03-24-2024, 12:30 PM | #1 |
Rep 21
2017 320i Base iDrive Controller Upgrade
Good afternoon, I’m looking to upgrade the small I drive knob to the nicer one the 328i or 330i comes with. I have a 2017 with ID4, not evo. I notice there are two options that are KCAN2 and was wondering if both work. I have attached photos below. The only difference I notice is the media/radio buttons and the HW version on the sticker on the back.
03-30-2024, 04:14 PM | #2 |
Rep 1,591
I believe the 7-button controllers have two versions. A touch and a non-touch. I installed the touch version going from a 5-button controller. The touch is really useless if using an NBT in my opinion. I would go with the non-touch unless you find the touch for near the same price. If you install the touch, you will also need the touch module ECU for about $30 on EBay. Both will need to be on the KCAN2 bus instead of the KCAN(1) where the 5-button was. Both need coding afterwards.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
jacobmitchellrc0.00 |
03-31-2024, 09:26 AM | #3 | |
Rep 21
03-31-2024, 06:33 PM | #4 | |
Rep 1,591
I would make sure I get a controller that has a manufacturing date after your car’s date so you don’t have to mess around with the Zeitkriterium. It may be plug and play if the hardware version is close to your current controller’s hardware version. In any case, it should work plug and play, but you may have a hidden ECU error code that you could clear up with Esys with CAFD injection.
