07-17-2007, 07:05 AM | #1 |
Rep 145
Dual Exhaust?
I see that the pitures from the 128i and 135i in europe have a single exhaust. When the car hits the US market, will it be like the 3-series where the 328i has a single exhaust, while the 300hp turbo-charged 335i has dual exhaust? Anyone know?
07-17-2007, 07:10 AM | #2 |
Rep 4,240
If I'm not mistaken the 135i does have dual exhausts. The 535i has a dual exhaust even though the pipes are on one side.
- 04 Honda S2000(gone)
07-17-2007, 07:34 AM | #3 |
Rep 3,742
Neither models (128/135) will have the exhaust outlets from the 335i (one on the left and one on the right). It will remain dual outlets on the left side. BMW AG will not change the exhaust outlets for just the NA market. It would have to be for worldwide sales.
07-17-2007, 10:07 AM | #5 |
Rep 551
Was that ever actaully figured out? The other thread about this I posted in did not have an answer. Has someone actaully see under the car?
07-17-2007, 10:15 AM | #6 |
Rep 4,240
If this car dosent have dual exhausts, its going to have have some issues. I can tell you that much.
07-17-2007, 03:10 PM | #7 | |
Rep 6,759
Which I for one am thankful for. I hope this decision will keep aftermarket exhaust prices reasonable (335 exhausts are from $1200 up) and who knows, maybe it also leaves room under the trunk floor for a spare wheel well. |
07-17-2007, 03:52 PM | #8 | |
Rep 98
If you estimate that half of the wheelbase (52.36 in/134cm) is the length between the cats and the mufflers, the difference between 2 2" pipes and 1 2.75" pipe is almost nothing in terms of volume but the dual pipes would weigh 10lbs more. I for one hope there is only 1 pipe. :wink: |
07-17-2007, 04:19 PM | #9 |
Rep 146
Aesthetics aside, if the HP and torque numbers are the same as the 335, less exhaust plumbing is just less weight, right?
2010 135i Coupe | Black Sapphire Metallic | Red Leather | Poplar Grey Wood Trim | 6MT | Premium pack | M Sport pack | Heated Seats | HK Premium sound | USB | Smartphone integration | Automatic high beams
07-17-2007, 04:34 PM | #10 |
Rep 6,968
07-17-2007, 04:41 PM | #11 |
No longer moderate
325
Rep 4,401
Well there's a pretty good technical reason why dual exhaust on a straight six (with the firing order that this engine uses) is good. It involves scavanging the 'three cylinder' groups exhaust (because of the pulse spread - based on firing order). A truly dual exhaust would be the best - a dual exhaust back to the muffler would be the next to best and a combined exhaust just aft of the turbos would be less than ideal. Keep me honest, but I believe that's what we're talking about.
07-17-2007, 06:13 PM | #12 |
Rep 145
335i (300hp, dual exhaust, dual mufflers) = xxx hp at the wheel.
Wouldn't the 135i (300hp, dual exhaust, single muffler) make less hp at the wheels due to the restrictions of a single muffler? :iono: |
07-17-2007, 06:21 PM | #13 | |
No longer moderate
325
Rep 4,401
To be honest I'm not sure if the effect of a true dual pipe/single muffler would be in HP but its impact may be felt in where the peak HP would be. I read that a 335i customer of Vishnu requested an X-pipe (crossover pipe) for his custom exhaust and that did have some effect on HP - but the X-pipe was much closer to the turbos in that application, IIRC. Again someone needs to keep me honest here. |
07-17-2007, 09:24 PM | #15 |
Rep 908
As far as flow goes, didn't someone post that a single, large diameter pipe actually flows better than 2 smaller ones
Vorsprung durch Gas Geben!! 172 of 740 |
07-17-2007, 10:21 PM | #17 |
Rep 146
OK, I'm not sure what I'm missing here. 335 HP & TQ = 135 HP & TQ, right? Since they're equal, I think it's fair to assert that the exhaust is functionally equivalent as well. I certainly have room for the possibility that the torque curves may be different and/or that the peaks are slightly different. But I suspect they're pretty much the same, ya know?
07-18-2007, 02:53 AM | #18 |
Future Owner
21
Rep 161
I think BMW may be doing a 2-2-1 setup. Both headers may lead into two separate catalytic converters and then into a 2.5 inch Y connection and lead out as a single 3 inch piping. And that will lead into a muffler that will have a dual output on the left side of the car.
07-18-2007, 12:36 PM | #19 |
Rep 6,759
Change the muffler on a turbo car and get what? 3-4BHP maybe? That is easily accounted for via software.
Any significant exhaust improvements on turbocharged cars have to happen at the exhaust manifolds, turbos and downpipes. Even catback exhausts only seem to liberate only around 15RWHP on the 335. In other words, I think it's all a wash between the 335 and 135, exhaust-wise. |
07-18-2007, 05:03 PM | #20 |
Rep 44
My evo IX MR had a 3" all the way from the o2housing, not any farther and it gained at least 20HP, but i did have a downpipe.
If the 135 needs to be single sided, i hope they at least can offer a true duel aftermarket for flow, backpressure is the enemy for a boosted car. but the 135 is also running low boost compared to my evo(21 psi). So im not sure if it would benefit from a High flow cat somwhere during the piping for mid-range. Travis |
