09-14-2020, 09:23 AM | #1 |
Rep 103
Spring Choices
Before anyone says: "do a google search"... thanks for the bump. I have, but I would like to know if there has been a change in opinions
Yes I know coilovers exist. Not trying to spend 2k when i dont track the car. Was looking at dinan with the bumpstops or H&R on my 435xi. Leaning towards Dinan just because I have seen people seem to see it be closest to stock springs. Living in New England, snow can be bad at times. Pictures and opinions are appreciated. Thanks! |
09-14-2020, 12:23 PM | #2 |
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
I'm in the middle of doing this... using springs will wear down your shocks a lot quicker...how many miles on current shocks?... labor install is the same... the cost of springs vs coilovers is $500 if you go with no-rebound adjustment ST coilovers...
09-14-2020, 01:09 PM | #3 | |
Rep 1,079
If the roads aren't great over there and you don't have adaptive suspension then you might just want to try Eibach springs as the lowering is mild as compared to H&R and Dinan. Having more drop from Dinan or H&R will just damage your shocks sooner or later and the ride will become unbearable. |
09-14-2020, 02:29 PM | #4 | ||
Rep 103
If going through with the coilover route is the best option, what am i looking at for options and cost? |
09-14-2020, 02:33 PM | #5 | |
Rep 1,288
09-14-2020, 02:44 PM | #6 | ||
Rep 1,079
09-14-2020, 02:55 PM | #7 |
Rep 1,288
They say around 50,000 miles to change... go springs and you cut that in half of life you have left and still have to fork out the same as if you bought coilovers to begin with....
I was quoted $450 labor springs or coilovers.... ST = $838 Dinan = $279 Bilstein struts/shocks = $652 Your gonna blow your shocks out sooner than later going with springs on 42000mile oem struts/shocks.... best you go coilovers to begin with.... good luck with your decision... |
Fareed299723.50 |
09-14-2020, 02:57 PM | #8 | |
Rep 1,288
09-14-2020, 03:04 PM | #9 | |
Rep 1,288
Or just save up for KW's... lol... |
thatBimmerBloke877.50 |
09-14-2020, 03:06 PM | #10 | ||
Rep 1,079
09-14-2020, 03:11 PM | #11 |
Rep 1,079
In addition to FastF30s options:
Bilstein B14 ~ 1k. KW V1 ~ 1.4k Either do B8 shocks+dinan or eibach springs or just go for coilovers, B14s are pretty good too. If you only want to try springs then Eibachs as they provide a mild drop that won't be harsh on stock shocks as much as Dinan or H&R will be. |
09-14-2020, 03:35 PM | #12 |
Rep 1,288
Looks like the clean and anit-seize should be used on all C/O ... galvanized or SS... this is what I'm thinking... Moly-Spray™ Dry Film Lubricant... once before and after the season will keep them like new... this is just my opinion from doing quick reads...
update... washes off easily... damn.. looks like a lot of guys use spray on lithium due too the fine threads bind with certain anti-seizes... who would of guessed that.. Update again: DRI-MOLY (royal oil co.) dries quickly and will not wash off. Once it dries, it will stay in place providing lubricity even under very heavy loads (in excess of 20,000 psi)... Last edited by FastF30; 09-14-2020 at 03:49 PM.. |
09-14-2020, 03:53 PM | #13 |
Rep 694
09-15-2020, 12:18 PM | #16 |
Rep 694
09-15-2020, 12:39 PM | #17 | |
Rep 4,365
KW V1 if you want it low, with ability to set the perfect height while still retaining more than acceptable levels of ride comfort. I believe Eibach has two different spring offerings. x-drive is mild lowering, rwd is a bit lower if eibach x-drive springs, mild lowering, i recommend pairing them up with koni SA or yellow sport(adjustable rebound) dampers. SA are sporty but more comfortable. Yellow Sport are more track oriented so they're firmer than SA but well comfortable if adjusted soft. since koni SA are meant for mild lowering only, use koni yellow if you opt for the lower eibach rwd springs here is a F32 xdrive with lowering comparison between stock and eibach for x-drive...https://f30.bimmerpost.com/forums/sh...&postcount=122 since you do not track and basically just want to reduce the hideous x-drive wheel gap, i'd go with eibach(x-drive) and koni SA. if you want it a pinch lower than that eibach(rwd) and koni yellow sport |
09-15-2020, 03:20 PM | #18 | ||
Rep 5,396
Drives: 2015 BMW 335i x-Drive Auto
09-15-2020, 03:38 PM | #19 | ||
Rep 103
With all that, itll rack up near $900-1000. at that price maybe KW v1 may be worth getting if its a better set up for little extra cost and peace of mind? |
09-15-2020, 08:21 PM | #21 |
Rep 1,288
I was all set to get the ST's XA and now I don't know....this winter thing is really bugging me now... I don't drive unless streets are clean but still gonna get salt residue I'm sure... yea I can put boots on but I just don't know anymore... kw's are just to damn expensive and rather take that money and spend somewhere else.. never gonna track it competitively anyways... lots of good reviews for the B14.... hmmmmmm.....
P.s. is there anything else I have to purchase... bump stops etc? |
09-15-2020, 11:29 PM | #22 | |
Rep 1,079
