01-21-2021, 10:26 AM | #1 |
Rep 3,022
Drives: 2019 M2 Competition
Its always fun to share out your build journey and I wanted to do the same with my new love, this incredible F87 M2C, as I did on my much loved F32.
I will be updating this thread as I move through the build on this truly incredible machine, so bear with me as it gets updated over time. My F32 build took several years, and while I suspect this one will be faster, it will still be a labor of love over time. As the build progresses, I will share updates, timing and DIY videos throughout the build! I am also planning on getting a good baseline dyno run here soon (2/20 probably) so I can measure progress moving forward from stock! I know as of right now, there isn't a lot to show here but it will grow. [3/22 update] Caught up all of the build items, plus just chuckling at the original post info.. 'isn't a lot to show here..', well THAT has changed! The build is come along significantly faster than I could have imagined, and is starting to get into final stages places like exotic fueling, port injection or meth really as last pieces. There is also the potential of a suspension change as well, but that is in the future along with (no doubt) much bigger rear tires due to HP increases. [5/22 update] TONS of updates coming to address the fueling shortcomings on E85, then subsequent updates to the tune with Cary Jordan. So many things coming I realized my build sheet here was out of date, so getting caught up! [8/22 update] MASSIVE fueling upgrades throughout the whole system, end to end. Precision Raceworks stage 3 LPFP, new PR fuel lines leading to Dorch HPFP lift kit AND PR port injection kit with Motiv controller. This includes new EU5 injectors to top it off, with a fresh set of plugs just to make sure. Fundamental changes along with a new 2 map setup from Cary Jordan, that will be dialed in soon, with Map1 flex fuel daily driving and map 2, the full E85 PI 'send it' map. All this is is documented and will be new videos over the next weeks/months, but man its been a crazy month! [6/23 update] It's official and the next step in amazing journey. Lillith is sold to a fantastic forum member here. Great guy and absolutely worthy next owner of this legendary car. What a journey it has been.. Name: Lillith Birthday: 1/29/19 Leipzig, Germany Bought: 1/21 (second owner) Dyno stats: Stock: 3/11/2021 - 22rpd in Renton RWP averaged SAE corrected - 403 Torque average SAE corrected - 466.85 modded: 3/11/2021 - 22rpd in Renton Stock CS Map - Side note, the power curve is RADICALLY different, and is +70rwp at 6500rpm RWP averaged SAE corrected - 422.1 Torque average SAE corrected - 473.43 3/30/2021 - 22rpd in Renton Stock CS Map - Active Autowerke catless DP and performance midpipe RWP averaged SAE corrected - 461.4 (+39.3 over CS) Torque average SAE corrected - 444.92 (-28.51) (guessing heatsoak) 3/30/2021 - 22rpd in Renton OTS S2 BM3 Map - Active Autowerke catless DP and performance midpipe RWP averaged SAE corrected - 503.7 (+42.3 over CS catless, +107.7 over stock) Torque average SAE corrected - 548.62 (+103.7 over CS catless, +87.22 over stock) 6/21/21 - Custom S2 tune from Cary Jordan, on a Dynojet at CarbConn in Kirkland WA RWP averaged STD corrected - 500.28 Torque average STD corrected - 511.37 Really stable smooth runs, ZERO issues like I had with the OTS S2 tune. 3/17/22 - Custom S2 Mosselman turbos with pump/flex fuel tune from Cary Jordan, on a Dynojet at CarbConn in Kirkland WA 92 octane RWP averaged STD corrected - 588.12 92 octane Torque average STD corrected - 484.09* (serious tire slip throughout) E85 RWP averaged STD corrected - 632.35 E85 Torque average STD corrected - 573.78 (still tire slip) 8/16/22 - Custom S2 Mosselman turbos with pump/flex fuel tune from Cary Jordan, on a hub dyno at DUDMD Auburn Wa Map 1 - full DI setup, upgraded LPFP, fuel lines, E52 