07-03-2020, 03:16 AM | #1 |
Rep 49
RetroFit Done, GPS Issues
Good Morning, Finally got the NBT Evo working in my 320d, all coded and working thanks to shawnsheridan friend, so thanks. Only issue I have is the GPS doesnt seem to work, I moved the GPS connection from my Business Nav (HUENTRYNAV) to the EVO but doesnt seem to locate me? I dont have the Combo box I know people mention I have the Telematic Control Module in the boot. Am I missing something silly?
07-03-2020, 05:27 AM | #3 |
Rep 49
http://blog.obdii365.com/2016/09/19/...or-enet-cable/
as per this picture I connected the BlueConnector from my entrynav to this one on port 5. |
07-03-2020, 07:26 AM | #4 | |
Rep 2,302
You can now check the setting GPS_FROM_NAVI if it's set to active. If it's active you can also try to set it to nicht_aktiv. |
07-03-2020, 07:33 AM | #5 |
Rep 49
07-03-2020, 07:41 AM | #6 |
Rep 49
Found it changed this
SYSTEM_GPS_RECEIVER to aktiv GPS_FROM_NAVI to aktiv ADAS_GPS to not_aktiv TELEMATIC UNIT change from ATM to off (So it fails over to GPS attena) |
07-03-2020, 08:16 AM | #7 |
Rep 49
I guess I cant use my Telephone module with this unit can I for connected drive? also touch control all turned on in ESYS but not working, mine is late 2015 so do I need any additional cabling?
07-03-2020, 12:13 PM | #8 | |
Rep 2,302
The controller with touch or the display with touch? |
07-03-2020, 12:30 PM | #9 |
Rep 49
07-04-2020, 07:08 AM | #10 | |
Rep 2,302
https://www.newtis.info/tisv2/a/en/f...ttons/IH4YcYnp |
07-04-2020, 07:12 AM | #11 | |
Rep 49
Ahhhh doh! Make sense I will see if I can get one. |
07-04-2020, 07:19 AM | #12 | |
Rep 49
I assume this plugs into the back of the headunit? and where is the best place to mount this? |
07-04-2020, 11:34 AM | #13 | |
Rep 2,302
Up to 06/2016 https://www.newtis.info/tisv2/a/en/f...lim/1VnY0KRpXj From 07/2016 https://www.newtis.info/tisv2/a/en/f...lim/1VnZAc1ILW Here an overview for the connection https://www.newtis.info/tisv2/a/en/f...box/1VnXXpwdRW And here the wiring diagram for the Touchbox and controller https://www.newtis.info/tisv2/a/en/f...ler/1VnXPoUex4 After installation both ecus (controller + touchbox) have to be coded. |
07-04-2020, 11:42 AM | #14 | |
Rep 49
Thanks so If I was to buy this as well as the control unit will it work? https://www.ebay.co.uk/itm/BMW-F10-F...bba4%7Ciid%3A1 |
07-04-2020, 01:12 PM | #15 | |
Rep 2,302
Because the touchbox and the controller have exactly the same connections. |
07-04-2020, 01:13 PM | #16 |
Rep 49
