09-09-2008, 02:43 AM | #1 |
Perfection Is In The Details
67
Rep 1,044
Detailing Perfection: 2001 GMC Sierra C3
Hey guys! Sorry I have not been posting lately. Between school and my girlfriend, I have not had enough time for a proper write-up for my details. I have been surprisingly busy and have now been receiving many return customers. Well from the get-go I knew this detail was going to have a great turn-around so I felt a write-up was calling.
THE DETAIL Well the truck is a 2001 GMC Sierra C3. The truck as never had paint correction and has not had protection for over a year. For the first 80,000 miles the truck had seen many drive-through car washes and in the last 50,000 miles has seen good washing techniques. So as you can guess the paint was in bad shape. Also because of the harsh chemicals from the drive-through car washes, the trim had lost a lot of color and had become dole. The truck has also been driven up the Lake Tahoe countless times therefore the undercarriage had pounds of sand and dried salt caked to the surface. I will illustrate the pictures as much as possible throughout the post. I was working very hard and was lazy with the pictures from correction to the final product and missed a couple of steps in-between, but you will still be able to see a huge difference. Enjoy and thanks for looking! Jared *Exterior Detail Only* BODY WASH Honda Gas Powered Power-Washer Foam Lance Foam Cannon (2)Zymol Wash Sponges (2) Buckets P21s Total Auto Wash (Pre-Soak) Chemical Guys Citrus Wash Clear (Main-Wash) Chemical Guys Water Spot Remover Chemical Guys MF Waffle Weave Drying Towels DOOR JAMS Honda Gas Powered Power-Washer P21s Total Auto Wash Swissvax Wheel Brush WHEEL WELL/TIRE WASH Honda Gas Powered Power-Washer P21s Total Auto Wash Tire Brush Wheel Well Brush WHEEL WASH Honda Gas Powered Power-Washer P21s Total Auto Wash (Pre-Soak) P21s Wheel Gel (Main-Wash) Swissvax Wheel Brush CLAY Special Yellow Clay Chemical Guys Extreme Slick Synthetic Quick Detailer Chemical Guys MF Waffle Weave Drying Towels PAINT CORRECTION Menzerna Power Gloss Menzerna Super Intensive Menzerna PO106ff 2000 Grit Wet-Sanding Paper (Only On Certain Areas) CCS Yellow Pad CCS Orange Pad CCS White Pad Chemical Guys Polishing Pad Conditioner Alcohol/Distilled Water (To Remove Polish Oils) Green 3M Masking Tape Flex Tool XC 3401 VR Hitachi High Speed Chemical Guys MF Fluffer Towels PROTECTION/LSP WINDOWS Einszett Glas Polish Lusso Glass Polish Chemical Guys MF Fluffer Towels WHEELS AND ALL OTHER METALS Swissvax Autobahn Megs App Pad Costco MF Towels WHEEL WELLS/TIRES Chemical Guys Fade 2 Black Costco MF Towels PLASTIC TRIM Chemical Guys Fade 2 Black Chemical Guys Trim Gel Costco MF Towels Megs App Pad BLACK METAL TRIM Chemical Guys Fade 2 Black Costco MF Towels Megs App Pad HEAD LIGHTS/TAIL LIGHTS/ THIRD BREAK LIGHT Pluxes Chemical Guys Fluffer MF Towels [B]DOOR JAMS[B] Chemical Guys Jetseal 109 Chemical Guys Fluffer MF Towels Megs App Pad PRE-WAX Chemical Guys VB-408 Chemical Guys Fluffer MF Towels Megs App Pad LSP Chemical Guys Jetseal 109 Chemical Guys Fluffer MF Towels Megs App Pad FINAL WIPE DOWN Optimum Instant Detailer & Gloss Enhancer Chemical Guys Fluffer MF Towels First up was the wheels, wheel wells, and tires. As you can see the interior of the wheel was caked with years of build-up and needed a lot of work. I started off by soaking the wheel, wheel wells, and tires with P21s TAW. Next I brushed the tires and wheel wells and then rinsed off everything with the power washer. After I was happy with how the wheel wells and tires turned out, I started with the wheels by giving them a good soak with P21s Wheel Gel. I let the Gel sit for 10 min and then started brushing them with my Ace Power Stick hooked up to my drill. Finally I brushed the face of the wheel with P21s Wheel Gel with my Swissvax wheel brush and gave everything a heavy power-wash to make sure all the soap was off the surface. For the door jams I gave them a good soaking with P21s TAW and then brushed them with a different “door jam only” Swissvax Wheel Brush. The finished with a good power wash. Here is what the paint looked like before the wash. The car received a good soak of P21s TAW to de-grease the entire truck and then was power washed. Next was the foam cannon and wash steps. I used the two bucket method with two Zymol Wash Sponges. It had some water-spots so I mixed some Chemical Guys Water Spot Removier in with the wash to take care of them. I used the special yellow clay (you know what it is) and here is what ¼ of the truck looked like. I started with the smaller trim. The upper is not polished, and the lower is. Another angel Here is a 50/50 of the hood And another This was a tough area the needed wet-sanding. Before After: Here are some reflection shots after a quick foam to get the polish oils off. NO LSP. For my last steps I decided to go with products that have never let me down. I used CG VB408 to make sure all the polish oils were off and to add a bit of depth and then used CG Jetseal 109 and my last step. Once the CG Jetseal was al wiped off I came back with OPT QD to finish it off. For all the plastic trim I used CG Trim Gel, for the wheels and chrome/metal trim I went with SV Autobahn, and lastly for the dressing I dressed the wheels with CG Fade2Black along with the wheel wells. Keep in mind that in these pics I did not wipe the tires off yet therefore they look a bit un-even. Lastly I polished the glass with Z1 and Lusso glass polish.
2006 E90 SG-Dinan Ram Air Intake-Dinan Throttle Body-Dinan Exhaust-19' Hyperblack CSL's-15/5 tint-Matte Black Grills-M3 Spoiler Lip-Amber Delete-Smoke Side Signals |
09-09-2008, 04:35 PM | #3 |
67
Rep 1,044
PM sent
