11-17-2019, 07:32 PM | #1 |
Rep 54
Can't perform ftm reset
"perform reset" is greyed out..filled all tires up to correct pressure.
I sold the OEM wheels. not sure if they had the sensors in it or not.. Also can't use eco or sport modes.. 2016 340i , Canadian car. anyone experience this and have a solution ? |
11-17-2019, 07:56 PM | #2 |
Rep 144
Yeah man If your oem wheels had the sensors you won't be able to get a reading of the tire pressure on your new tires and you won't be able to switch driving modes. You can buy aftermarket sensors though they aren't that expensive
11-17-2019, 08:56 PM | #3 | |
Rep 10,473
11-17-2019, 10:05 PM | #4 | |
Rep 54
not under warranty anymore so doubt they will help out. |
01-31-2021, 02:00 PM | #5 | |
Rep 9
I am also facing the same issue with my BMW 328i 2014 Canadian Model |
01-31-2021, 02:36 PM | #7 |
Rep 4,931
The Canadian cars don't come with TMPS. They use rolling circumference as a means to determine low pressure, so there is no sensors.
Odd that it would be greyed out -- never seen that before. Did you try removing the negative battery terminal for a couple minutes to reset everything? |
02-01-2021, 05:15 PM | #9 | |
Rep 29
02-06-2024, 03:07 PM | #10 |
Rep 220
Big Bump..
What ended up happening with this? I have the same problem with my F80 M3. Greyed out FTM reset. Cannot stop constant gong warning while driving. Tire pressure is fine. Even put TPMS sensors in to try to prevent the gong, no resolution. |
02-06-2024, 03:20 PM | #11 |
Rep 6,069
On US cars if there is no tpms you can select all modes. If tpms has low pressure then sport mode is disabled. But you can put transmission in sport mode still.
02-06-2024, 05:23 PM | #12 | |
Rep 7,586
The two systems are:[/list]Direct System: TPM/RDC system which uses sensors in each wheeln that sends specific data to the RDC module[*]Indirect System: FTM/RPA system which uses wheel circumference & ABS wheel speed sensors[/list] You tell which system you have by pulling up the screen…it reveals in writing which system you have.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
