07-11-2022, 01:06 PM | #1 |
Rep 562
Clunk in Front End Low Speeds
Hi all - Wondering if anyone here could chime in on an issue that's come up on my 2020 X3M (non-comp). Recently, when driving at low speeds, generally after the car has sat overnight, I get an audible clunking in the front end that I can ever so slightly also feel in the steering wheel. This seems to happen mostly on uneven pavement, where there are slight dips or imperfections. It does not happen on bigger bumps where the suspension is really being taxed. It seems to go away at speeds over 50mph, but this just may be due to wind noise, etc drowning it out.
It also sometimes happens when taking off from a stop. I have not found a way to straight up reproduce it, like turning the wheel quick side to side, bucking the brakes at a stop, etc. It just takes driving it for a little bit to hear and feel it. It sounds like something is binding or is loose. Mostly it sounds like its coming from the driver side (US), but I think I've heard it from the other side as well. It's really intermittent, but consistent in that it happens on every drive after it's sat overnight. I have an appointment to take it to the dealer (still under warranty) but that's not until 7/25. I have a 400 mile round trip jaunt to go on next week. Just curious if anyone has dealt with this problem. Everything is 100% stock, with the stock 20" wheels, new Pirelli Scorpion All Seasons, 29K on the clock. Thanks in advance for any help... |
07-11-2022, 08:40 PM | #3 |
Rep 480
Drives: 1991 E30 M3
I had this problem on my 2020 Comp. Turns out it was a bad control arm. Replaced under warranty along with a 4 wheel alignment. Went away after repair. Passenger side front.
gfisher99287.00 |
07-11-2022, 09:06 PM | #5 |
Rep 562
Thanks guys.. I appreciate the info. I'll take a look at both the calipers and the control arms and see if it's obvious. I would assume it won't be and probably takes a lot of force to reproduce it from underneath. If it's a control arm, I assume it'd be one of the bushings has gone bad, eh?
07-11-2022, 11:33 PM | #7 |
Rep 562
07-12-2022, 08:17 AM | #8 |
Rep 4,400
Drives: 2022 F97 X3M Comp LCI
check control arm and/or thrust arm bushings.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
gfisher99287.00 |
07-12-2022, 10:05 PM | #9 |
Rep 42
Yeah. Im going to go over everything with a fine tooth comb when im putting my JB4 on this weekend...
07-13-2022, 10:49 AM | #11 |
IG @bmwF9xG80
3816
Rep 7,594
Keep us posted
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
07-20-2022, 07:20 PM | #13 | |
IG @bmwF9xG80
3816
Rep 7,594
Maybe should take it to the track and do some launches
60-130 6.5s X4M
07-20-2022, 09:47 PM | #14 |
Rep 42
Yup. Everything in the suspension is tight. Starting to suspect axle, steering, etc... There was a TSB for an axle that sounds like a similar complaint, however, I do not know if it applies to my VIN yet.
07-21-2022, 01:15 PM | #15 |
IG @bmwF9xG80
3816
Rep 7,594
Have a link to that so I can check my VIN ?
60-130 6.5s X4M
07-21-2022, 06:07 PM | #16 |
Rep 42
I have seen a lot of people talking about the TSB, but have yet to actually find the bulletin itself. I have my SA looking into it and will report back.
07-27-2022, 10:40 PM | #17 | |
IG @bmwF9xG80
3816
Rep 7,594
Keep me posted
60-130 6.5s X4M
07-27-2022, 10:52 PM | #18 |
Rep 562
I'm the OP and mine went into the dealer on Monday. They haven't touched it yet. They said they are backed up 4-5 days. My SA sat and looked thru all the TSBs while I was with him and there was nothing for this for the X3M. He said there was another one that applied to a different vehicle, but didn't say if that was a base X3 or a completely different model.
Hoping to hear something tomorrow or Friday. I will keep the thread updated. |
07-27-2022, 11:04 PM | #19 |
Rep 19
Mine too...
I have a new '22 X3MC. I've noticed the "clunk" at low speeds in reverse, and sometimes forward, with the steering at lock. At first I thought it was rubbing, but it is a different noise and sensation. I just hit 2k miles, and it seems to have corrected itself. I haven't noticed it for a couple of weeks.
07-28-2022, 08:38 AM | #20 |
Rep 158
I have the same issue on my 2021. It seems to be when I first drive in the AM after the car has sat overnight. I have a speedbump in my complex and its when I go over it every morning I feel this "clunk" in the steering wheel.
It is very subtle but weird/annoying Seems like bringing it into the dealer will be a waste of time.... |
07-28-2022, 09:03 AM | #21 |
Rep 192
I have experienced the same issue. in my case, I have swapped to ceramic brake pads and realized the pads needed some more lube on the backs of them, odd..yet that was the issue. it was surely coming from the calipers.
Donington grey F97 X3M Competition | Sakhir Orange | H&R Springs | M performance Steering wheel | OEM Carbon paddle shifters | Spacers
FSociety3815.50 |
07-28-2022, 09:51 AM | #22 |
Rep 562
So your noise started after you switched to new ceramic pads?
