09-27-2019, 07:48 PM | #1 |
Rep 504
Premium gas costco
So i was told that my 30i requires premium 92 or above and i been doing that but that past three or four times been doing regular by accident . Previous car i always did regular which 87. How much damage do you think i did or am i safe as its only been done 3 to 4 refills. Never understood octane etc
09-27-2019, 08:28 PM | #2 |
Rep 64
Modern engines have knock sensors which can sense the offset in ignition timing due to the lower octane fuel which will prevent engine damage. They will adjust and it will limit your power output. For just cruising lower octane is generally fine, but when you floor it and the pressures get high it is not great for the engine.
Just stick to premium from now on and you'll be fine. |
nakamuru137.50 |
09-27-2019, 09:38 PM | #3 |
Rep 166
Octane determines how much pressure will cause the gas/air mix to “detonate” or literally explode. Needless to say that happening before the engine is ready is a bad thing. Higher octane can take a higher pressure as its “less” explosive. This also sadly means there is a lower energy density in higher octane gas (you’re paying more for less). As mentioned the modern engines try to safeguard themselves against this. Turbocharged engines typically always need high octane because they boost the pressure beyond normal compression anyway. More than likely your car is performing under its expected level and this is why as the engine has detuned itself to protect itself.
nakamuru137.50 |
09-27-2019, 11:25 PM | #4 |
Rep 1,599
Recommend You Look at the Online Driver's Guide for Your Car
The salient fuel advice for the M40i follow. You should look at the Driver's Guide for your car. I'm going to guess that they'll be identical:
nakamuru137.50 |
09-28-2019, 02:38 AM | #5 | |
Rep 504
09-28-2019, 05:17 AM | #6 |
Rep 351
09-28-2019, 06:35 AM | #7 |
Rep 2,323
Drives: 9Y0 Cayenne S
German automakers are based in a land where 95 octane is the norm, hence a contributing factor to the octane recommendation in non-German markets. Use the recommended fuel to achieve performance near what the manufacturer warrants.
nakamuru137.50 |
09-28-2019, 06:45 AM | #8 |
Rep 2,073
Beware the difference between octane ratings between US and Europe. US 93 is 98 in Europe. US 91 is 95 in Europe.
09-28-2019, 03:05 PM | #10 |
Rep 497
My previous X5 2004 was traded in with 215 thousand miles and still as strong and sweet sounding as new - I only used "regular" from day 1.
I am not going to argue that the car would have "preformed" better with higher octane, but it definitely, positively did no damage |
Amel13.00 |
09-29-2019, 04:23 PM | #11 | |
Rep 351
09-29-2019, 05:04 PM | #12 |
Photojournalist, Tech & Product Analyst
510
Rep 472
To my knowledge, most Costco Premium gas is rated 91 and is top tier. It is perfect for our BMW X3s (and have also used it for years in my Corvette, which also requires Premium).
Current:2024 i4 Mineral White Metallic with Blue Exterior Accents, Canberra Beige Perforated SensaTec, Premium Package, Driving Assistance Pro Package, Drive Recorder. 2019 X3 Mineral White Metallic, Caberra Beige interior with most options. Corvette Stingray Arctic White w red interior.
Past:2002 Z3, Corvette Stingray and about 40 other cars |
09-29-2019, 05:24 PM | #13 |
Rep 26
Costco Gasoline
From Costco’s website:
Regular unleaded and premium unleaded gasoline, and diesel at select locations. Gasoline octane can vary by state, but at Costco, it's typically 87 octane for Regular Unleaded and 91 octane for Premium Unleaded Gasoline. In Northern Virginia, it’s 93 octane. For what it’s worth, premium is typically 60-70 cents less expansive than other stations. |
09-30-2019, 09:24 AM | #15 | |
Rep 504
09-30-2019, 10:00 AM | #16 |
Rep 351
As far as I know BMW does not recommend any specific fuel any longer. They used to recommend BP, but now I believe they recommend any TOP TIER fuel, which is most of the big companies such as Shell, BP/Amoco, Mobil/Exxon, Valero, Costco and many others on the Top Tier website. They do not include Bj's. I have been using BP 93 for over 10 years with no issues in any of my BMW's. Just recently switched to Shell 93 because where I am it's about 10 cents a gallon less than the BP 93
09-30-2019, 06:04 PM | #19 |
Rep 351
09-30-2019, 06:43 PM | #20 |
Rep 1,000
10-01-2019, 12:09 PM | #21 |
Rep 409
My 2015 435i doesn't recommend Shell either, just premium fuel. They switched to a deal with Shell sometime after that. But I've been using Shell in my BMW's since 2008. Mike Miller has always preached about using Shell Vpower, so I do.
10-02-2019, 02:40 AM | #22 | |
Rep 1,959
