08-30-2020, 03:32 AM | #1 |
Rep 40
Badge Removal
Hey guys I purchased a gloss black X5 badge to replace the chrome one. Any help on how to remove the existing badge would be appreciated.
Cheers |
08-30-2020, 03:38 AM | #2 |
Rep 365
Heat up with hair dryer, use dental floss under badge to cut away the glue in slow back and forth motion.
Heat again to remove any excess glue. Tar/glue remover will help in dissolving any left over. Quick polish with cutting compound to remove any imperfection, wipe down if ISO and stick on new badge |
08-30-2020, 06:54 AM | #5 |
There's a storm coming
253
Rep 596
Drives: BMW Vader
Garage List 2020 BMW M135i xDrive [0.00]
2019 BMW G05 M Spor ... [0.00] 2018 540i M Sport X ... [0.00] 2018 BMW 540i M Spo ... [0.00] |
08-30-2020, 07:03 AM | #6 |
Rep 243
Dental floss will also get the job done.
I've Seen Things24.00 |
08-30-2020, 07:32 AM | #7 |
Rep 40
08-30-2020, 08:01 AM | #8 |
Rep 5,343
My go to is spider wire braided fishing line in a loop around two handles. This works for the really big jobs like a spoiler install or the little stuff. Always have the temp above above 60 degrees when sticking anything to your paint.
08-30-2020, 08:16 AM | #9 |
Rep 40
Thank you for the tip regarding temp sir.
08-30-2020, 08:30 AM | #10 |
Rep 5,343
Way too many on the M forums with CF spoilers not sticking good enough. Adhesive promoter and warm temp for the bigger items. Badges are simple enough to just clean the area with alcohol and stick them in a warmer temp. I have done badges in the winter but used a heat gun to really heat up the metal and let them set up in the garage overnight.
