04-09-2020, 02:47 PM | #1 |
Rep 5
How to play DVD videos?
Hello BMW lovers!
I have bought an used BMW 320d, 2012. one year ago, and since then have not found a good way to play videos in my car. Video in motion is unlocked (that's how I bought the car). I have tried to play from USB (both FAT32 and NTFS) many different video files formats (mp4, avi, wmv, mov, flv, wma). I was able to see only mp4 and wma, but could not play them because of the error ''Could not play the file''. I tried both USB slots (gloves box and armrest). Then a local amateur coding guy told me that only 2014 or newer BMW cars can play videos from USB. I moved on and started looking for an alternative, and saw that I can play normal DVD movies even in motion. So I wanted to burn as many music videos as possible on DVD disc and play them. - First I burned simple Data DVD disc in Nero with .mp4 music video files. That did not work at all... Then I found out that only .vob files can be recognized by BMW and my multimedia hardware. I found a way to convert and burn .vob files on the disc but the problem is that I can't see file title, instead of that I can only see ''Chapter 1, Chapter 2, Chapter 3...'' and I can't change the song simply by pressing on ''Play next chapter''. Instead of that I have to do it on a complicated way, which can be distracting while driving, and is not safe... you can see how it looks here. I have to press Options, then go to Other Options, then Select title. you can see how it looks here Anyone here knows what software can I use to burn DVD discs and how to change videos faster/easier than this? I look forward to hearing from you! ------------- Another question - Bluetooth does not play music from my phone. I don't have any option to enable or disable that, so I assume that my multimedia hardware in car does not support that. Or am I wrong? Phone calls work perfectly fine though and I am happy to have that feature |
04-09-2020, 02:54 PM | #2 | |
Rep 256
Unlocking enhanced Bluetooth via esys or bimmercode might work |
04-10-2020, 01:43 PM | #3 |
Rep 5
'Might work' is not enough. I would like to know how to burn DVD disc and how to easily change music videos from that disc. I also want to ask if anyone knows where to find changelog for software. I would like to know if software update is really necessary for my car
04-10-2020, 03:04 PM | #4 | |
Rep 256
It's $20 for an esys cable or $32 for bimmercode and $10 for the obd connector to be able to code your car. Most people here have 1 or the other |
04-10-2020, 09:32 PM | #5 |
Rep 5
I am not sure if bluetooth can stream video. That is what I want. I have USB stick with songs on it, but I can play mp3 only. I would like to play video instead
04-16-2020, 05:17 AM | #6 |
Rep 3
I also have a F31 from 2014 and I don't know what video file type I can play from a USB stick. Does it work if I use the USB jack in the glove box instead of the middle console one ?
