E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Warning: If you're considering purchasing new wheels/tires for the XI
      12-26-2008, 02:07 AM   #1
dakine
Drives: mineral white e92 M3
Exclamation Warning: If you're considering purchasing new wheels/tires for the XI
You will have problems if the rolling diameter is not the same or off by around 1% or more (the 1% is a recommended tolerance reported by others on this forum).
- you will trip your DTC while driving normal
- you may blow up your transfer case
- you will not be happy
Can an admin make this a sticky at the top?
I saw more threads/questions pop up and want to make sure people who are new to the XI, and wouldn't even think to search for DTC + new wheels/tires unless they encounter a problem (after it's too late), read this prior to purchasing new wheels.
Related posts:
http://www.e90post.com/forums/showthread.php?t=190455
http://www.e90post.com/forums/showthread.php?t=186089
Thanks
      12-28-2008, 05:19 PM   #2
Ph0zenstone
Ph0zenstone's Avatar
325
Drives: 2018 530e X-Drive
seems to be a little exagerated. I've seen many people run wheels past the 1% threshold with no problems. Just like people argue that non staggered can't be used on Xi. Of course I don't recommend it but its not detrimental.
      12-28-2008, 07:07 PM   #3
who's ur daddy?
Drives: Canada's first and only 323xi
Not that I disagree with the advice of matching front and rear diameters, but where does this magical 1% threshold come from other than some members mentioning it? Is it from a BMW engineer or something? If its on the Internet it must be true...
Again, it makes inherent sense to keep the diameters the same to preserve the clutch pack, but I just question what the appropriate threshold is.
      12-28-2008, 11:42 PM   #4
scheherazade
Drives: 09 GTR (& 93' accord!)
I think "1% tops" is another way of saying "as close to 0% as you can".
Granted that if you run staggered wheels, you'll have a hard time getting to 0%... but something "as good as zero (aka some low % like 1%)" will suffice.
-scheherazade
      12-29-2008, 12:07 AM   #5
Nikolas
Drives: 996 TT
Oh dear god don't forget the POLAR BEARS!!!!!!!!!!!!!!!!!!!!!!!!!! This is huge!!!!!!
      12-29-2008, 02:40 AM   #6
JunkStory
Drives: E92 M3, 8V RS3
well that sucks. So what if the diameter shrunk a little bit due to normal tire wear?
      12-29-2008, 07:56 AM   #7
Lassaxi
Lassaxi's Avatar
Drives: April ED - E90 328xi
Short answer: Nowhere. Someone pulled it out of his ass one day, posted it on this forum, and it became a fact.
Long answer: I've been on this forum for more than 2 years. As far as I can tell, this 1% figure came from a group of former Subaru owners who knew that their Subies had a 1% overall rolling diameter tolerance. This is true for Subarus that have viscous center couplings as their AWD system (which would be most manual transmission models, except for the STi). The reason for this is that a viscous coupling is not a particularly heat or stress tolerant form of differential, and the fluid in the coupling can overheat and break down over time if the axles that feed it are constantly spinning at different rates.
Of course, xDrive doesn't use a viscous center coupling. It uses an electromechnical clutch pack, with a heat-resistant clutch. I've never seen anything that provides a specific tolerance for an acceptable difference in rolling diameter between front and rear wheels.
During a trip to my local independent service shop about a year or so ago, I was flipping through the SA's xDrive dynamics manual, and saw a secton on wheels. I remember that the manual said that the xDrive system can tolerate differences in wheel diameter, but I don't remember there being anything specific about how big of a difference was acceptable. I was just sort of flipping through the book though, and I wasn't really looking for an answer to this question, so it may be in there and I may have just missed it. If any SAs out there have their xDrive dynamics training manual, and can lay this issue to rest once and for all, I would welcome it.
EDIT: To clarify, my post should not be read as suggesting that you will have no problems if you put monster truck wheels on the rears and heelys on the fronts. My point is simply that, so far, I have never seen any real basis for the 1% figure.
May 3, '07European Delivery, Redelivered on 6/11/07 - Monaco Blue/Beige, Steptronic, ZPP, ZCW, PDC, iDrive/Navi with RTTI, Logic 7, Xenons, HD Radio
      12-29-2008, 07:56 AM   #8
Lassaxi
Lassaxi's Avatar
Finally! Someone else understands the true issue!
      12-29-2008, 11:39 AM   #9
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Seriously, there are a lot of people running staggered on the XI platform and so far I've only see one person reporting DTC light on but it was because he put on wrong-sized tires. I've been running staggered on both the old and new XI for 1.5 years and neither car has detonated, nor have I been attacked by a Polar Bear yet.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      12-29-2008, 12:26 PM   #10
BMWFanboy
Drives: BMW 335xi Coupe
I'm a little confused. Most of the posts seem to indicate people think a staggered setup is bad with the xi, but you're saying some people argue the opposite?
      12-29-2008, 12:48 PM   #11
who's ur daddy?
This type of response I can appreciate! Thank you.
