08-13-2020, 07:39 AM | #1 |
Rep 101
I've been reading a lot of these posts and I think I know what I need, but couldn't decide my mind.
I ordered M50i (no VIN yet so I can still make modifications) and I originally put 21 in 741M, but couple days later changed my mind to 20 in 740M and below are the pros and cons that I think about these two wheels.. my mind tells me 21 but reality and practicality goes to 20. I'm outside the states so tires option are limited for me. Any advice would be appreciated, thanks. 21 Pros -Looks better than 20 740M -More traction on corners Cons -Staggered, so more tire changes than 20 in -Limited tire options for 315-35-21. I only see michelin and p zero and i heard mixed reviews about p zero 20 Pros -longer lifespan than 21 -lots of options for tires Cons -looks (from both side and rear) -decreased top speed (from 155 to 130) |
08-13-2020, 08:54 AM | #3 |
Rep 1,492
Neither. Go with 22's as they complement the car best.
2020 G07 x40i BSM/Blk Merino
2022 Audi E-tron S Mythos Blk/Blk Valcona |
08-13-2020, 01:26 PM | #5 |
Rep 5,731
Drives: '24 iX50; '23 i4 M50
Yup, 22" for summer and winter
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
08-13-2020, 06:44 PM | #6 |
Rep 101
08-13-2020, 07:55 PM | #7 |
Rep 89
Drives: 2019 M850i First Edition
I chose 20's for our M50i for the following reasons:
1) Immediately replacing whatever tires come with my current favorite tire, Goodyear Exhilerates. Have them on BRZ and GTI and they are amazing. Will store Run Flats and replace close to lease return. 2) This is my wifes primary vehicle, and she wants as plush/comfy as possible, so 20's with Air Suspension. She will use the acceleration for passing, but will not be screaming through corners nor going anywhere near 130 top speed. 3) We live in Atlanta, so only need "winterish" tires for holiday road trip to Illinois for Thanksgiving and Christmas/NY. We deal with snow on those trips about 2 times every 10 years. All that said, the 22's are BEAUTIFUL, and if it were my main drive, I would definitely have 22's (and DHP instead of AS) |
08-13-2020, 09:44 PM | #9 |
Rep 4,246
DHP = Dynamic Handling Package
Current BMWs - '20 X5 xDrive40i M Sport, '20 BMW M550i | Past BMWs - '03 E39 540iT M Sport, '06 E53 4.8is, '11 E70 M Sport LCI
08-13-2020, 10:50 PM | #10 | |
Rep 296
Drives: M3 Competition (G80)
I have 21's on mine. It came with Hannook Summer. I had the same 21's on my X5 40i and yes winter or All season are rare finds. If you want dedicated winters, start looking no. Nokia makes a limited run for the 315's. If you ordered the 2 axle air suspension, the 22's will be fine. Not sure of the roads in and around Atlanta but I have a feeling they are much better than the potholes in the Northeast. Also, there are plenty of OEM 20's you can buy for a winter set up. I personally think if you put on the expensive suit, wear the right shoes to match. |
08-13-2020, 11:34 PM | #11 | |
Rep 101
08-14-2020, 12:08 AM | #12 |
Rep 1,241
20s and 22s are easiest to find tires for. 21s are much more difficult..... but not "impossible".
I actually like the design of the 21s the best..... comprimise on comfort (compared to 22).... but still maintains the width, top speed, and appearance (compared to 20s). Unless you live in a REALLY..... REALLY bad area for roads, 22s will be fine, especially if you have air suspension. I do.... and got 21s for the reasons listed above. And now.... I have a set of 22s being made and shipped,.because even with bad roads, 22s are fine with a bit of caution. |
08-14-2020, 01:46 AM | #13 | |
Rep 101
08-14-2020, 05:04 AM | #14 | ||
Rep 296
I am going to go with a set of dedicated winters with the same size set up. I know others may disagree but I'm the one buy and driving. I like the look of the wider tires. I wish the rear rims were 11" wide, like the F15 20's. I had decided winters last season for the X3M and zero acceleration reduction. That being said, I ran all seasons on my F15 50i, Continental DWS 06 Extreme. Never had an issue in the worst snow storm. $1,200 a set mounted and balanced. I went through 3 sets. |
08-14-2020, 05:06 AM | #15 | |
Rep 296
08-14-2020, 05:24 AM | #16 | |
Rep 1,241
Took 2 months to build, and they should be arriving (here in Europe) in the next couple weeks.
2020 X5 M50i, Alpine, B&W, Air Susp, anthracite, coffee, **CD player**:
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019 690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813 6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342 |
08-14-2020, 07:59 AM | #17 | |
Rep 5,731
FS in PA: Genuine BMW Black 22" 742M Winter Setup https://g05.bimmerpost.com/forums/sh....php?t=1700976
08-14-2020, 08:05 AM | #18 | ||
Rep 101
08-14-2020, 08:20 AM | #19 | |||
Rep 5,731
Those aren't your offsets btw, but the width I think you're referring to
08-14-2020, 08:23 AM | #20 | ||
Rep 296
Just putting together my build list now. Trying to get that front splitter shipped to the states. Actually think I have it all set...should know very soon. |
08-14-2020, 08:25 AM | #21 | ||
Rep 296
08-14-2020, 08:58 AM | #22 | |||
Rep 5,731
