08-20-2020, 09:29 AM | #1 |
Rep 32
Bmw apps after retrofit and 09c code
Just a quick question about the bmw apps fsc code , i have an nbt retrofit from hu cic with combox, i used to have bmw apps before and now even with the 6nr coded it seems that neither bmw live or bmw apps do not want to work ! I will attach a print screen fron esys with fsc code status shows app 156 fsc status active ! I still need to change that or the car is not coded properly? Thank you!
08-22-2020, 03:09 AM | #3 |
Rep 32
So a quick update, it seems that i still have 6vb on the fa, if i unplug tje combox from the boot i get connected store to show up but still not able to connect to the network message ! Any ideas with what i am doing wrong ? Thanks !
Also what do you guys think about the bimmercode screenshot's anything out of place ? |
08-24-2020, 06:22 AM | #4 |
Rep 32
I will keep writing here, possible somebody cand provide me an ideea !
I disconnected the combox completely, i was keeping it plugged in so that i do not get the sos malfunction message and to have the most loop closed, but apparently this was interfering with the connected drive services! After this i get the update services option that was greyed out in the past to show up and after pressing it i see the transfer globe active and i get the bluetooth data thethering message in my phone, and after this is complete nothing new shows up, even after i let the car to go to sleep! Any ideas what might be causing this , car not beeing coded properly ( should i code the nbt with the donor win ?) , Fsc code not good ? |
