06-20-2020, 05:17 AM | #1 |
Rep 62
2016 328i Carplay
Hi,
My car shows incompatible for Carplay on BMW NA's website. However, there are some third party companies that can install aftermarket Carplay to my car. Why can't BMW install Carplay to my car when these companies can? Can I just buy a used/new OEM head/main unit with Carplay and have BMW dealer install it? I am little confused as why BMW says it is not possible to have Carplay in my car when it is actually doable. Thanks. P.S. I also have BMW navigation in my car. |
06-20-2020, 06:51 AM | #2 |
Rep 256
BMW says it's impossible because your headunit in your car (likely nbt Evo id4) doesn't have carplay built in. BMW does not install new headunits from newer model year cars in previous model years and can't enable carplay by software update to you, so by their standards it can't/won't be done
You can of course by a mmi box that adds carplay functionality by acting as a bridge to the headunit and hijacking the signal, which is something BMW would never install on their own. Or you can upgrade your headunit from a newer donor vehicle |
sspade2466.00 |
06-20-2020, 07:12 AM | #3 |
Rep 62
That's what I was trying to ask when I said used/new head unit. So, if I buy a new or used donor head unit, will BMW dealer install it?
Say something like this? https://www.ebay.com/itm/113400868051 |
06-20-2020, 07:15 AM | #4 |
Rep 1,687
Drives: 2014 428i and 2018 X5
Doubtful, and if they did they would charge you a shitload.
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
06-20-2020, 08:12 AM | #6 | |
Rep 256
I have a 2016 328i and have been very happy with the mmi for carplay. Cheaper than a Android unit and retains factory look |
06-20-2020, 09:11 AM | #7 | ||
Rep 62
Could you please tell me which MMI do you have? |
06-20-2020, 02:33 PM | #8 |
Rep 256
Could you please tell me which MMI do you have?[/QUOTE]
I have carlinkit which was about 270 Some andream will be on sale for 200 If you want to spend more bimmertech has one for 650 that has slightly more updated software (if you use AA it's worth it, carplay not really) |
06-20-2020, 03:15 PM | #9 | |
Coding ECU's remotely
445
Rep 1,176
if your car has NBT EVO then Carplay is doable, you can even by a genuine FSC code from BMW to enable it. BMW won't activate it because their diagnostic system won't allow it "computer says no" |
06-20-2020, 04:57 PM | #10 |
Rep 256
2016 328i has id4 which is a no go
06-20-2020, 05:08 PM | #11 |
Rep 62
Some andream will be on sale for 200 If you want to spend more bimmertech has one for 650 that has slightly more updated software (if you use AA it's worth it, carplay not really)[/QUOTE] What is AA? Do I want it? I ONLY want Carplay. We have all iPhones. |
06-20-2020, 06:15 PM | #12 | |
Rep 256
I ONLY want Carplay. We have all iPhones.[/QUOTE] as is Android auto. If you use carplay only it doesn't matter then. Just bimmertech has a bug fixes for AA |
06-21-2020, 07:19 AM | #14 |
Rep 62
Does your idrive have a list or tile menu?
Cars made after 07/2016 have ID5 Can't check since the car is at BMW service. I thought it could be done while at the service hence the question. Looks like not as easy with the dealer. |
06-21-2020, 12:28 PM | #15 |
445
Rep 1,176
Post the full VIN and I can check on BMW's AOS server for the production date.
06-21-2020, 12:41 PM | #16 | |
Rep 62
