4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Weather Applet Not Working
      10-08-2019, 10:33 AM   #1
Pentop63
Pentop63's Avatar
Drives: X4 M40i
My weather applet has just decided to stop working ?? Anybody else got the same issue ?? I have deleted and added it back on the screen with no luck plus when I click on the global apps and click weather it works ??
Any clues or advise most welcome.. running latest firmware and have changed any settings.
      10-14-2019, 02:15 AM   #2
petejigsaw
Drives: BMW G20 330e
Same here - mine has disappeared and then reappeared once in the first week since delivery, and disappeared again yesterday without trace.......
      10-14-2019, 04:18 AM   #3
Vossy
Drives: G20 330E M Sport
As I posted elsewhere, just take a few minutes to read some of the reviews on the Apple App Store regarding the BMW Connected Drive App. Absolutely shocking some of the issues. I take delivery of a G20 330E in a few weeks time and had hoped to use it for more than just sending destinations asI do to my current 520D. Not looking forward to similar issues.
      10-14-2019, 05:06 AM   #4
tricky6
Drives: G20 330e M Sport+
I've found the app generally ok in my 3 weeks of ownership (running .40 build). I had one period where it was only partially connected to the car for 24 hours but it sorted itself out (no update on location/charge state but I could lock/unlock/flash the headlights).
The rest of it seems to work fine although there are gaps in functionality (e.g. lack of reporting on journey metrics such as MPG, electric usage etc.) Would also be good to get it to send a notification when charge is complete. I've submitted 3-4 things to the "Send Feedback" section.
The Apple Watch app also works well. Limited functionality but useful to check charge state in meetings, pre-condition the car etc.
      10-14-2019, 01:20 PM   #5
Pentop63
Pentop63's Avatar
Drives: X4 M40i
This is very strange... was driving down the M1 today and it magically started working ??? Booked into BMW tomorrow so will be interesting to see what’s in the log files.
      10-14-2019, 04:31 PM   #6
tricky6
Originally Posted by Pentop63 View Post
This is very strange... was driving down the M1 today and it magically started working ??? Booked into BMW tomorrow so will be interesting to see what's in the log files.
Probably nothing anyone at the dealer will understand given the various software related discussions/experiences on this board.
I had a fault with my Mondeo which manifested as a hissing sound through the speakers (regardless of whether any audio was being played) The car was off the road for 3 weeks (!!) until they fixed it. Turned out some unit responsible for central locking and electric windows was causing noise on the comms bus which also carried the audio. They didn't have a clue and replaced all kinds of things before solving it (new amp, new head unit, speakers, wiring etc)
BMW need to set up a proper technical support helpline rather than relying on their dealers. Changing the oil and replacing brake pads has little in common with diagnosing computer faults or glitches...
Having someone "official" on this kind of forum actively supporting us when we have problems would be another good step. Companies like Microsoft have been doing this for years...
But good luck for tomorrow!
      10-16-2019, 02:44 AM   #7
petejigsaw
I rebooted my iDrive 7 this morning and this has restarted the weather feed and also enabled Driver Recorder, which hadn't worked since I picked my car up last week. I'd suggest thrying that and see if it works.
Isow319.00
      10-16-2019, 02:54 AM   #8
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
Drives: BMW G20 330i RWD M Sport
Yep...
Just like the PC solution. Ctrl,Alt,Del.
If in doubt... do a reset...
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
Isow319.00
      10-16-2019, 04:48 AM   #9
Isow
Drives: G20 330i MSport
How do you reboot the idrive ?
Thank you
      10-16-2019, 04:56 AM   #10
Tam the Bam
Grumpy Old Git
Press the vol button and hold it pressed for at least 15 seconds... screen will reset. No settings are lost.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      11-02-2019, 03:53 AM   #11
Pentop63
Pentop63's Avatar
Drives: X4 M40i
Went to dealers and they reset the car then two weeks later it. Went again so back to the dealers in mid November, just seen post so will reset today.
      11-02-2019, 03:56 AM   #12
Burnzie’s BM
Burnzie’s BM's Avatar
Drives: BMW 330e 2019
This happened to me the second day of ownership but a few minutes later it started working again..... I didn’t do anything, it just started working......
      11-02-2019, 03:58 AM   #13
petejigsaw
A reboot of iDrive normally fixes it.
      11-02-2019, 08:11 AM   #14
Pentop63
Pentop63's Avatar
Drives: X4 M40i
Correct, reboot done and all is well, can’t believe dealer didn’t tell me this and wanted to book my car in for 2 days for investigation ?? TOP TIP... many thanks ��
      11-02-2019, 06:31 PM   #15
pjd001
Drives: BMW 330
My weather app also isn't working - stopped about a week ago. One day I noticed a new app appeared, then disappeared. I've had nothing but problems with the connections from G20 since acquiring it. I'm going to post separately now.
      04-19-2020, 08:03 AM   #16
billycheong
Drives: BMW G20 330i M Sport
I’m facing the same, it happened since last 3 day ago. Just now it automatic recover again. 🤦🏻*♂️
      04-19-2020, 10:07 AM   #17
Peter619
peter619
Peter619's Avatar
Drives: 2021 BMW 530i xDrive
Reboot
Just reboot your iDrive system. Press the power/volume button in and hold it until everything turns off. This corrects the issue for me. Also refreshes everything like your GPS and whatnot.
g20
