07-02-2021, 10:21 AM | #1 |
Rep 919
Does compression change in different modes?
I have a manual, and maybe I'm imagining this, but when I lift off the gas in Sport, it seems to hold the car back more than it does in comfort.
Neither has any gas going into it, so am I experiencing timing changes? I've got some steep hills around me and in comfort, just seem to roll freely, without anything holding me back in 2nd, 1st makes my car cry at the bottom.
07-02-2021, 01:49 PM | #3 |
Rep 919
I'm not sure I quite understand that. I have a manual with fixed gear ratios...so in either sport or comfort, if I'm going the same speed in the same gear, aren't the rpms going to be the same?
07-02-2021, 02:08 PM | #4 |
Rep 7,620
It might be in your head. The primary different in mapping between sport/comfort that would be relevant under decel (0% pedal position) is WGDC. In sport WGDC starts at 100% and it opens as you reach boost target but in comfort it starts lower and increases as needed to reach boost target (to make it more responsive in sport). That could in theory increase back pressure and therefore increase engine braking but seems like it would be negligible.
dmaxdmax417.00 |
07-07-2021, 05:35 PM | #6 |
Sarcasm while you wait.
149
Rep 118
Drives: 2017 F33 B58 xDrive
How exactly did you thing compression could change? It takes an adjustable connecting rod that I believe only Nissan has tried in the Infinity QX50.
tex26702421.50 |
07-07-2021, 06:49 PM | #7 |
Rep 4,903
In an auto, they lock/unlock the torque converter and it goes into "sail mode". Not sure what that entails, but it might be with the valvetronic to reduce backpressure.
No clue if the 6MT does the same, but perhaps (valvetronic wise). |
07-07-2021, 07:04 PM | #8 | |
Rep 919
I feel less engine braking in this car than I did with my e46...probably because it also wants to go much faster than the e46.
07-08-2021, 05:53 PM | #9 | |
Rep 7,620
07-09-2021, 10:28 PM | #10 | ||
Rep 1,199
07-10-2021, 02:48 PM | #11 |
Rep 7,620
