07-08-2008, 03:53 PM | #1 |
361
Rep 5,859
Drives: Vorsteiner E60 M5
Location: 1460 White Oaks Rd. Suite F. Campbell, CA 95008
Jlevi SW | Active AutoWerke Performance Products
Hi guys,
OK. So here’s the situation: BMW builds this incredible go-bot called the 135i. But you’re not content with merely “incredible”. You’re chasing “stupendous”. And your friends at Active Autowerke have just the ticket to help you get there. We are proud to announce that we're now carrying Active Autowerke's products for the E87 1 series. Below are some performance products for the 135. Active Autowerke 135i Blow Off Valve Kit Key Features High-efficiency single displacement BOV – takes place of two smaller plastic valves Large opening can handle maximum boost, provide high flow Proven and tested to handle 600+ HP All aluminum venturi design with factory-style throttle clamp CNC machined flange Durable black powder-coated wrinkle finish Illustrated instruction manual & installation guide for easy “Plug ‘n Play” Active Autowerke Processor: BMW 135i Key Features -Proven HP and torque gains measured at the rear wheels -Verified & tested on numerous manual and Steptronic 135i’s -Does not throw "CHECK ENG" faults or create annoying limp conditions -XEDE unit is small, compact and easily attached to the factory wiring harness by any competent technician -Full control over Fuel and Boost parameters and Ignition -System is fully-reversible, leaving no trace -Programmable for future revision upgrades; easily transferable to another 135i -Optional feature: VALET/RACE switch to easily control power & boost with the flip of an in-glovebox switch Performance Specs -Power : 55+ RWHP -Torque : 75+ Ft lbs of Torque -1/4 Mile : 11.8-12.9 sec Active Autowerke 135i Intercooler Kit There’s an old saying: “If you can’t stand the heat, get your intercooler outta the engine!”, Or something like that. Factory intercoolers work well on factory 135i’s, but with added boost comes added heat load. To overcome this, Active Autowerke’s unit stands tall and way up front, catching more air with the help an 88% larger core and a specially designed shroud. Our tests show an air temp drop of close to 30° F in the intake manifold, with a gain of 12 usable rear wheel HP on a Mustang MD250 dynamometer. btw: the ambient temperature in our shop measured a scorching 92°F during the session. This thing works. Please don't hesistate to ask us any questions you may have. Thank you, JleviSW.com |
10-07-2008, 03:21 PM | #2 |
Rep 17,017
We also now have the Active Autowerke Short Shift Kit available for your 135!
11-20-2008, 03:34 PM | #4 |
Rep 692
the 335 short shift kit fits the 135.
08' 135 in much need of some TLC.
But after that... Watch out. AA/Berk/ER/UR/CP-e/Snow/ESS |
