05-18-2020, 08:06 AM | #1 |
Rep 59
x3 2020 trunk fuse box
Does anyone have a link to the fuse box diagram for the trunk fusebox?
I opened it up and didnt see any diagram on the x3's trunk fuse box.. Need to hook up dashcam battery to the trunk.. |
05-18-2020, 09:14 AM | #2 |
Rep 59
Ok I found it..
Looking at other threads, it seems like people are using F46/F47 for ACC.. On my X3, the 12V are always on, so does that mean F46/F47 are constant and not acc? I can't check the actuals amps as my kit hasn't arrived yet. |
05-18-2020, 11:17 AM | #3 | |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3515
Rep 4,211
Turn off the car, hold the volume power button until the shutdown sequence is seen on the displays. Wait 5-10 minutes or until the start stop button light goes out and the car should be asleep. Fuses that are now 0v are switched power and will best to use for the dashcam. |
05-18-2020, 11:29 AM | #4 |
Rep 59
The engine hasn't been on for 12hours.
I noticed the 12v turned on after unlocking the car, it was turned off after around 10 mins after closing the door and locking the car. I guess thats ok? The battery will be milked by the external batter for another 10 minutes.. 12v doesn't seem to go to sleep with doors opened and doors locked. |
05-18-2020, 01:10 PM | #5 |
Photojournalist, Tech & Product Analyst
510
Rep 472
Check out my post and the link in it https://x3.xbimmers.com/forums/showp...02&postcount=1. I include the fuse box diagrams and recommended fuse locations to tap for a dashcam install.
I think you will find it easier to tap the interior cabin fuse box as noted in my write-up, rather than the rear side fuse box.
Current:2024 i4 Mineral White Metallic with Blue Exterior Accents, Canberra Beige Perforated SensaTec, Premium Package, Driving Assistance Pro Package, Drive Recorder. 2019 X3 Mineral White Metallic, Caberra Beige interior with most options. Corvette Stingray Arctic White w red interior.
Past:2002 Z3, Corvette Stingray and about 40 other cars Last edited by JDsX3; 05-18-2020 at 10:41 PM.. |
05-18-2020, 04:44 PM | #6 | |
3515
Rep 4,211
05-26-2020, 02:51 PM | #7 |
Rep 59
Ok, this is problematic as the ACC is not turned off when ignition is off, but rather it turns off 6 mins later.
My acc is hooked up to Cellink NEO and the 6 mins is draining the car battery... I just got a low voltage warning from the Cellink.. How to make acc turn off completely immediately after ignition is off.? |
05-26-2020, 07:00 PM | #8 |
Rep 59
So after looking at the distribution diagram, it seems there are no fuse slots that turns off immediately after ignition is off is suitable for fuse tapping.. none of the existing ones are over 10a.
K15 slots https://www.newtis.info/tisv2/a/en/g...ear/1Vnc7Pg177 Anyone have issue charging their battery with the 6 minutes off 12v fuses? |
