11-05-2019, 05:10 AM | #1 |
Rep 5
Mirror Glass
Also, on another note Guys. Regards F32 / F33.
Does anyone know how to get the mirror glass out of the housing without breaking it? (In need to replace the motor) |
11-05-2019, 06:42 AM | #2 |
Rep 716
Check for instructions on https://www.newtis.info/tisv2/a/en/
11-05-2019, 02:02 PM | #4 |
Rep 252
I took mine out, very carefully, and it broke... Mine is auto dim / dip model and the best price non-used was about $400. Be careful!! It is in there really, really well. It should be easier to detach than it was so it does not crack.
sspade2475.50 |
11-05-2019, 02:17 PM | #5 |
Rep 552
I was able to pop mine out pretty easily quite a few times. You just need a plastic trim pry tool. Angle the mirror(s) all the way up first, and then pry from the bottom out. When you angle them up, it creates a gap at the bottom and makes this easier. Youtube videos help as well
11-05-2019, 02:36 PM | #6 | |
Rep 252
Maybe the non-dimming are easier? I have done a lot of trim work in the past, and have never had the issues I had with the mirror. |
11-05-2019, 03:59 PM | #7 |
Rep 83
Drives: 2016 340ix MPPSK| 2015 R60 JCW
I was able to remove my auto dim mirror twice without cracking them...both driver and passenger. Kies Motorsports video explains how I did it but I used a wider trim removal tool
11-06-2019, 03:27 AM | #8 | ||
Rep 552
11-06-2019, 04:58 AM | #9 |
No 55mph
1623
Rep 8,479
Had the glass off on my auto dim/heated multiple times as well with no breakage
Important when using plastic pry tool to pry under edge of glass at center directly under motor ONLY - do not pry at outward edges of glass
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
IK6SPEED4499.00 |
11-06-2019, 01:18 PM | #12 | |
Rep 252
Seems like some are just in there more than others. That was the video I used, which was very helpful. I guess he was right that many will still break even when following that procedure. Luck of the draw I guess. Good to know she was built well |
11-06-2019, 02:06 PM | #13 |
Rep 2,664
I JUST removed my mirror caps to replace them. I didn't have to remove the glass at all. I heated the entire mirror first with a heat gun and slid an old credit card up from the middle of the mirror caps and worked side to side. They popped right off and no broken tabs. Don't mess with the glass, not worth it.
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
11-06-2019, 07:34 PM | #14 |
Rep 10,473
11-07-2019, 09:04 AM | #15 |
Rep 552
Use a plastic pry tool on the centre top or bottom and not the outer edges. There is less support from the backing plate on the outer edges and you can crack the glass.
Also I would slide some paper between or mask off the plastic surround trim as when you pry the glass can scape the surround plastic paint. |
11-07-2019, 02:01 PM | #16 |
Rep 128
Drives: 2024 BMW 228i Gran Coupe
I removed both mirrors to put on M caps. I used the plastic trim removal tool as a few others have said. It was quite easy with no issues.
11-11-2019, 08:53 PM | #17 |
Rep 209
Got these a year ago because of the wide angle. Very cheap but very good quality. They are heated but not dimming. Cant say I miss the auto-dimming option of the oem mirrors. Still have the originals in perfect shape but would not put them back on. I just love the wide view . In case you broke a mirror , these could make a great temp/permanent replacement.
https://m.aliexpress.com/item/329094...o1573526519503 |
