03-23-2020, 01:24 PM | #1 |
Rep 203
Can X5M Comp be ordered with 22s all around ?
Hello friends
I'm curious to know if the x5m comp be ordered with 22s all all around as a pose to 22 rear and 21 front Thanks in advance |
03-23-2020, 01:49 PM | #2 |
Rep 8,805
pretty sure no and its because the Michelin tires that BMW M specifies to be used on the X5M doesn't come in the correct size in 22".
03-23-2020, 01:50 PM | #3 | |
Rep 203
03-24-2020, 04:29 AM | #4 |
Rep 5,728
Drives: '24 iX50; '23 i4 M50
Michs 4S come in 22" 285/315, but as you alluded to, the compound could be slightly different. Once my Contis wear out, I plan on running the 4S on my M50i, moving from 275 to 285 up front shouldn't be an issue.
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
babyghost94.50 |
03-24-2020, 09:07 AM | #5 | |
Rep 217
I think the stock width of the 21” front wheel on the F95 is 10.5 and the stock tire width is 295. Could you put, for example, a tire with a width of 305 on that same wheel or would you have to get a wider wheel (e.g. 11)? I guess my question could go the other way too - could you put a 285 tire on a 10.5 wheel or would you need to go down to a 10 wheel? I can’t imagine there is much leeway, but I was thinking there may be some without having to actually replace the wheel...maybe not though. |
03-28-2020, 10:26 AM | #6 | |
Rep 982
03-28-2020, 02:13 PM | #7 | |
Rep 1,206
I didn't know I couldn't do that. But I did know I couldn't do that.
03-29-2020, 04:16 AM | #8 | |
Rep 50
My friend was forced to change one of his tires on a road trip and the x drive didn’t survive 40 miles. It went into safety mode and limited everything. |
