09-21-2021, 04:55 PM | #1 |
Rep 764
Turbo blankets for F90 m5?
Assuming they are similar to F10's, wondering if anyone has them on their F90's and if they have seen any difference.
https://funkmotorsport.com/product/f...turbo-blanket/ |
09-21-2021, 09:56 PM | #2 |
Rep 1,607
Drives: 2020 M8 Comp First Edition
Following
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
09-22-2021, 08:46 PM | #4 |
Rep 608
G80 Comp, Hcp custom e50, 9.69@141
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
09-22-2021, 09:13 PM | #6 |
Rep 1,607
So logic of this item is to keep engine bay cool by restricting the heat inside the turbo. Restricted heat helps the turbo and not cause any issue.
Now Are there any pics of similar item on our motor or if someone can elaborate how would it go on the turbo? Thx
GT
09-22-2021, 09:27 PM | #7 | |
Rep 764
Here are f10 pic's https://f10.m5post.com/forums/showthread.php?t=1580001 Last edited by brad65ford; 09-22-2021 at 09:33 PM.. |
09-22-2021, 09:57 PM | #8 | |
Rep 548
Mcc420 does 144mph in the quarter so whatever he is doing, is working |
09-23-2021, 05:52 AM | #9 | ||
Rep 608
09-23-2021, 06:55 AM | #10 |
Rep 10,650
09-23-2021, 09:54 AM | #12 |
Rep 243
Im interested
2020 M8 SMB full boltons and tune
2022 CT5-V Blackwing 2019 GT3RS full headers exhaust and tune 2022 Cayenne Turbo coupe Catless/ Tune 2022 Huracan STO |
09-23-2021, 01:03 PM | #13 |
Rep 1,607
So ptp has 10% off available but I just want to be sure if in the end if it's worth it overall and also if installation is straight forward.
GT
09-23-2021, 06:58 PM | #14 |
Rep 107
I'm very interested in trying one of these options. The engine bay gets and stays so hot on this car. I've run turbo blankets on past cars and currently have one on my big single turbo 2JZGTE swapped IS300 and it made a big difference with under hood temps along with whatever benefit it has for the turbo.
09-23-2021, 08:18 PM | #15 |
Rep 1,607
I guess Ill pull the trigger and order one. I assume it's just one big blanket for our turbos vs 2. Thx
GT
09-23-2021, 09:50 PM | #16 |
Rep 764
09-25-2021, 12:07 AM | #17 |
Rep 3,205
The ptp goes over the oem metal heat shield that sits above the primary cats. I've had it on my s63 motors since my e70. On the f90 it fits, but not perfectly. Slight changes on the tu4, but still worth it imo.
The first option posted goes over the turbos themselves so in theory you can rock all three. I have a pair of the turbo ones I'm going to attempt to put on soon. I got the ones Troy recommended. Can't recall if the op ones posted are the same or not. Hope this helps. |
05-15-2023, 06:24 PM | #18 | |
IG: @M5RCY_
365
Rep 317
Could you share some insight here and any pics you may have. Please and thank you in advance.
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
06-02-2023, 07:01 AM | #21 |
Rep 10,650
Ceramic coating is a good option, but most people are not interested in removing their turbos, diasssembling them, and sending out the turbine housings. Far, far, far more work than installing turbine covers or the big blanket that lays over the top of the turbines and cats.
This is really for heat management in the engine bay, such as to protect the coolant tank. The efficiency gains on these tiny turbos from whatever heat retention mechanism will have a minuscule effect on performance. If you had a single giant turbo instead, there would be some gains. I installed GT22 turbine covers and put reflective heat tape under the upper heat shield and on the bottoms of the coolant tanks. I also wrapped my downpipes. If money was no object, I would rebuild the motor with stronger rods, buy a supersprint turbo manifold and have it ceramic coated, buy upgraded turbos and have them ceramic coated, and ceramic coat my downpipes. Maybe I will do that at some point. |
916_M5365.00 |
