07-17-2020, 10:27 PM | #1 |
Rep 112
Braille batteries (G20 vs I48CX)
Someone please feel free to hit me over the head here,
It's hard to believe i can actually use this G20 battery from Braille. What are some reasons to pony up for the I48CX if I can get away with the G20? Braille Performance GreenLite Lithium-ION Battery - G20 - 4.5lbs (~$500) Physical Specifications: BCI Group: 20L Weight: 4.5lbs / 2.04kg Length: 7.1" / 180mm Width: 2.98" / 76mm Height: 6.25" / 159mm Polarity: Right Side Positive Performance Specifications: Voltage: 12 Full Charge Voltage: 13.8 Pulse Cranking Amps (PCA): 697 Amp Hour (AH): 12 Lithium Amp Hour/Lead-Acid Equivalent (LAH/PbEq): 36 Reserve Capacity (RC): 28 vs. Braille Intensity Carbon Lithium-ION Battery - I48CX - 10.5lbs (~$1400) Physical Specifications: BCI Group: 48 Weight: 10.5lbs / 4.8kg Length: 11" / 279mm Width: 6.8" / 173mm Height: 7.7" / 195mm Polarity: Right Side Positive Performance Specifications: Voltage: 12 Full Charge Voltage: 13.8 Pulse Cranking Amps (PCA): 1520 Amp Hour (AH): 25 Lithium Amp Hour/Lead-Acid Equivalent (LAH/PbEq): 75 Life Cycle @ 10% DOD: 5000 Yes it's a lot for a battery but I have a wing and large diffuser kit going on so trying to offset the weight gain.
Follow my build on instagram! @the340iguy
07-18-2020, 07:50 AM | #3 | |
Rep 13
Hi, if you have option to register this type of battery with Ista, go for it, otherwise stay chill. |
