10-24-2020, 04:23 AM | #1 |
Rep 12
M Perf LSD break in
I installed the M Perf LSD yesterday. Ive read through the BMW LSD FAQ and break in instructions but I’ve got some questions about the procedure: they talk about constant accelerating through left and right turns to actuate the clutch mechanism under load. Does this mean actually getting into a (slight) oversteer situation?
I hope so because I’ve stepped the back out slightly in some turns. |
10-24-2020, 12:39 PM | #2 |
Rep 86
I just drove around circles in a parking lot, 20 clockwise, 20 counter clockwise, then moderately for the next 500 miles, it worked just fine for me. No power oversteer situations for me.
10-24-2020, 01:53 PM | #3 | |
Rep 1,115
10-24-2020, 02:46 PM | #4 | |
Rep 3,506
BTW, that slipping is always the way you're alerted that your clutch-pack diff is due for rebuilding. Knowing BMW, however, they won't do a rebuild – they'll want to instead sell you a new diff. At that point, you're off to a specialist like Diffsonline here in the States. Figure-eights are another means of achieving the same effect.
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
10-24-2020, 02:59 PM | #5 |
msej449
514
Rep 717
Drives: M235i Convertible +LSD 2016
I'm lucky to live near some natural LSD running-in roads:
These are the sort of curves I imagined the BMW guide was referring to. I'm lucky that this junction is matched by a similar one to the left only a mile or so along the freeway, so I could go back-and-forth easily and do a series of balanced left/right LSD-stretching curves. So worth seeing if there's something similar near you.
2016 M235i Convertible Estoril Blue & Oyster
2023 Peugeot e-208 GT (electric) Last edited by msej449; 10-28-2020 at 11:15 AM.. |
10-24-2020, 11:29 PM | #6 | |
Rep 12
Unfortunately not blessed natural flowing roads in Perth, and those that are are generally swarmed with traffic police. Bit of a hoon problem in north Perth. As an aside I had the LCA/TS M upgrade done at the same time as the LSD, and between the two the Control Arm upgrade is my fav of the two. The steering response (maybe also to do with the -1.5deg camber) feels like a totally different car. I’m almost annoyed that BMW would sell the car with the original arms when the M ones are night and day for minimal extra cost. If you haven’t done the control arms definitely consider it. |
10-28-2020, 08:28 AM | #7 |
Rep 12
I contacted Drexler directly to ask them their opinion on the matter and got this back. Guess they should know...they built it....
Regarding your question I don't know what BMW recommends but Drexler have always advised me that the LSD does not require running in, the car can be driven aggressively straight away. You should ensure the diff oil is changed periodically, Ravenol SLS SAE 75W-140 GL 5 LS diff oil should be used with a Drexler LSD. Friendly regards Drexler Motorsport Australia 26 North Street Moss Vale NSW Phone: +61 2 4868 2347 |
Dylan861330.00 |
12-14-2020, 06:13 PM | #11 | |
Rep 3,506
Do you know if BMW rebuilds them or plans on selling you a new diff at your first clutch-refresh interval?
Phillymb7562.50 WolfGTI717.50 |
12-17-2020, 06:22 AM | #12 |
Rep 2,882
Likely they neuter this info from the instructions to support their 'lifetime fluids' fantasy - strange as this may seem, your dealer is looking out for you. The M2's all get fresh diff oil at the 1200 mile break in service, and I'd always heard to do this for any major machined parts from new (diff, trans, engine). They wear off metal bits that you don't want hanging around (and some situations they also use a break-in lube that is not as slick, to promote wearing-in of contact surfaces).
Moflow2484.50 |
12-17-2020, 11:46 AM | #15 |
Rep 81
10-29-2022, 06:37 AM | #16 |
msej449
514
Rep 717
I have just had a new replacement BMW M Performance LSD fitted after the previous unit developed a fault. The dealer showed me the recommendation from BMW for running-in:
'Break in/servicing differential: Upon differential installation, and fluid top-off, proceed to drive vehicle to a controlled area where several circles/figure-of-eights can be performed. Drive vehicle at idle speed in 20 figure-of-eights, full-lock to full-lock. Then drive at idle speed in 20 full-lock circles left, 20 full-lock circles right.' They also said to drive moderately for the first 3-400 miles or so, and not over-rev etc. Note the 'idle speed' recommendation: just engage the engine and don't use the throttle. They emphasised not to go much over a crawl and certainly not anything aggressive.
2023 Peugeot e-208 GT (electric) Last edited by msej449; 10-30-2022 at 07:36 AM.. |
10-30-2022, 06:55 PM | #17 |
Rep 919
10-31-2022, 01:09 AM | #18 | |
Rep 281
This is certainly not justified on a daily driver to service the diff every 15K unless somebody want to waste money on unnecessary maintenance. I cannot find any information in the maintenance book that give some credibility to this.
2019 M240i, Melbourne Red, Black Interior. 3M Tint, Premium Package, Harman Kardon, Adaptive LED Head Lights, M Performance Exhaust and Diffuser, Chrome Exhaust Tips, 719M Bi Color Wheels, Black Kidney Grille, Burger Tuning JB+.
