10-26-2022, 04:17 PM | #1 |
Rep 593
Windscreen Washer Top Up
I topped up my windscreen washer bottle today it took about 2 litres, my issue is that it took about 10 minutes, surely that cannot be right. I could only put a 1/4 pint if that in at a time and had to wait for that to disappear then repeat this procedure many many times.
I would appreciate comments as my car goes into my dealer on Tuesday for another fault ( emergency phone not available) dealer suggests a Diagnostic Check, sods law as my G01 ran out of warrentee on 30th September and this fault started on 2nd Oct Grrrrrrrrrrrrrrrrrrrrrrrrrr |
10-27-2022, 03:15 AM | #2 | |
Rep 4,352
Admiral776.00 |
10-27-2022, 03:53 AM | #3 | |
Rep 302
Regarding the emergency phone error, is the message something like "Emergency call system malfunction?" I had this happen on my G01 shortly after I bought it. If it's the same thing, it's due to a fault in the TCU telemetry unit under the shark fin. Water ingress causes an issue with the battery in the unit, resulting in the failure message. This is a known issue. So if that is the cause of the error in your case, ask the dealer to fix and honour under warranty as a goodwill gesture - especially as your warranty expired less than a month ago. |
MyfirstBMW_X3M40i148.50 Admiral776.00 |
10-27-2022, 11:19 AM | #4 | |
Rep 593
10-27-2022, 12:05 PM | #5 |
Rep 1,205
Poor design. The worst bit of the car ... takes forever ... this and the water dripping into the boot when you open it after rain ....
BUT .... these are the only two things I can fault on the car after 3.5 years |
10-27-2022, 03:46 PM | #7 |
Rep 4,352
The tailgate dripping is a pita. Although reducing the opening heigh helped a little.
10-29-2022, 03:39 AM | #8 |
Rep 540
Its caused by the fill pipe from the fill tray to the reservoir having a low point along its length. It can be easily adjusted within about 10 minutes and will fill perfectly afterwards.
You just have to remove the side trim and adjust the pipe once you can see it |
10-29-2022, 10:15 PM | #9 |
Rep 2,114
Are you saying such adjustments "could have" been made at the factory to avoid this dripping? Or, such adjustments come with usual wearing, from normal driving?
ocdx30.00 gofastbmw5100.00 |
10-30-2022, 02:35 AM | #10 |
Rep 540
Yes mine came from the factory with the pipe drooping causing a low point. I adjusted it at least two years ago and it been fine since and fills straight away. The adjustment is only twisting the pipe fitting at one end which lifts the pipe up removing the trap.
10-30-2022, 04:55 AM | #12 |
Rep 4,352
