11-02-2021, 06:54 AM | #1 |
Cheapskate
4455
Rep 4,995
How much Torque can the B58 Transmission Handle?
New video is up to discuss the limits of the ZF8 and 6MT, as well as options to upgrade as you increase your car's power. Hope this helps
11-03-2021, 06:55 AM | #2 |
Rep 595
Great video as usual Kern!
What would be the next level clutch recommendation from you after the 550i clutch? Said differently, what would be the next stronger clutch after 550i that still has same road manners? |
11-03-2021, 01:18 PM | #3 |
Rep 1,456
Probably a stage 3 or stage 3+ clutch that can reuse the factory DMFW. Single flywheel will lose some daily drivability and introduce clutch chatter (so I've heard).
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 |
11-04-2021, 08:38 AM | #4 |
Cheapskate
4455
Rep 4,995
Yeah the main reason the OEM clutch has good driveability is the DMFW. Most Clutch companies don't make upgrades compatible with it.
