09-29-2022, 12:19 PM | #1 |
Rep 432
Michelin PS4 AS 245/45 and 275/40 on 718 21" wheels
Started a separate thread for this size. For anyone wanting to ditch the RFT, I believe this is a good solution. These tires sidewalls are 4/10 of an inch higher than the stock size (245/40/21 and 275/35/21). Speedo should register right on instead of 2-3 mph under. Rolling circ. difference for the X Drive is zero. The tires do not fall outside of the wheel width tolerences like some other fittments. Costco has a rebate on top of Michelin's right now so $150 off on 4. The Pilot 4 all season tires are available in this size. There may be others as well.
09-29-2022, 02:01 PM | #3 |
Rep 5,755
Drives: '24 iX50; '23 Audi RS etron GT
Let our resident expert/tech freshxdough chime in...
'24-I20 iX 50; '23 RS etron GT; '23-G26 i4 M50*; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
MyfirstBMW_X3M40i148.50 |
09-29-2022, 02:54 PM | #4 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3560
Rep 4,245
Dunno. Someone be the Guinea pig. Should work.
09-29-2022, 03:22 PM | #5 |
Rep 111
I may well be the guinea pig, but plenty of miles to go yet, but also plenty of time to think this or the 255/295 solution, it'll be one or the other. Im just conscious of how these would affect any warranty/mtce issues if it ever came up.
09-29-2022, 03:25 PM | #6 |
Rep 432
The only difference from stock is the profile which accounts for each tire being 4/5 of an inch taller than stock. That translates to a sidewall 4/10" higher. Width is the same as stock so no clearance issues. Width also does not exceed stock wheel max width. I'll be doing this size next tire change. I'm not crazy about 295s in the rear or the X3M option so for me, this is ideal until stock size becomes available. It might even be better cuz you have a tad more sidewall.
09-29-2022, 03:40 PM | #7 |
Rep 5,755
IDK, I think all the members here running 255/295 speaks volumes and I haven't read anyone suggesting problems.
09-29-2022, 03:49 PM | #8 |
Rep 287
Drives: 2022 X4 m40i
I've got 13.6k on my original Alenza RFT. So I need to make some decisions at some point.
Was debating between 3 options. 1 - Michelin Primacy AS. Pros stock size Cons not speed rated. 2 - Michelin PSAS with the 255/295 setup. Pros done my other forum members. Cons Rear rim size is technically out of fitment 3 - Michelin PSAS with this new size. Pros keeps the original profile of the tire more or less. Cons No one has done it. Let me know what people think. Thanks. |
09-29-2022, 04:36 PM | #9 | |
Rep 432
I also think this size is what BMW specs in their 20" wheels. 245/45/20 and 275/40/20. Last edited by Oldguysrule; 10-01-2022 at 09:27 AM.. |
11-01-2022, 09:00 AM | #10 |
Rep 18
Has anyone tried this set up yet?
Deciding on A/S tires for my 21 inchers is driving me nuts |
11-01-2022, 12:04 PM | #11 | |
Rep 276
I’m debating if I should spend that much or downsize to 20” or 19” if I find some nice rims and get the new tires (supposedly would work out cheaper than just to get the 21” tires and then finding tires for the smaller sizes would be a lot easier and less time consuming than the 21” |
HeatJoey1223.50 |
11-01-2022, 12:29 PM | #12 |
Rep 432
I have not but plan to in spring when I ditch the RFTs. I did speak to two installers telling them what I have currently for wheels and tires and they both stated this size in 21s should create no problems and be almost identical in fitment to stock except for the sligh bump in sidewall height which also puts the speedo right on with actual speed vs 2-3 mph off. I'd suggest you do the same to ease your mind. All the other options in size present at least one if not 2 issues with tire width exceeding rim width specs (meaning slightly pinched sidewalls).
11-01-2022, 02:40 PM | #13 |
Rep 287
I will probably try this setup out or use the stock setup on Michelin Primacy with the lower speed rating. 14.6k miles on my Bridgestones so far.
11-01-2022, 03:10 PM | #14 | |
Rep 432
Pilot Sport 4AS and Crossclimate2 are avail in 245/45/21 and 275/40/21. So are Pirelli Scorpion Zero AS which are run on VW Atlas, Range Rover. Not rated for higher speed tho. Last edited by Oldguysrule; 11-01-2022 at 03:37 PM.. |
OciWan238.00 |
11-01-2022, 04:06 PM | #15 | ||
Rep 287
This is what I was looking at |
11-01-2022, 04:18 PM | #16 |
Rep 432
Sorry, wasn't looking at 40 and 35 apsect ratio. Primacy might be an option in 21" then but it's not a highly rated tire based on Tire Rack and others. Ill be looking to do the Pilot Sport in 45/40 ratios.
11-01-2022, 04:44 PM | #17 | |
Rep 287
But I do like your setup as well. Thanks for coming up with it. |
11-02-2022, 02:10 PM | #18 |
Rep 41
Since all season's are quite hard to find in stock tire size (245/40/21; 275/35/21), does anyone have experience running summer tires all year in "warmer" climates (CA, FL, AZ etc)? Wondering how summer tires perform in winter months and in inclement wether if it can get as low as 40 degrees (but generally never below that)?
11-02-2022, 02:37 PM | #19 | |
Rep 411
P.S. I ran summers on my vehicles the entire time I lived in the Bay Area with zero issues. Carried chains for when I infrequently ventured into higher elevations. Cheers~
Current:
2023 X3 M40i / Dark Graphite Metallic + Tacora Red 2014 Ram Limited / White + Black Leather 2009 335i x-Drive / Jet Black + Saddle Brown Dakota |
11-03-2022, 03:46 AM | #21 | |
Rep 501
Weather is dry, so almost never we have snow, but some times we do and in those conditions xDrive makes a good job. Summer is totally different, we can have several weeks above 35º-40ºC. Before I was running Alenza's (they are rubbish), now I'm running Michelin PS4s in stock tire size (245/40/21; 275/35/21) and man...these tires are amazing in every condition. I have almost 25k kms on them and looks like they can last another 25k, treadwear is impressive too. |
Fentomized7.00 |