      12-29-2008, 02:37 PM   #12
dakine
The point of starting this thread was to let current or future XI owners know if you plan to run a staggered setup, make sure the rolling diameter of your wheels are as close to 0% as possible before going out and buying the wrong sized tires/wheels like I did, so for a fact, 245/40/18 rear with 225/40/18 front (on stock staggered rims) is out of tolerance. By the way, what do polar bears have to do with this thread? I may be too old or young to understand the reference... Someone please enlighten me....
      12-29-2008, 02:49 PM   #13
dakine
nevermind about the polar bears reference... I did a search for polar bears and staggered setup and was viciously chased by a polar bear... good thing I'm running a staggered winter setup or I would've been done for.
      12-29-2008, 03:43 PM   #14
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
If that is a true story, then fail by those Subaru owners because the actual Subaru spec is "Within 1/4-inch of tire circumference or about 2/32-inch of each other in remaining tread depth." (using the OEM diameter for an '02 WRX as reference, the acceptable difference in tire diameter is 0.05%)
Also, this spec is true for both viscous center diff WRX and multiplate clutch pack STi
I'm biased because I am a 'former Subaru owner' but if I had a xi I would use that Subaru spec in the absence of an equivalent BMW spec because all AWD systems have an ideal rolling diameter difference of 0% and an overly tight spec is much better than $$$$ differential damage
      12-29-2008, 03:56 PM   #15
undecided
undecided's Avatar
Drives: 08 M5 Sapphire Black
2008 335xi SOLD!!!! ...  [0.00]
2008 M5  [0.00]
Well, stock xi with Sport Pkg and 18 inch wheels is staggered
What if one tire is under or over inflated by let's say 5-10 psi? would that cause a problem?
      12-29-2008, 05:16 PM   #16
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
It would cause a problem with tire wear for sure over the long term.
Would it cause a problem with the differentials? I'm not sure but I suspect it would not because I don't think that difference in pressure will change the tire's diameter very much (driving an AWD with one flat tire (conventional tire with no air) would be a big problem though)
      12-29-2008, 06:27 PM   #17
Lassaxi
Lassaxi's Avatar
I don't know whether it's a true story or not, but it's the best I've been able to discern over the years. If anyone has any more reliable info, I'd love to see it.
I did not know that. My '04 Outback, which has Active AWD (which includes the multiplate clutch pack) apparently does not have that same tolerance. I know this because I got a flat at about 17,000 miles, and needed to have a tire replaced. I asked the dealer about needing to replace all four tires, and was told that the tolerance on the Active AWD system is not as tight as on the viscous center coupling systems. I checked my manual, and sure enough, it only says that the tires need to be of the same make, model, and size, and there is nothing about uneven wear. My friend's WRX manual, in contrast, had a sentence or two about uneven tire wear.
      12-29-2008, 09:21 PM   #18
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
I'm getting info from Sube tolerances from the factory service manual for WRX/STi. I don't have the CD with me so I can't post the pdf. I don't think anyone here will care anyway
      12-29-2008, 11:53 PM   #19
Ph0zenstone
325
if you got the ZSP and 18" wheels, then you got staggered wheels on an Xi from BMW.
      12-30-2008, 12:24 AM   #20
Lassaxi
Lassaxi's Avatar
Did you have the non turbo 2.5L outback? the AWD in that car is part time. the car is FWD and then based on wheel spin in the front wheels a transfer clutch locks up the center diff and powers the rear wheels. that's why the tolerance isn't as tight (especially for the rear wheels) the center diff isn't routing power all the time.
If you had the 3.0 or 2.5 turbo automatic I'm surprised the tolerance isn't tight because the center diff uses a planetary gearset to provide fulltime AWD with rearward torque bias and a transfer clutch to control the front rear torque split. that system (like the viscous coupling type) would care about tolerance because the center diff is routing power all the time
anyyyway.... i am surprised this differential topic comes up so often on this forum and that no one with a xi factory service manual has posted with some tech.
Actually, I have an H6-3.0. But, in '04, the the Variable Torque Distribution system (the full-time electromechanical clutch system you've described) was only available on the "VDC" model Outback. I have an L.L. Bean model, which didn't get the VTD AWD system until '05. That might explain it.
      12-30-2008, 01:07 AM   #21
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
I deleted my post above since it is incorrect speculation on my part. I looked through some of my old Impreza docs and all of the awd systems (viscous (manual trans), clutch (auto) , planetary and clutch (auto w/ VTD)) are full time, but with different default torque splits.
I frankly have no idea why the tread depth specs appear to be more relaxed in your outback. Impreza service has the same spec for all cars
      12-30-2008, 04:48 AM   #22
Lassaxi
Lassaxi's Avatar
Neither do I. EDIT: I was told he story I recited above- that the fluid in the viscous coupling is prone to overheating, which is why it's more sensitive to differences in tread depth. But if you're saying that the technical manual lists the same spec for all Imprezas, I've got nothing.
I suppose the possibility exists that the dealer simply lied to me and got away with it, but I've had one tire with 17,000 fewer miles on my OB wagon for the last 20,000 miles or so, and haven't had any problems with the AWD system. That reminds me- it's nearly time to start looking at new tires!
I also didn't realize that VTD was available on any of the Imprezas. I've also never owned an Impreza, so that probably exlpains that.
e90post
