01-04-2020, 09:17 AM | #1 |
Rep 74
Driver seat headrest - move back and forth
Is there an option to push the headrest back and forth? Looks like it's only possible to move it up and down. I'm I missing anything?
01-04-2020, 09:55 AM | #2 |
Rep 4,518
Drives: 2022 iX xDrive50, DGM
With the multi-contour seats it's possible to adjust only the upper part of the seat back (including headrest) forward and back, but I don't think there's a tilt function on the headrest itself.
alpinekarthik105.50 |
01-04-2020, 10:16 AM | #3 |
Rep 527
If I remember correctly, there is a black button on the headrest (the medial side) when you press it and hold it then you should be able to move it back and forth if you do not have the multi contour seats option. Check it out! Enjoy your ride in good health!!
01-04-2020, 10:22 AM | #4 |
Rep 74
Thanks for the quick response! I do have the multi contour seat and it moves the entire top-back portion back and forth. Becoming a minor inconvenience, but I am sure I just need to find the sweet spot so the shoulder can rest without the head pushed to the front.
01-04-2020, 10:49 AM | #5 |
Rep 4,518
You do bring up an interesting point - I have the multi-contour seats, and inspecting the headrests there is a slot cut out on the underside in front of the supporting columns - that looks and feels like it was specifically designed for rearward travel of the headrests, although I could find no such adjustment lever, button or knob. Curiouser and curiouser....
01-04-2020, 10:58 AM | #6 | |
Rep 74
01-04-2020, 11:22 AM | #8 | |
Rep 4,246
The additional slot length is required for gaining access to and replacing the crash-activated gas-actuator in the head restraint. Replacing gas generator for left or right crash-active head restraint https://www.newtis.info/tisv2/a/en/g...ort/1Vnd7IH1KE The interior of crash-activated head restraint comprises of complex, spring-driven mechanical operating units activated by a pyro-actuator. As soon as the pyro-actuator ignites, it propels a release stick moving a release plate and setting two adjustment springs free. The springs, in turn, move the impact plate and the head restraint padding both forward and upward. The crash-activated headrests move up to 60 millimetres or 2.36" forward and up to 40 millimetres or 1.57" upward.
Current BMWs - '20 X5 xDrive40i M Sport, '20 BMW M550i | Past BMWs - '03 E39 540iT M Sport, '06 E53 4.8is, '11 E70 M Sport LCI
01-04-2020, 11:35 AM | #9 | ||
Rep 74
01-04-2020, 11:38 AM | #10 | |
Rep 4,246
The rail slotting part of these headrests is designed to gain access to the interior. You have to detach it and slide it down the extended railing. The slot in the head restraint cover allows for that. See the enlarged:
01-04-2020, 11:43 AM | #12 | ||
Rep 74
01-04-2020, 11:46 AM | #13 |
Rep 4,246
Until there's information that disputes the information provided for G05/06 multi-contour crash-activated front head restraints, we're going to agree to disagree.
01-04-2020, 12:17 PM | #14 |
Rep 4,246
Going to provide additional information for adjusting the head rests for owners with Sport Seating.
The button on the head restraints provides height adjustment. The head restraint does not tilt in any way. Fore position is achieved by increasing the head restraint height Aft position is achieved by decreasing the head restraint height Note video is for G01/02 but it's identical to the G05 with Sport Seats. The crash-activated Sport Seating head restraint moves up and forward in crash test:
mcsa65.00 alpinekarthik105.50 |
01-04-2020, 12:29 PM | #15 | |
Rep 74
01-04-2020, 01:22 PM | #16 | |
Rep 4,246
Given that the G05/06 active-crash comfort head restraints move up and front cushions pop forward - my thought is that what's why it's fixed for that reasoning. Have you tried adjusting the head restraint cushions forward? Grab the left and right edges of the cushion and gently pull forward.
01-04-2020, 03:13 PM | #17 | ||
Rep 74
Do you know if the issue only with multi contour seats? |
01-04-2020, 03:56 PM | #18 |
Rep 4,246
My person experience with multi-contour seating, since my 2001 E38 740i Sport, 2003 BMW 540iT M Sport LCI, E53 X5, 2006 E53 X5 4.8is, 2011 E70 X5 LCI, 2017 F15 X5, 2020 M550i to G05, has been that head restraints have never had a fore/aft adjustment l - only fixed.
M Sport seats and M Multifunction seats also don't have fore/aft adjustment. I've been able to find an optimal seating position - combination of recommended head restraint height, upper back rest tilt, back rest tilt - where I can comfortably rest my head against the head restraint ok long trips. While it maybe perceived as an issue, there maybe hasn't been enough consumer/market insight and feedback for designers and engineers to adjust the design for the past 2 decades. Perhaps they intended the upper back rest fore-aft tilt adjustment as parity to the head restraint fore-aft adjustment in sport seats.
01-04-2020, 04:16 PM | #19 | |
Rep 74
I don't mind the lack of support to move the head rest back and forth. That's not the issue. The issue is that the headrest is too forward to begin with, that you feel you are hunching when you lean all the way back to rest your shoulders. I think the headrest should be aligned with the level of the seat. |
Auricom4364.50 polychromatic134.50 |
01-04-2020, 04:24 PM | #20 | |
Rep 4,246
I did find that I have to tilt my backrest a bit more than usual and then tilt the upper backrest forward to maintain the 90 degree elbow bend. Perhaps try extending the steering wheel a bit to adjust the reach?
01-04-2020, 11:32 PM | #21 |
Rep 88
alpinekarthik it just seems to maybe (maybe I’m wrong) that the position you want to achieve is not correct. It seems from your photo that you’re trying too much leaning back in your lower part while it’s not good neither for the driving capabilities nor for your back I believe.
I believe the seats are made to allow resting your shoulders and head the way you should be doing that. Check out the real sport seats (I mean like in real racing car) - they are always in very much vertical position. |
01-05-2020, 12:17 AM | #22 | |
Rep 74
