 128i Convertible (AW/CR)
When _don't_ you use 6th gear.
amy!
      11-25-2008, 12:24 PM   #16
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
Interesting, less power understood. Do you have any sources to validate less milage claim for the 128i, robert?
      11-25-2008, 06:14 PM   #17
gio
Drives:
I don't see why you would use more gas in 6th. I use 6th all the time even when I'm not the highway. Anytime I don't need the power and I'm going fast enough that the engine will bog down, I'll shift to 6th to save gas.
Waiting on a 2015 M235
      11-25-2008, 06:42 PM   #18
robertdelrusso
Drives:
Try the momentary mpg on the dash
No the only specifics I have is momentary mpg readout on the dash. I've just noticed that unless I'm doing over 80 the momentary mpg are higher in 5th when the rpms are closer to 3000. it seems like i'm getting better milege and more power, both of which I;m completely happy with. I don't often get to go above 80. haven't really had it out yet , only 2 months old.
My real question is has anyone else noticed this. If not give a shot when you can (if you like) It seems like the car runs more efficiently at a higher rpm. next time your in traffic at say 65-70 mph in 6th downshift to 5th and see where those momentary numbers fall. i don't even have a clue how accurate those number are, but i can read them. I was surprised, pleasantly i might add
.... still curious
Cheers
Bob
1addicts
