BMW X5
      09-16-2020, 09:49 PM   #1
Maximus2002
Maximus2002's Avatar
136
Drives: 2019 BMW X5
Michelin Tires 275/45R21 315/40R21
Happily replaced all four tires with with Michelin all season tires. The ride has improved a lot. No rubbing, no issues, just had to change the tire setting on the iDrive.
      09-17-2020, 07:43 AM   #2
HomeIn2
HomeIn2's Avatar
Drives: 2020 X5 M50i
So iDrive let’s you enter a non-factory spec tire size?
Current: 2020 X5 M50i
Previous: 2019 M550i, 2018 X5 xDrive35i, 2015 750i, 2015 X5 sDrive35i
      09-17-2020, 08:04 AM   #3
nvisich
Drives: 2020 bmw x6 m50i
Attachment 2415312
Attachment 2415313
Attachment 2415314
I had these tires on my Mercedes GLE43 coupe. Great tires. Mercedes uses the exact ones for their 21" wheels.
Did the dealer install them? Just curious if they gave you a tough time being out of spec or will void any warranty work down the road. I'm in the same boat with my X6 M50i with 21" summer tires. I would prefer the Michelin tires you got. I would put the summer tires back on at the end of lease so car goes back as spec'd.
      09-17-2020, 10:22 AM   #4
Pumxee
Pumxee's Avatar
Drives: BMW X6
Wish I had seen this post a few weeks back. You don't have the air suspension. My concern has always been the larger tire and the air suspension.
Pum Performance Website Coming Soon!
BMW Parts and Accessories
https://pumperformance.com
      09-17-2020, 10:41 AM   #5
Maximus2002
136
Drives: 2019 BMW X5
Yes, it gives you that option to choose.
      09-17-2020, 10:45 AM   #6
Maximus2002
136
Drives: 2019 BMW X5
So far, I have had them for a few days, and I really like them. A tire shop installed them for me. Saved the run flat tires for the end of the lease when/if I have to return the car.
      09-17-2020, 10:49 AM   #7
Maximus2002
136
Drives: 2019 BMW X5
I honestly don't know if a large tire would fit if you have air suspension.
      09-17-2020, 11:59 AM   #8
HomeIn2
HomeIn2's Avatar
So I'm seeing in iDrive where it lets you change between Summer and Winter/AS tires, but I don't see how its possible to change tire size. It appears you went with +5 on the side wall aspect ratio.
      09-17-2020, 12:42 PM   #9
Maximus2002
136
Drives: 2019 BMW X5
My tire size was not listed on the iDrive, so I went with "All Year" "Other Tires". That was a suggestion given to me by three different BMW Geniuses.
      09-17-2020, 07:42 PM   #10
mocad
mocad's Avatar
Drives: 2021 X5 xDrive 40i
2021 BMW X5 40i  [0.00]
I assume this is an xDrive. You're sure the AWD system will be OK with the different rotation rates between front and rear? I'm in the exact same situation you are only with the 741M wheels. It's impossible to find all season tires for both front and rear from same manufacturer. I'm not super excited about the idea of buying an entire second set at a $5k price point to avoid constantly changing tires on the same wheels. I hate all the mess it makes with the balancing weights.
Current: 2023 X5 xDrive 40i (on order)
R.I.P.: 2021 X5 xDrive 40i (18-Jul-2022)
Past: 2008 335xi (fond memories)
      09-17-2020, 10:05 PM   #11
Maximus2002
136
Drives: 2019 BMW X5
Yes, it is an xDrive 40i. below is a good source to compare the tire sizes:
https://www.miata.net/garage/tirecalc.html
The iDrive has been configured to look for a different tires that have different sidewall measurements than what is listed on the menu, so most likely I'll be fine.
Worst case scenario, I'll put the original tires back, if I get any warning down the road. I can always sell the Michelin tires on Craigslist for a cheaper price. I gain a smoother and better ride IMHO, If the car doesn't complain.
mocad39.00
      09-25-2020, 09:39 AM   #12
SmartSaves
X5 Enthusiast
SmartSaves's Avatar
Drives: 2021 X5
2021 BMW X5  [10.00]
Interested to know if anyone with air suspension using this setup.
Edit: found answer here. Thanks Pumxee for checking this out. This is great info for those who prefers taller tire side walls.
      10-01-2020, 12:05 AM   #13
SmartSaves
X5 Enthusiast
SmartSaves's Avatar
Drives: 2021 X5
2021 BMW X5  [10.00]
OP, how is your experience so far? I definitely want to try these tires.
2021 X5, Excellence, M Sport, DHP, DAP, RSE, MW, Merino.
mosen766.00
      10-01-2020, 11:08 AM   #14
Maximus2002
136
Drives: 2019 BMW X5
I am very happy with these new Michelin tires. Put more than two hundred miles on the tires with no issues at all. Compared to the RF tires, these tires are making the ride WAY more comfortable with much less road noise
mosen766.00
      10-01-2020, 11:14 AM   #15
SmartSaves
X5 Enthusiast
SmartSaves's Avatar
Drives: 2021 X5
2021 BMW X5  [10.00]
I am very happy with these new Michelin tires. Put more than two hundreds miles on the tires, no issues at all. Compared to the RF tires, these tires are making the ride WAY more comfortable with much less road noise
Awesome! Thanks for the feedback.
      10-01-2020, 11:22 AM   #16
Maximus2002
136
Drives: 2019 BMW X5
My pleasure
      10-01-2020, 08:35 PM   #17
vkxkswk_xxxk
Drives: X5 M50i
Where did you find these tires? They're not on tirerack...
      10-02-2020, 12:41 AM   #18
Maximus2002
136
Drives: 2019 BMW X5
IMO Tirerack shouldn't be the only source you could get tires from. Depends where you are located, purchase your tires from Amazon, or Walmart. Then find a local tire shop (with a good review on Yelp), and have them balanced & installed for you. I took with me the below items before going to the tire shop. I made sure they are using my provided tools for the whole process of changing the wheels and tires:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I have 4 of these jack pad adapters for all 4 jacking points.
      10-02-2020, 09:51 AM   #19
SmartSaves
X5 Enthusiast
SmartSaves's Avatar
Drives: 2021 X5
2021 BMW X5  [10.00]
https://www.amazon.com/gp/product/B0...UTF8&psc=1
Wrap this pin guide tool with some electrical tape, in order to prevent scratching your wheels. I have two of them.
Learned this from you today. These are definitely keepers.
Thank you Maximus2002
      10-02-2020, 10:19 AM   #20
Maximus2002
136
Drives: 2019 BMW X5
My pleasure
      10-05-2020, 12:41 AM   #21
vkxkswk_xxxk
Drives: X5 M50i
You're right, but I'm overseas and my options are limited. Usually Tirerack has the best options and discount tire would follow. 315 tires are not easy to find..
      10-05-2020, 06:07 PM   #22
Maximus2002
136
Drives: 2019 BMW X5
Now that makes sense. I hope you will find a great deal easily
xbimmers