injectors, Dorch HPFP 92 octane RWP averaged STD corrected - 670 92 octane Torque average STD corrected - 620 Map 2 - Full E85, port injection with all other upgrades E85 RWP averaged STD corrected - 745 E85 Torque average STD corrected - 620 Factory options: Black Sapphire Metallic Black Dakota leather with blue stitching Executive Package iStep Version to date: F020-18-11-551 - November 2018 Coding changes: Bimmercode changes for mirror fold, seat changes and HALO brightness. Interior modifications: //M Performance stainless steel pedals - dealer installed //M Performance floor mats - dealer installed BMW LED door projectors - dealer installed Carbon Fiber seat backs from Kies Motorsports - 2/21 Blue M1/M2 buttons from Kies Motorsports - 1/21 Gates Innovations Key Fob upgrade - 2/21 Bimmertech Premium Amplifier - 2/21 Bimmertech Alpha One speakers including subs - 2/21 G2X/G8X rearview mirror retrofit - 3/21 H3R Performance seat mounted fire extinguisher- 8/21 Stage 1 Soundskins speaker rings - 10/21 Stage 2 Soundskins vapor barrier insulation - 11/21 Stage 3 Soundskins full cabin insulation - 11/21 P3 Gauges from Kies Motorsports - 12/21 Mashimarho custom steering wheel - 6/22 Faserschmiede Raw Carbon steering wheel trim - 7/22 Soundskins trunk insulation - 11/22 Exterior modifications: BMW Wheel locks - dealer installed BMW floating hub caps - dealer installed Carbon Fiber rear spoiler - dealer installed //M Performance side sill decals - dealer installed IND color matched reflectors - 1/21 LED backup bulbs - 1/21 Zunsport front bumper screen kit - 5/21 Turner Motorsports front skid plate - 6/21 CT Carbon //M Performance M2 CS carbon fiber winglets - 3/22 CT Carbon //M Performance M2 CS carbon fiber spoiler - 3/22 CT Carbon //M Performance M2 CS carbon fiber rear diffuser - 3/22 CT Carbon //M Performance M2 CS carbon fiber front lip - 3/22 Sliplo skid pads - front lip - 5/22 Full exterior PPF stealth wrap - 6/22 Blackline caps (gas cap, engine caps) - 8/22 Downstar dress bolts engine bay - 8/22 Phase 2 Motortrend engine bay hose clamps- 11/22 Kies Motorsports 10mm front and 12mm rear spacers - 11/22 Mashimarho ICEDriver lemon yellow DRLs - 1/23 Blackline oil filter cap - 3/23 Kies Motorsports GTS/CS style vented hood - 6/23 Performance modifications: Mosselman oil thermostat - 1/21 BMS clutch stop - 1/21 RK Autowerks pinned crank hub - 2/21 ProTuning Freaks BM3 - S2 custom tune by Cary Jordan - 3/21 Active Autowerke single midpipe with resonated AB pipes - 3/21 Active Autowerke catless downpipes - 3/21 BMC air filters and charcoil filter removal - 3/21 CSF charge cooler and heat exchanger - 4/21 NGK plugs gapped to 0.022 (at 20k miles) - 4/21 Mishimoto oil cooler upgrade - 6/21 Funk Motorsport turbo blankets - 6/21 3D printed custom airbox snorkels - 6/21 Mishimoto oil catch can - 8/21 BMW OEM M2 CSR front sway bar - 9/21 Active Autowerke Equal Length midpipe - 12/21 Kies Motorsports charge and J pipes - 12/21 Funk Motorsport intake insulation wrap - 12/21 Funk Motorsport downpipe blankets - 1/22 Active Autowerke valved axle back exhaust - 1/22 ProTuning Freaks flex fuel sensor - 2/22 Mosselman stage 2 MSL 65-80 big turbos - 3/22 MST turbo inlet pipes - 5/22 Precision Raceworks stage 3 LPFP - 6/2022 Turner 6MT shifter bushing - 7/22 Dorch stage 3 high pressure lift kit- 7/22 BMW OEM S65 EU5 injectors - 7/22 Precision Raceworks port injection system - 7/22 Precision Raceworks fuel line upgrade - 7/22 Motiv Reflex Plus controller - 7/22
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread Last edited by BMW DIY Guy; 06-22-2023 at 09:06 AM.. |
01-21-2021, 06:39 PM | #2 | |
Rep 1,286
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
BMW DIY Guy3075.00 |
01-21-2021, 06:45 PM | #3 |
Rep 6,939
Drives: 2018 M2 AW DCT
I saw an M Performance sticker in the pictures. What options are already installed by the previous owner?
