10-20-2020, 04:41 PM | #1 |
Rep 21,240
Michelin Pilot Sport Cup 2 Connected Smart Tires & App Tested on M2 Competition
Joe Achilles tests the new Michelin Pilot Sport Cup 2 Connected Smart tires on his M2 Competition.
The first application for these new tires are on the BMW M2 CS as OE tires. See more tire info here: https://f87.bimmerpost.com/forums/sh....php?t=1731119
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
9
Fabb228.50 My Schnell22.50 isN5454.00 frankiebones5299.00 BrysonDM53.00 oz555672.00 Dog Face Pony Soldier9719.50 JustChris17487.50 Elbow144.00 |
10-20-2020, 07:51 PM | #3 | |
Rep 1,314
10-20-2020, 08:07 PM | #4 |
Rep 2,007
Drives: 2022 i4 M50
13
10-20-2020, 08:55 PM | #5 |
Rep 296
Drives: M3 Competition (G80)
Seattlesquash894.50 |
10-20-2020, 11:07 PM | #8 | ||
MDM = Must Drive More
666
Rep 479
'21 M2 Comp
Sunset Orange | MT | Exec Pkg |
///M TOWN16568.00 |
10-21-2020, 12:58 AM | #9 |
Rep 1,271
10-21-2020, 03:19 AM | #10 |
Rep 386
Unless there are electronics and mechanisms that can increase/decrease tyre pressures including lowering/raising temperature of the tyres on the fly with the app, I do not see the benefits of such systems. As some has mentioned, the car itself already has TPMS, seems like a repeated feature that is not necessary.
Born in M Town
10-21-2020, 04:28 AM | #11 | ||
Rep 555
F87 M2 Competition Sunset Orange
IG: M2C_SO |
10-21-2020, 05:11 AM | #12 |
Rep 908
Drives: G20 M340ix; F30 328i msport
Gimmickry
Seems like another Youtuber trying to sell a product. |
10-21-2020, 05:15 AM | #13 | |||
Rep 775
Having a system tell you in real-time what the pressures are is somewhat irrelevant unless you are competing in professional racing and have a team at hand who can provide your real-time analysis and feedback on a per corner basis (aka, F1). As a driver at a track day, the only thing you can do is slow down, back off or stop and adjust pressures. If the current technology doesn't do enough to equip you... well, need I say more. For track days, even timed laps, this just comes across as a massive gimmick designed to sell more tyres (and at a higher price). |
danimal8720.00 |
10-21-2020, 06:13 AM | #14 |
Rep 2,442
Drives: 2022 M3 6MT
Pretty sure every tire already has this app. Called "wear bars".
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
10-21-2020, 07:09 AM | #16 |
Rep 390
You're obviously always alone and prohibited to have fun at a track day... I don't think Joe was trying to set a lap record nor pretend to be a race driver ... Even though he isn't a professional, he's pushing his car above the average pleb i'd say
///M TOWN16568.00 |
10-21-2020, 07:32 AM | #17 | |||
Rep 1,487
Blessed Beyond Measure
///M TOWN16568.00 |
10-21-2020, 07:55 AM | #18 |
Rep 6,759
Do you mean for cars which don’t have the tire pressure/temp display by default? Or do you mean something more than what my M3 is already showing?
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
10-21-2020, 08:00 AM | #19 |
Rep 1,487
Most BMWs do not have the feature by default, so I'm referring to those. I'm sure it's just unlocking the same system your M3 uses.
10-21-2020, 08:00 AM | #20 | |
Rep 3,337
A simple heat transfer analysis will show how different measuring at these two locations are in a real time process. To put it in the simplest of terms (without delving into conduction, convection and radiation heat transfer needed to be accounted for in the analysis), it's analogous to measuring the temperature of the burner itself in a gas fireplace as the gas level is cycled higher and lower versus a room temperature sensor mounted 3 feet in front of the fireplace. Whether said real time transient tread/carcass temperature is useful as used within the Michelin app or not is another question of course. As to TPMS measured air pressures...at a recent time trial event on a very fast course that was about 82 seconds long, in the M2C I had the iDrive pressure and temperature screen displayed as I was curious how it would correspond to my measured pressure (I have both a Longacre and an Intercomp bourdon tube type gauge) after each run. Due partly to massive heat input from the brakes, the pressures up front especially need to be constantly bled for at least the first four runs on course even when starting out low to begin with (31 psi). Anyway, immediately after the first run, the TPMS readout showed 32 psi LF and 34 psi RF, and get this with LF at 144F and RF at 145F; both started with exactly 31 psi measured and shown on the TPMS. My direct pressure measurement showed the LF at 37 psi and the RF at 38 psi (the course is somewhat biased to turning left, i.e. loading the RF the most). After measuring them and readjusting to 34 psi for the next run (RE-71R btw), I checked the TPMS screen to see what it showed, and it was unchanged. Hence, not only was it way off on the pressure at the end of the first run, but even after the adjustment, it hadn't (yet) changed. I think there is some significant buffering in the pressure readout when it sees a wild change in temperature like occurs in this case where over 80 seconds time the TPMS location measured temperature went from about 75F to over 140F. I didn't bother looking at it for the rest of the event since I felt it was useless...direct, accurate pressure measurement immediately after each run was far more useful.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
10-21-2020, 08:01 AM | #21 | |
Rep 6,759
The idrive display as someone mentioned does allow me to work with any brand of tire as long as I know their optimum pressure and temps hot. A gimmick, and completely irrelevant as I never run Cup 2’s on track, they have got to be one of the worst performance per dollar track tire out there.
Kankles1484.50 GarageMadness665.50 |
10-21-2020, 08:06 AM | #22 |
Rep 3,337
Exactly. Maybe the Cup 2R might be a heavy hitter against other track tires, but nobody can find out since it only comes in a couple of sizes (GT3RS I think); other than that, many other tires easily out perform the Cup2 on track.
Current Stable:
