dtc engages alot after changing to winter tires?
12-02-2008, 04:53 PM | #1 |
Rep 192
wasnt sure if this is normal or not, which is why i'm asking. i got my winter tires put on today and went for a test drive on dry roads. the temperature was just below freezing if that makes a difference. to sum things up, the car seems to pull a bit at low speeds, and when going around 40-50 mph, i push the throttle about 1/2 way down in 4th gear, the dtc light kicks on and off a bunch of times and the car behaves similarly to when you're going around a high speed turn and you can feel the car shift throttle around... i thought maybe the dealer didn't fill up the tires, but the tpms didn't alarm. anyone experience this?
12-02-2008, 08:10 PM | #3 |
My God is a faithful God
10
Rep 126
I got my winter tires on a few weeks ago, and I haven't had any problems. We had a few inches of snow two days ago, and I took the car for a drive and the car didn't have any changes or lights on. Maybe you should take it to the shop.
Previous vehicles 2011 BMW M3, 2016 BMW 550i M Sport, currently driving a 2016 BMW M3 |
12-02-2008, 08:19 PM | #4 |
Rep 24,685
Drives: '04 330i ZHP
ya i'd at least give your dealership a call and talk it over with a service advisor to see what it could be.
i'd be 1 thing if you were in 5 inches of mushy snow but on dry pavement it almost sounds like you're driving on slicks |
12-03-2008, 12:10 PM | #5 |
Rep 192
i talked to the service guy at the dealer and he said it's because i put on a different tire size in the rear that it's behaving like that. i say that's crap. The tires i have on there now are the pirelli 240 sottozero runflats 245/40/18 on stock rims. i'm going to go and measure the tire pressure right now, i didn't do it before because i refused to believe the tires are under inflated after the dealer put the winter on the rims.
12-03-2008, 02:11 PM | #6 |
Rep 192
i checked the tire pressure and it was low! the tire called for 50 psi max, and the tires were at about 30. i pumped them up, reset the tpms, and went for a test drive... while on the freeway, at around 60 mph, the car started to flash the dtc majorly. and the car started going limp... actually started slowing me down to about 45 mph, so i went to do a downshift and when i pressed the clutch and put the car into 4th, i immediately felt the car come out of limp mode and then go right back into it with the yellow light flashing. i almost thought i had to pull to the side of the freeway because the car kept slowing down and kind of shaking. could the change in tire size actually cause the car to go all limp like that and the car seems very unstable like it's trying to auto correct itself out and into going straight.... freaking wierd. the thing i dont get is what could they have messed up with a tire change? or are the difference in tires so drastic it would cause the dtc to flip out.... anyone got anything?
12-03-2008, 02:17 PM | #7 |
Rep 192
forgot to mention i kept the default size on the fronts and bought the 245/40/18s for the rear because at the time tire rack was out of the 255s and i did a premature buy-ation because the temperatures started getting colder.
12-03-2008, 02:37 PM | #8 |
Rep 261
If I understand the sizes you have on your car correctly (F=225/40/18, R=245/40/18), then your service rep is absolutely correct, and you need to change those wheels out ASAP. Damage to transfer case due to wrong tire size is not covered under warranty (and shouldn't be)
If you go here: http://www.e90post.com/forums/forumdisplay.php?f=12 you can figure out the rolling circumference of the tires you're using. If the front VS rear is off by more than 1% (yours is off by about 2.5%!!) you risk damaging your transfer case, and yes, DTC will be going nuts. BTW, just b/c tire says max pressure is 50 PSI does not mean that's the correct pressure. The correct pressure is listed in the door-jamb of driver side, I believe. For 328xi it's F=34psi and R=36psi. not sure about 335xi. When in doubt, consult the manual... Last edited by nomile; 12-03-2008 at 02:54 PM.. Reason: Used wrong size of front tire in example... |
12-03-2008, 03:59 PM | #9 |
Rep 192
dammit... if that's the case, i'm sol. I cant seem to find the sottozero 240 in a 255 runflat. i should've just went with a set of new winter tires and rims. anyone know where they have available a 255/35/18 rft pirelli sottozero 240 in stock? or if worse comes to worse, is there a problem running runflats in the front and non rfts in the rear?
12-03-2008, 05:25 PM | #10 |
Rep 192
hey nomile, i forgot to thank you for your info... thanks. Where did you come across the info for the wheel differences? Also, would it be better to disable the DTC until i get the correct tire size? Thanks
12-03-2008, 05:49 PM | #11 |
Rep 24,685
http://www.wheelsnext.com/tires/Pire...(Runflat).html
tirerack also has um in that size just not in RFT. |
12-03-2008, 05:54 PM | #12 |
Rep 192
thanks UdubBadger, they got nice wheels, but the prices are kind of steep compared to tire rack... i guess it all boils down to how bad you want it.
12-03-2008, 06:58 PM | #13 |
Rep 95
As nomile stated, very very bad tire size combo on there. Besides the car being un-drivable, you're going to damage your transfer case. The rolling diameters of the front and rears much match very closely on an all wheel drive vehicle. Turning off the DTC will make the light go out but the car still isn't going to work. Put some 255/35/18's on the rear ASAP. Don't drive the car like that.
2008 BMW 328xi -- Titanium Silver/Black 2008 JEEP Wrangler Unlimited Sahara -- Black/Gray 2004 VW R32 -- Reflex Silver/Black 2001 VW Passat 4Motion -- Blue/Black 1972 VW Super Beetle Convertible -- Yellow/Black |
12-04-2008, 09:56 AM | #14 | |
Rep 261
I've been looking to get some summer tires for my 328xi and in looking around the XI forum and wheel forum, the "staggered wheel on xi" question has shown up again and again. Staggered is fine, IFF rolling diams are within a fraction of a percent. There's a post somewhere on e90post.com where someone continued to drive his car even though DTC kept coming on, and blew up transfer case, and many other such examples - peruse and you'll find them, I'm sure. Look for questions about staggered wheels. Now get the new tires ASAP!! |
12-04-2008, 12:38 PM | #15 |
Rep 192
Thanks for all the help guys... good thing i got the scubi to hold me over until i decide what i'm going to do. I only drove it once and for a short distance. I put the car in the garage because it felt wierd driving. Then I jumped on the forums here, trying to figure out what's going on. This forum is really great.
12-04-2008, 03:08 PM | #16 |
Rep 261
02-04-2009, 11:19 PM | #17 |
Rep 13
I was just about to make that same mistake. let me see if i get it, basically o xi both front and back wheels need to have the same diameter and cant be too big. so For me to put the other OEM wheels I should change the tire. put a smaller one? Thats the solution, or we simply cant use the other wheels?
02-09-2009, 01:09 PM | #18 |
Chief Executive
300
Rep 2,886
Drives: 2008 335xi 6spd Coupe
When temps are above 35, my snows slip a bit more, and my dtc will occasionally kick in.
02-09-2009, 09:53 PM | #19 |
Rep 610
i had this exact issue when i put my winter wheels on. I put on 225/45-17 in front and 255/40-17 in the rear. The tires I bought had Identical outer diameters (according to spec), but the difference in width caused a different rolling radius (front tires compressed more). I swapped the rears out for identical 225/45-17 tires and the problem disappeared.
My stock tires (staggered 18s) are 0.1" larger OD in the front than in the back, but because they are narrower, when the tires are loaded, all four have similar rolling radii. Be very careful when selecting staggered tires, even though the tire spec says that the OD is the same, once it is loaded, it may not be. |
