      12-19-2007, 07:31 AM   #1
Freno a mano
Drives:
Pics of my black e87 (120d) with 18" Wheels
Sirs,
some pics of my car,
it's a 120d attiva with:
-18" wheels
-fin instead of antenna
-manual gearshift
-16 mm wheel spacers
-Bmw sport suspension
- front camber
-xenon light
Bye
      12-19-2007, 07:35 AM   #2
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
Nice pix Freno!! Welcome to the gang!
      12-19-2007, 07:42 AM   #3
Freno a mano
Drives:
Thanks
      12-19-2007, 08:13 AM   #4
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
Wow! looks good.
Question for you. Those look like e90 wheels. You mention you are using 16mm spacers in order to fit them. Do they rub on the inside if you do not use the spacers? I'm trying to get a feel for which wheels (that I already have) will fit the 1er.
Also, did you add camber plates to get the -2 deg of camber? If so, what kind?
      12-19-2007, 08:30 AM   #5
Freno a mano
Drives:
Originally Posted by larryn View Post
Wow! looks good.
Wheels are N°217 and are specific for the Bmw 1 series with stock offset. With spacers sometimes they rub on the outside.
Referring to camber:
In TIS there is this chapter:
You can reach 2° 10' without camber plates, only adjusting as pics. It's enough! The under steering will disappear and the tyre consumption on external side will decrease.
Regards
      12-19-2007, 04:50 PM   #6
Auto
Sweden
170
Drives: MB CLS 63 AMG
Nice car! Any future mod plans?
      12-20-2007, 01:47 AM   #7
Freno a mano
Drives:
Thanks,
maybe adjustable suspension and some electronic engine management mod.
      12-20-2007, 09:58 AM   #8
BMWeber
Drives: 08 135i
very similar to what I did in my E46 m3 for camber. but in the e46 you swapped left to right and rotate.
      06-25-2008, 06:50 PM   #9
gTa
Sporthatch Lover
Drives:
Regards
Hi, freno a mano,
I'm interested in that "mod", but I'm sure my mechanic won't understand Italian, and nor do I.
So...
Would it be possible to post the complete TIS pictures (a part of it is not visible because you had to scroll down, I see)? And would you want to translate it? To English or French, no difference.
Thanks a lot!!
Gilles
(Belgium)
      06-26-2008, 02:21 AM   #10
Freno a mano
Drives:
Now I've it also in English.
I think that 2° 11' it's a mistake of the machine measurement.
I think that you cannot reach more than 1° 30', however ok to reduce tyre consuption on ext side, and to eliminate understeering.
      06-26-2008, 04:36 AM   #11
gTa
Sporthatch Lover
Drives:
Thanks man!
I don't understand anything of it, but hopefully my mechanic does...
I have a facelift model (MY2007 120d177 3-door), is it still possible to do that mod?
      06-26-2008, 05:04 AM   #12
Freno a mano
Drives:
yes, all 1 series, also the new and the coupe.
It's very easy to do that, the only thing is to apply big strength with an hammer to remove pin 1 and, when you adjust the camber, lift the car in order to have the two wheels not touching the ground so the antiroll bar doesn’t make force.
      06-27-2008, 08:45 AM   #13
gTa
Sporthatch Lover
Drives:
Thanks a lot for the suggestion! I've contacted my BMW dealer. My car was already scheduled for maintenance (30.000km) next thursday, they've added this camber mod to the list! :-)
Cheers,
Gilles
      10-27-2008, 12:58 PM   #14
Shalabert
Drives:
Nice car! Where did you buy that fin antenna?
      10-27-2008, 02:59 PM   #15
Freno a mano
Drives:
it's the e91 one.
It's perfect for the e87!
      10-27-2008, 03:01 PM   #16
Freno a mano
Drives:
-2 degree is not correct.
The maximum reachable with the operation i've indicated is -40'.
Sorry for the mistake.
      10-28-2008, 08:03 AM   #17
Rafael
Noob...!
Rafael's Avatar
Germany
Drives: E87 5dr
Very clean E87...! Like the wheels...!
all information about my 1:
04 E87 116i | SGM | MTECH | BLACKLINES | BBS | H&R | PAINTED KIDNEYS | GPTHUNDERS
      10-29-2008, 12:16 PM   #18
BerkTechnology
BerkTechnology's Avatar
223
Drives: Fast
Gorgeous car with a gorgeous view!
1addicts
