11-10-2019, 02:48 PM | #1 |
Member
899
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
The X5 came with 22" and know the tire pressure for that set. I moved to a 20" 275/45 and 305/40 Michelin's PA5 for the winter. How do you determine the right tire pressure? Currently they are set at 35 psi in the front and 42 psi in the rear. What should they be?
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
11-10-2019, 03:45 PM | #2 | |
Rep 68
If I am reading it correctly page 334 - 336 of the Owners Manual says for a 2019 X5 xDrive40i with two rows of seats "with Sport Package" - Tire inflation pressure values "up to" 100 mph/160 km/h. Front: 275/45 R20 .... 33 PSi Rear: 305/40 R20 .... 39 PSi -Tire inflation pressure values "over" 100 mph/160 km/h Front: 275/45 R20 .... 41 PSI Rear: 305/40 R20 ..... 45 PSi
2024 X5 40i AW M-Sport
2019 X5 40i AW M-Sport (Sold) 2015 X5 35d M-Sport AW (Sold) 2018 440i xDrive Gran Coupe AW-Ind Opal White,Merino Dash,MPPSK 2012 X5d AW (Sold) |
X54TH899.00 |
11-10-2019, 03:50 PM | #3 |
Rep 5,731
Drives: '24 iX50; '23 i4 M50
BTW, I thought the 275/35/22; 315/30/22 recommended psi was 39/45. Did you find that too high?
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
11-10-2019, 03:50 PM | #4 | ||
Member
899
Rep 2,032
11-10-2019, 05:41 PM | #5 | |
Rep 68
Front: 275/35 R22.... 38 PSi Rear: 315/30 R22 .... 45 PS I have been running the above psi without issue. Kief, Sorry not sure of the correct PSI for your 2020 X5 M50i. But the Owners Manual has the tire pressure for the 2019 X5 50i at and can only assume its similar for the 2020 X5 M50i. - Tire inflation pressure values "up to" 100 mph/160 km/h. Front: 275/35 R22 .... 38 PSI Rear: 315/40 R22 .... 45 PSi -Tire inflation pressure values "over" 100 mph/160 km/h Front: 275/35 R22 ... 44 PSI Rear: 315/30 R22 ... 49 PSI
Kief4438.50 |
11-12-2019, 12:48 PM | #6 |
Rep 494
Was the tire temperature always visible? Mine only has the pressure but no temperature!
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold) 2012 BMW X3 28i (sold) |
11-12-2019, 01:08 PM | #7 | |
Member
899
Rep 2,032
11-12-2019, 09:37 PM | #8 | |
Rep 2,609
HU_MGU/3E52: RDC_DRUCK_TEMP set to druck_und_temperatur I was pretty excited to add that at the start, but after a couple of months, ugh, whatever :-).
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
11-16-2019, 06:53 AM | #9 |
Rep 5,731
I have the temps noted here in the US without the need to code. Sorry for starting another thread below on 22" psi, but I just find 39/45 psi seems so high. Not sure why? I'm not overly concerned about comfort, rather lasting tire wear and avoiding a blow out bc they are set so high.
11-16-2019, 07:13 AM | #10 | |
Member
899
Rep 2,032
Kief4438.50 |
11-16-2019, 07:16 AM | #11 | ||
Rep 5,731
Another issue I have with the recommended 39/45 psi, is bc that's for five passengers and/or luggage. What's the recommended psi for just a driver and passenger?
11-16-2019, 07:22 AM | #12 | |||
Member
899
Rep 2,032
12-04-2019, 09:05 AM | #13 | |
Rep 137
For comfort, I'll probably play with some lower pressure levels, but I don't like to deviate too far from recommended (although I recognize the recommendations are probably biased toward safety/liability avoidance). FYI, I keep the tire pressure screen as one of my 8 preset buttons so I can easily check it. |
12-04-2019, 09:24 AM | #14 | |
Rep 1,952
12-04-2019, 11:08 AM | #15 |
Rick James
305
Rep 784
Does anyone use the iDrive Tire Pressure Monitor figures instead of a good tire pressure gauge? When reading the manual, it looks like they have iDrive numbers as a method of checking. This doesn't make sense, since there is an option to reset upon filling. I always use a good digital gauge...
Kief4438.50 |
12-04-2019, 11:09 AM | #16 | ||
Rep 5,731
And doesn't 52psi exceed the max psi on the tire itself, be careful!
12-04-2019, 07:07 PM | #17 |
Rep 137
Correction to my earlier post: what I thought was a change in recommended pressure because of the tire type I selected, appears to be the result of changing tire temperatures. In other words, the system is telling what your tire pressures should read based on their temperature, hotter = higher pressure. Makes sense and takes away the 'cold' pressure confusion for some folks.
Kief, I had selected 100mph+ which I believe would be a higher recommended pressure than at 'up to 100mph'. |
12-04-2019, 07:13 PM | #18 | |
Rep 137
Not sure I follow you on the resetting comment. Resetting doesn't recalibrate the iDrive readings, if that's what you meant. |
12-04-2019, 08:39 PM | #19 |
Rick James
305
Rep 784
Sorry misspoke. I was under the impression you got the reading Cold on a digital gauge then hit the button in iDrive to measure the pressure. Then it basically reset itself based off your work with the digital gauge. I figured that’s why they were always so close, the iDrive reading and digital. I was just curious since it was in the manual.
