      06-04-2008, 01:39 PM   #1
Mike@BPS
Drives: 2006 M3
UUC Motorwerks Evo3 Ultimate short shifter @ Bimmer Performance Store
Check it out, we've added a short shift kit for the 135i to our online catalog: http://store.bimmerperformancestore....t-Shifter.aspx
NOTE: EVO3 shifters include cartridge bearings and delrin carrier bushings standard.
What makes the UUC Motorwerks short shifter kit so good is the engineering and attention to fine details, many different points that add up to tremendous differences in how the unit works and feels.
We use our own precision-machined pieces, all "massive overkill" designs, race-tested to ensure they easily surpass the rigors of street use.
Upper lever section is height-adjustable for driver comfort and personalized ergonomics. Simply loosen, slide lever to preferred height, and re-tighten.
CNC-machined stainless steel lower section features integral pivot ball and self-adjusting primary pivot bearing. No welds, no plastic.
Special features that make the "Ultimate Short Shifter" unique:
100% CNC-machined 303 stainless steel and 6061-T6 aircraft-grade aluminum construction.
UUC's "massive overkill" design philosophy exemplified. The precision machining of these shifters makes them feel like a solid one-piece design that still absorbs vibration via the rubber inner section. They do not come apart or flex like "clip together" shifters.
Height-adjustable design.
:thumbup:
      06-04-2008, 11:00 PM   #2
FreeBMW.net
Drives: 2008 BMW 135i
Corrected this for you....
NOTE: EVO3 shifters include cartridge bearings and delrin carrier bushings standard. NOT ON THE E82 or E90 SHIUFTERS THEY DO NOT!
:thumbup:
      06-05-2008, 03:18 PM   #3
Mike@BPS
Drives: 2006 M3
not for me, the info is from UUC, so you can correct them if you like
http://www.nexternal.com/uuc/Product593
      01-26-2009, 06:26 PM   #4
stunn2night
no tire gaps
Armenia
Drives: 135
any actuall pics?
      01-26-2009, 07:31 PM   #5
MadMan77
↓↓↓ Ex-Con ↓↓↓
MadMan77's Avatar
Guam
34
Drives: Jet Black '08 135i
According to this thread posted the other day, his kit did NOT come with the delrin carrier bushing. He states this down on post 10.
http://www.1addicts.com/forums/showthread.php?t=224624
Maybe UUC can chime in and see what is going on with this.
      01-26-2009, 09:01 PM   #6
mynew135
assistant to the regional manager
mynew135's Avatar
Drives: 135i
2009 135i  [0.00]
They aren't needed on our model.
      01-27-2009, 08:10 PM   #7
MadMan77
↓↓↓ Ex-Con ↓↓↓
MadMan77's Avatar
Guam
34
I think all of us here would love to know for sure. Maybe BPS can check with UUC or if UUC can chime in.
      01-28-2009, 08:59 AM   #8
mynew135
mynew135's Avatar
Drives: 135i
2009 135i  [0.00]
I installed mine. Mine didn't come with the bushings. Only the aluminum bearing inserts are needed.
      05-04-2009, 07:44 PM   #9
Upgrade+
Good life
Upgrade+'s Avatar
130
Drives: 2008 E90 M3 AW
Are these quality, reliable shifters? Compared to BMW ssk?
      12-09-2009, 06:47 PM   #10
theanhdy
theanhdy's Avatar
93
Drives: 135i
bump for answers to above questions
      12-09-2009, 08:02 PM   #11
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
I purchased one of these kits with the DSSR from back when UUC did the group buy, the 135i version does not have the delrin bushings that go on the end of the carrier.
Here's a pic of everything it came with, stock shifter is on the left :
Prior to picking this up I also had the BMW Perf SSK and in comparison the build quality of the UUC SSK is much more precise and IMO better and more robust. The UUC SSK does take some time to break in before being totally smooth but it's a great improvement over the stock shifter.
Upgrade+ - I see you're in NY, if you're coming out to the meet happening next Sat 12/19 you're more than welcome to check out the shifter in my car.
U WOT M8?
      12-09-2009, 10:11 PM   #12
Justin(OKC)
Justin(OKC)'s Avatar
Drives: 1988 M3, 1990 M3, 1998 M3/4
1998 BMW M3/4  [10.00]
2011 BMW M3 Sedan  [9.28]
1988 BMW M3  [9.40]
1990 BMW M3  [10.00]
2008 BMW 135i - sold  [0.00]
2003 BMW M3 - sold  [0.00]
Were you able to install the DSSR? I haven't put mine in due to clearance issues with the carrier.
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black
1998 BMW M3 - Alpine White/Mulberry
2011 BMW 328i racecar - LeMans Blue/Black
      12-09-2009, 10:49 PM   #13
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
Yes, I installed both the SSK and the DSSR at the same time, they dropped in pretty smoothly. I saw your post in the other thread about the rubbing but so far I don't feel any noticable rubbing when in first or reverse. I'll tear it apart next week to double check and take some pics.
U WOT M8?
1addicts
