07-07-2020, 07:46 AM | #1 |
Rep 29
GPS navigation signal issue F30 NBT ID6
Hi all,
form one day to another my gps has stopped working and i don't know why i've purchased another gps antenna thinking that the OEM was damaged but at the end i have the same problem i've entered in the secret menu and it says gps status: Reserved do you know how to solve the issue? thanks |
07-07-2020, 08:45 AM | #2 |
BimmerPost Supporting Vendor
665
Rep 1,976
Drives: 2020 G20 320i M Sport
Do you have Tool32? There should be a command that you can run there to see if the GPS circuit is responding and if it is picking up any signal.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
07-08-2020, 01:18 AM | #3 |
Rep 29
Hi i don't have this tool but going into the service menù i don't see any signal and the gps is RESERVED is coding activation lost for the gps?
because i've changed the antenna and i have the same issue thank you |
02-15-2021, 10:17 AM | #6 |
Rep 115
i would look into getting a copy of esys and tool32 so you can check the status as advised by steve
tool32 to check gps status esys to check the gps is set as aktiv. was the car originally id6 or have you retrofitted it |