BMWCCA member Puget Sound Chapter
01-21-2021, 06:47 PM | #4 |
Rep 3,022
Its a start..
Dealership on the day I bought her, and then the obligatory 'holy crap she is my garage' shot later in the evening!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
01-21-2021, 06:51 PM | #5 |
Rep 3,022
Oh good point.. I should add those to the build sheet since they are extra per se. I will pull the list so I get them right and not off the top of my head. 8)
01-21-2021, 07:45 PM | #6 |
Rep 3,022
First official "mod".. lol
01-21-2021, 08:31 PM | #7 |
Rep 6,939
I used the BMWCCA window sticker. I have the grill badge but I am not a fan of it. It sits in my desk draw.
BMW DIY Guy3075.00 ///M TOWN16568.00 |
01-21-2021, 08:47 PM | #8 |
Rep 3,022
updated with all of the relevant options. 8)
DanG10664.50 |
01-23-2021, 09:52 PM | #9 |
Rep 659
Stefan,
Are you going to do the Crank hub fix?? Thanks! |
01-23-2021, 09:55 PM | #10 |
Rep 3,022
Most definitely.. will have a video series on it, and see it as critical work even before any RWP work
01-23-2021, 10:03 PM | #11 |
Rep 659
Stefan,
I'll text you about this Crank Hub fix.. Great to hear you are doing this Crank Hub fix.. |
01-24-2021, 09:22 AM | #12 |
Rep 3,022
Sounds like a very RARE thing at bone stock, but would like to avoid it regardless. The car will no doubt be tuned some day.. but building towards that to be ready.
M3nmotion18390.00 BarrettDB95.50 |
01-27-2021, 11:00 AM | #13 |
Rep 3,022
Installed the BMS clutch stop, and candidly, its AMAZING! Probably the best $10 I have spent on my BMW in a long long time. Really changes clutch feel and engagement, and 1st gear is direct engagement especially now, which is really nice with less slop at the bottom of the pedal.
BMW video is pending and in work. LED backup bulbs installed, simple work and easy and install video is coming there too soon.
01-27-2021, 03:45 PM | #14 |
Rep 3,022
The first DIY is done!! Yeah super simple, but always want to share as much knowledge as possible, and so so so many more to come!
01-29-2021, 07:56 PM | #15 |
Rep 5
cool video thanks! Super easy to follow along. Keep up the great work.
01-29-2021, 08:30 PM | #16 |
Rep 3,022
lots and lots more coming.. 8)
01-29-2021, 08:54 PM | #17 |
Remove Before Flight
6822
Rep 1,611
Thanks for the video-- on the links below, which bulb was needed for the M2C?
01-29-2021, 08:57 PM | #18 |
Rep 3,022
Assuming you are LCI, most likely the wedge/blade style I used. Link is in the video description
flybigjet6822.00 |
02-03-2021, 10:39 AM | #19 |
Rep 3,022
Ok yall, next DIY video is up today! Simple and easy DIY but I dont know about you, but this makes a massive difference! The engagement especially coming out of 1st gear is night and DAY different. Sincerely probably the best $10 you will ever spend for the manual clutch crowd.
M3nmotion18390.00 TT M2C7.50 |
02-06-2021, 10:57 PM | #20 |
Rep 3,022
Fun day at BMW Seattle using Lillith on one side and a new M2 CS on the other for comparison.
02-07-2021, 03:55 PM | #21 |
Rep 3,022
All right yall! The latest video is up though not specifically the M2 per se, but the key fob modification from Gates Innovations! I am really impressed by this change, and feels absolutely worth it!
IND-Distribution9586.50 M3nmotion18390.00 |
02-10-2021, 09:44 AM | #22 |
Rep 3,022
All right!! Next up, changing out the (imho) awful orange reflectors to color matched from IND Distribution!
M3nmotion18390.00 IND-Distribution9586.50 |
