11-05-2019, 08:05 PM | #1 |
Rep 47
Has my rear door gasket shrunk?
Hi all,
New to me 2014 F31, and it looks like the gasket around the rear doors is too short. It doesn't go all the way to the lower edge, and leaves a gap as a result. Both sides are the same. Is this normal? Not sure why the pics are rotated, or how to fix. |
11-06-2019, 08:14 AM | #4 |
Rep 47
11-06-2019, 08:19 AM | #5 | |
Rep 47
Found it https://f30.bimmerpost.com/forums/sh....php?t=1142680 Looks like replacing may be the best option Last edited by Hali_Mark; 11-06-2019 at 08:56 AM.. |
11-06-2019, 11:59 PM | #7 |
Rep 2,499
Seems to be a thing:
https://f30.bimmerpost.com/forums/sh....php?t=1142680 No easy answers. Looks like it has to be replaced. I wonder if BMW has even addressed the issue for new parts. |
11-07-2019, 06:42 AM | #8 | |
Rep 47
I may pull that section off and see if it will stretch after being warmed up with a heat gun. |
11-07-2019, 11:11 AM | #9 | |
Rep 2,499
You might also just consider taking it to a specialty shop that works with older cars where parts aren't made anymore. It might be cheaper and ultimately more effective to have it repaired rather than replaced with another shrinking seal. |
11-21-2019, 08:15 AM | #10 |
Rep 47
Just to update, I fixed it. The seal can be released on the inside of the door, but will still be in a channel on the outside of the door. This did allow good access to warm up both sides of it with a heat gun. I stretched it until it was in place and used automotive adhesive to keep it there. I held it in place with painters tape while the adhesive cured.
Hopefully it will last through the winter cold and remain permanent. |
