BMW M5 F90 (2018+) General Forums Regional Forums UK    Battery charger?
      04-20-2020, 02:21 PM   #1
Darkeeboy
Darkeeboy's Avatar
Drives: X5M50i
Battery charger?
With the current climate meaning only essential travel only I am not using my car at all. I purchased a CTEK MSX 5 charger but had a thought that it might not work on our lithium type batteries? Am I ok to use it or should I get another type of charger?
      04-21-2020, 08:48 AM   #2
OneExtra
OneExtra's Avatar
Drives: None
I believe CTEK do a charger specific for Lithium batteries but not sure if the one you have works with one, maybe email CTEK to be sure before connecting
      04-21-2020, 05:13 PM   #3
CanadianF90M5
Drives: 2019 BMW F90 M5
I use this one from BMW
Previous: 2005 BMW E60 545
      04-22-2020, 03:44 AM   #4
Ian335xd
Drives: BMW F90 M5 2019
I use this charger.
https://www.tayna.co.uk/battery-char...hoC1_gQAvD_BwE
      04-22-2020, 11:49 AM   #5
Darkeeboy
Darkeeboy's Avatar
Drives: X5M50i
Hmmm think I got the wrong one then!
      04-22-2020, 03:21 PM   #6
Maxlude
Drives: E90 330D_SE_Man, F90_M5C
I've been using my Noco genius G3500, it has a 12v li-ion mode. Works well.
      04-23-2020, 03:50 AM   #7
M5stu
Drives: 2019 BMW M5 Competition
Hi - I believe the CTEK MSX 5 is for lead acid so wouldn't risk it with your expensive F90 Li-Po battery. I've got the CTEK Lithium XS for mine and its seems good tucked up in it's Covid hibernation..
https://www.ctek.com/products/vehicle/lithium-xs
Looks like there are might be more cost effective options out there, I also like the look of the BMW one mentioned above that is switchable for between battery types and cars / motorbikes.
      04-25-2020, 03:03 PM   #8
Darkeeboy
Darkeeboy's Avatar
Drives: X5M50i
Is this the noco one? It's only a third of the price is the ctec
NOCO Genius G3500UK 6V and 12V 3.5 Amp Smart Battery Charger and Maintainer https://www.amazon.co.uk/dp/B00E907P..._MBjPEb9K18Q9Q
      04-25-2020, 05:29 PM   #9
Maxlude
Yep, that's the one I've been using for about 3yrs. Got 3 cars it's currently charging one at a time as none are being driven. Even have to use it to charge my wife's Mini Countryman PHEV, as the engine kept starting even though the 7.6kw EV battery was fully charged, it seems that the normal electrics are 12v and fed off a standard battery which was running low due to only using the EV to do short trips the last month. Replaced a Ring Smart8 which crapped out.
      05-06-2020, 01:31 PM   #10
Darkeeboy
Darkeeboy's Avatar
Drives: X5M50i
The noco one works a treat! Cheers all
m5post
