E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > UUC sway bar noise issue?
      12-06-2008, 05:59 AM   #1
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
481
Drives: SMB F83
I had the UUC sway bars installed couple weeks ago along with the KW V3 coil overs. I noticed that there is an annoying screeching noise coming from the front suspension. I brought it back to the shop that did the install for some other work. They also looked for the source of the noise. It seems like it is coming from the sway bar moving around in the PUR bushings. Any one have a similar problem? Thanks~
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      12-06-2008, 11:09 AM   #2
Orb
Drives: 335
A few have fixed is with H&R bushings since they are the same size.
Orb
      12-06-2008, 01:28 PM   #3
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Thanks~ I'll ask my shop to look into it. The noise is really annoying during low speed city driving going over bumps.
      12-12-2008, 10:30 AM   #4
longodj
longodj's Avatar
Drives: 135i
2007 335xi  [0.00]
1974 VW Beetle  [0.00]
Grease Kev....shit tons of grease
      12-12-2008, 10:37 AM   #5
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Is copper grease ok?
      12-12-2008, 04:31 PM   #6
Nikolas
Drives: 996 TT
They probably didn't put enough silicone around the bushing. That is an easy fix. I assume they are urethane.
      12-12-2008, 07:07 PM   #7
cyphr
cyphr's Avatar
69
Drives: 08 335xi coupe
Yeah, just grease them liberally. I've had really good results with amsoil's marine grease (purple) if you're looking for specifics. Great durability, holds up to the elements, and no noise.
      12-12-2008, 07:13 PM   #8
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Thanks~ I'll let my tech know.
      12-12-2008, 07:37 PM   #9
cyphr
cyphr's Avatar
69
Just another heads up. Most shops will use lithium grease which has great lubrication properties but may have to reapplied after a harsh winter. If the sound won't bother you till the end of next week (I'll be back then), I can give you a tube of the grease I used. Otherwise, look for something with durability, it's a huge mess to reapply that gunk.
e90post
